Project: 44xx - multiple EUE from pmsfh2008
pmsfh2008
Hardware configuration: MB: GB GA-EP45-UD3P GB GA-P55-UD3R
CPU: Intel Q9550 C2Q (@3.4 GHz) Intel i7-860 (@3.762 Ghz)
RAM: 8GB Mushkin 996622 Ascent 996580 Mushkin 8GB 2x 996782 frosty
GPU: 2x EVGA GTX260-216 SC (@1350) Gigabyte GeForce 210
OS: Vista 64b Vista 32b
Folding: 2x GPU SMPx8
[updated 8/26/12 - i7 Vista v7.1.52 updated]
Post by pmsfh2008 »
Completed 255000 out of 1500000 steps  (17%)
[02:03:50] Quit 101 - Fatal error: NaN detected: (ener[17])
[02:03:50]
[02:03:50] Simulation instability has been encountered. The run has entered a
[02:03:50]   state from which no further progress can be made.
[02:03:50] This may be the correct result of the simulation, however if you
[02:03:50]   often see other project units terminating early like this
[02:03:50]   too, you may wish to check the stability of your computer (issues
[02:03:50]   such as high temperature, overclocking, etc.).
[02:03:50] Going to send back what have done.
[02:03:50] logfile size: 9331
[02:03:50] - Writing 9894 bytes of core data to disk...
[02:03:50] Done: 9382 -> 3473 (compressed to 37.0 percent)
[02:03:50]   ... Done.
[02:03:50]
[02:03:50] Folding@home Core Shutdown: EARLY_UNIT_END
[02:03:52] CoreStatus = 72 (114)
[02:03:52] Sending work to server
[02:03:52] Project: 4451 (Run 922, Clone 3, Gen 3)
[02:03:52] - Read packet limit of 540015616... Set to 524286976.
pmsfh2008
Project: 4460 (Run 967, Clone 3, Gen 8) EUE 5% NaN
Post by pmsfh2008 »
Completed 75000 out of 1500000 steps  (5%)
[00:55:06] Quit 101 - Fatal error: NaN detected: (ener[17])
[00:55:06]
[00:55:06] Simulation instability has been encountered. The run has entered a
[00:55:06]   state from which no further progress can be made.
[00:55:06] This may be the correct result of the simulation, however if you
[00:55:06]   often see other project units terminating early like this
[00:55:06]   too, you may wish to check the stability of your computer (issues
[00:55:06]   such as high temperature, overclocking, etc.).
[00:55:06] Going to send back what have done.
[00:55:06] logfile size: 0
[00:55:06] Warning: Core could not open logfile.
[00:55:06] - Writing 563 bytes of core data to disk...
[00:55:06] Done: 51 -> 91 (compressed to 178.4 percent)
[00:55:06] Gromacs cannot continue further.
[00:55:06] logfile size: 10680
[00:55:06] - Writing 11216 bytes of core data to disk...
[00:55:06] Done: 10704 -> 3486 (compressed to 32.5 percent)
[00:55:06]   ... Done.
[00:55:06]
[00:55:06] Folding@home Core Shutdown: EARLY_UNIT_END
[00:55:10] CoreStatus = 72 (114)
[00:55:10] Sending work to server
[00:55:10] Project: 4460 (Run 967, Clone 3, Gen 8)
[00:55:10] - Read packet limit of 540015616... Set to 524286976.
pmsfh2008
Project: 4452 (Run 809, Clone 2, Gen 6) EUE 7% NaN
Post by pmsfh2008 »
Completed 105000 out of 1500000 steps  (7%)
[02:47:35] Quit 101 - Fatal error: NaN detected: (ener[13])
[02:47:35]
[02:47:35] Simulation instability has been encountered. The run has entered a
[02:47:35]   state from which no further progress can be made.
[02:47:35] This may be the correct result of the simulation, however if you
[02:47:35]   often see other project units terminating early like this
[02:47:35]   too, you may wish to check the stability of your computer (issues
[02:47:35]   such as high temperature, overclocking, etc.).
[02:47:35] Going to send back what have done.
[02:47:35] logfile size: 8521
[02:47:35] - Writing 9084 bytes of core data to disk...
[02:47:35] Done: 8572 -> 3226 (compressed to 37.6 percent)
[02:47:35]   ... Done.
[02:47:35]
[02:47:35] Folding@home Core Shutdown: EARLY_UNIT_END
[02:47:37] CoreStatus = 72 (114)
[02:47:37] Sending work to server
[02:47:37] Project: 4452 (Run 809, Clone 2, Gen 6)
[02:47:37] - Read packet limit of 540015616... Set to 524286976.
pmsfh2008
Project: 4444 (Run 47, Clone 1, Gen 8) EUE 3% NaN
Post by pmsfh2008 »
Completed 45000 out of 1500000 steps  (3%)
[03:40:24] Quit 101 - Fatal error: NaN detected: (ener[13])
[03:40:24]
[03:40:24] Simulation instability has been encountered. The run has entered a
[03:40:24]   state from which no further progress can be made.
[03:40:24] This may be the correct result of the simulation, however if you
[03:40:24]   often see other project units terminating early like this
[03:40:24]   too, you may wish to check the stability of your computer (issues
[03:40:24]   such as high temperature, overclocking, etc.).
[03:40:24] Going to send back what have done.
[03:40:24] logfile size: 0
[03:40:24] Warning: Core could not open logfile.
[03:40:24] - Writing 563 bytes of core data to disk...
[03:40:24] Done: 51 -> 91 (compressed to 178.4 percent)
[03:40:24] Gromacs cannot continue further.
[03:40:24] logfile size: 10006
[03:40:24] - Writing 10542 bytes of core data to disk...
[03:40:24] Done: 10030 -> 3479 (compressed to 34.6 percent)
[03:40:24]   ... Done.
[03:40:24]
[03:40:24] Folding@home Core Shutdown: EARLY_UNIT_END
[03:40:28] CoreStatus = 72 (114)
[03:40:28] Sending work to server
[03:40:28] Project: 4444 (Run 47, Clone 1, Gen 8)
[03:40:28] - Read packet limit of 540015616... Set to 524286976.
[03:40:28] + Attempting to send results [March 13 03:40:28
pmsfh2008
Project: 4438 (Run 244, Clone 4, Gen 9) EUE 3% NaN
Post by pmsfh2008 »
[04:35:20] Quit 101 - Fatal error: NaN detected: (ener[13])
[04:35:20]
[04:35:20] Simulation instability has been encountered. The run has entered a
[04:35:20]   state from which no further progress can be made.
[04:35:20] This may be the correct result of the simulation, however if you
[04:35:20]   often see other project units terminating early like this
[04:35:20]   too, you may wish to check the stability of your computer (issues
[04:35:20]   such as high temperature, overclocking, etc.).
[04:35:20] Going to send back what have done.
[04:35:20] logfile size: 8523
[04:35:20] - Writing 9086 bytes of core data to disk...
[04:35:20] Done: 8574 -> 3232 (compressed to 37.6 percent)
[04:35:20]   ... Done.
[04:35:20]
[04:35:20] Folding@home Core Shutdown: EARLY_UNIT_END
[04:35:23] CoreStatus = 72 (114)
[04:35:23] Sending work to server
[04:35:23] Project: 4438 (Run 244, Clone 4, Gen 9)
[04:35:23] - Read packet limit of 540015616... Set to 524286976.
[04:35:23] + Attempting to send results [March 13 04:35:23 UTC]
Re: Project: 4460 (Run 967, Clone 3, Gen 8) EUE 5% NaN
I checked some WUs and the number of reports clearly shows an issue with your machine (most WU were finally completed by another donor).
Please check your system stability.
pmsfh2008
Re: Project: 44xx - multiple EUE from pmsfh2008
Post by pmsfh2008 »
Yep!
Everest testing did not error but prime95 did in 20 min with rounding.
Why this would crop up after months of folding is?
Thanks
Phil
