Project: 24xx - multiple EUE from pmsfh2008- mod editing now
pmsfh2008
Hardware configuration: MB: GB GA-EP45-UD3P GB GA-P55-UD3R
CPU: Intel Q9550 C2Q (@3.4 GHz) Intel i7-860 (@3.762 Ghz)
RAM: 8GB Mushkin 996622 Ascent 996580 Mushkin 8GB 2x 996782 frosty
GPU: 2x EVGA GTX260-216 SC (@1350) Gigabyte GeForce 210
OS: Vista 64b Vista 32b
Folding: 2x GPU SMPx8
[updated 8/26/12 - i7 Vista v7.1.52 updated]
Post by pmsfh2008 »
[02:47:06] Completed 82500 out of 250000 steps  (33%)
[03:14:26] Writing local files
[03:14:26] Completed 85000 out of 250000 steps  (34%)
[03:36:30] Quit 101 - Fatal error:
[03:36:30] Step 87020, time 2674.04 (ps)  LINCS WARNING
[03:36:30] relative constraint deviation after LINCS:
[03:36:30] max 0.540604 (between atoms 3185 and 3186) rms 1.#QNAN0
[03:36:30]
[03:36:30] Simulation instability has been encountered. The run has entered a
[03:36:30]   state from which no further progress can be made.
[03:36:30] This may be the correct result of the simulation, however if you
[03:36:30]   often see other project units terminating early like this
[03:36:30]   too, you may wish to check the stability of your computer (issues
[03:36:30]   such as high temperature, overclocking, etc.).
[03:36:30] Going to send back what have done.
[03:36:30] logfile size: 32899
[03:36:30] - Writing 33582 bytes of core data to disk...
[03:36:30]   ... Done.
[03:36:30]
[03:36:30] Folding@home Core Shutdown: EARLY_UNIT_END
[03:36:34] CoreStatus = 72 (114)
[03:36:34] Sending work to server
[03:36:34] Project: 2483 (Run 277, Clone 2, Gen 5)
[03:36:34] - Read packet limit of 540015616... Set to 524286976.
Edited by susato to condense thread; deleted posts summarized here.
pmsfh2008 also posted in the next 15 minutes:
Project: 2483 (Run 136, Clone 17, Gen 15) EUE 2% NAN
Project: 2485 (Run 248, Clone 39, Gen 2) EUE 22% NAN
Project: 2484 (Run 111, Clone 26, Gen 11) EUE 7% NaN
Project: 2483 (Run 280, Clone 35, Gen 14) EUE 5% NaN
Project: 2483 (Run 32, Clone 37, Gen 7) EUE 18% NaN
Project: 2484 (Run 1, Clone 5, Gen 8) EUE 17% NaN
Project: 2484 (Run 116, Clone 3, Gen 12) EUE 0% NaN
Project: 2483 (Run 2, Clone 22, Gen 7) EUE 19% NaN
Project: 2484 (Run 122, Clone 8, Gen 15) EUE 3% NaN
ChasR
Re: Project: 2483 (Run 32, Clone 37, Gen 7) EUE 18% NaN
Post by ChasR »
You don't need to post WU failures that are sent back to the server.
Foxery
Hardware configuration: Intel Core2 Quad Q9300 (Intel P35 chipset)
Radeon 3850, 512MB model (Catalyst 8.10)
Windows XP, SP2
Re: Project: 2484 (Run 122, Clone 8, Gen 15) EUE 3% NaN
Post by Foxery »
Please don't spam the forums... if you are having this many errors in such a short time, your computer is definitely unstable. You will need to decrease overclocks/increase voltages and run a stability test to figure out what is causing your crashes.
Core2 Quad/Q9300, Radeon 3850/512MB (WinXP SP2)
Foxery wrote:Please don't spam the forums... if you are having this many errors in such a short time, your computer is definitely unstable. You will need to decrease overclocks/increase voltages and run a stability test to figure out what is causing your crashes.
I agree. I checked some WUs and the number of reports clearly shows an issue with your machine (most WU were finally completed by another donor).
Please check your system stability.
Re: Project: 2485 (Run 248, Clone 39, Gen 2) EUE 22% NAN
Which tells us it's a hardware / overclock issue...
And a large number of errors all in the same project should be lumped together in one Post, not a dozen. Thanks. (maybe a mod can clean this up a bit.) ;)
pmsfh2008
Re: Project: 24xx - multiple EUE from pmsfh2008
Post by pmsfh2008 »
Yep!
Everest testing did not error but prime95 did in 20 min with rounding.
Why this would crop up after months of folding is?
Thanks
Phil
susato
Re: Project: 24xx - multiple EUE from pmsfh2008- mod editing now
Post by susato »
Thanks for testing, Phil.
Every component fails eventually. Something in your system simply reached the end of its lifespan. Try a memory test. With computers as with humans, the memory's the first to go. (Hmm, did I remember that quote correctly?) :wink:
And in computers it's the cheapest to replace. Sure wish I could expand my "bioware" memory so easily.
