Somewhat New...Just Checking
scozzie
Post by scozzie »
I've been running F@h for a few months now and just wanted to check I have things setup correctly.
My system:
ASUSP5KC
Intel Q9450 2.66MHz (Quad)
4GB RAM
nVidia 8600GT
I am running 4 uni clients and the gpu client.
These are my results
Are they about right? Will I get better results if I run the SMP client? :?
Thanks :|
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: Somewhat New...Just Checking
Post by MtM »
You would get more points with smp. For uniprocessor it looks rather okish for that cpu.
Gpu seems pretty good depending on wu :twisted:
Btw, you say 4 uni's but I only see 3?
scozzie
Post by scozzie »
Sorry, I meant to say 3 uni clients :lol:
Thanks for your reply. I think I might try SMP client then, see how it goes.
I've tried bumping up the shader clock to 1670 and upping the core and mem clocks slightly with the gpu, and it bumped up the ppd, but then got "exception thrown during guarded run" which I assumed was related to GPU instability, so I'll clock back a bit until its stable.
MtM
Post by MtM »
Uhm don't test with f@h, try to use Occt or something for stable clocks, and drop 10% after that since f@h stable != 3d stable.
If you need any help with smp just post :)
Welcome to the forums, and happy folding!
scozzie
Post by scozzie »
ok thanks for the help!
Just one question, which SMP client do I use? Deino or MPICH :|
MPICH client is sensitive to network changes but easy to setup.
Deino client is more robust regarding these network changes, but it is not available for 64 bits OS and a bit more more harder to setup.
Whatever version you choose, use the official installation guides ... it will save you time ;)
scozzie
Post by scozzie »
Ahh ok. Went with the Deino client. Got it setup and running, but in task manager, the 4 cores are only sitting around 30%. Surely they should be maxed?
Although Bill Process Manager does show the core using 100% cpu :e?:
DanGe
Hardware configuration: 2018 Mac Mini / MacOS Catalina
3.2 GHz 6-Core Intel Core i7
Post by DanGe »
Could you post your log file (between the tags)? It looks like you forgot the -smp -deino flags.
scozzie
Post by scozzie »
doh...I hadn't added -smp and -deino flags.
Did that, now I get the "work type a1 not eligible for variable processors"
--- Opening Log file [March 11 02:45:53 UTC]
                       Folding@Home Client Version 6.23 Beta R1
                          http://folding.stanford.edu
Launch directory: C:\Program Files\FAHSMP
Executable: C:\Program Files\FAHSMP\Folding@home-Win32-x86.exe
Arguments: -local -smp -deino
[02:45:53] - Ask before connecting: No
[02:45:53] - User name: the_scotsman (Team 24)
[02:45:53] - User ID: 42DE5BB36F6B7DE6
[02:45:53] - Machine ID: 5
[02:45:53]
[02:45:53] Work directory not found. Creating...
[02:45:53] Could not open work queue, generating new queue...
[02:45:53] - Preparing to get new work unit...
[02:45:53] + Attempting to get work packet
[02:45:53] - Connecting to assignment server
[02:45:54] - Successful: assigned to (171.64.65.64).
[02:45:54] + News From Folding@Home: Welcome to Folding@Home
[02:45:54] Loaded queue successfully.
[02:46:30] + Closed connections
[02:46:30]
[02:46:30] + Processing work unit
[02:46:30] Work type a1 not eligible for variable processors
[02:46:30] Core required: FahCore_a1.exe
[02:46:30] Core not found.
[02:46:30] - Core is not present or corrupted.
[02:46:30] - Attempting to download new core...
[02:46:30] + Downloading new core: FahCore_a1.exe
[02:46:31] + 10240 bytes downloaded
[02:46:32] + 20480 bytes downloaded
[02:46:32] + 30720 bytes downloaded
[02:46:32] + 40960 bytes downloaded
[02:46:32] + 51200 bytes downloaded
[02:46:32] + 61440 bytes downloaded
[02:46:32] + 71680 bytes downloaded
[02:46:32] + 81920 bytes downloaded
[02:46:32] + 92160 bytes downloaded
[02:46:32] + 102400 bytes downloaded
[02:46:32] + 112640 bytes downloaded
[02:46:33] + 122880 bytes downloaded
[02:46:33] + 133120 bytes downloaded
[02:46:33] + 143360 bytes downloaded
[02:46:33] + 153600 bytes downloaded
[02:46:33] + 163840 bytes downloaded
[02:46:33] + 174080 bytes downloaded
[02:46:33] + 184320 bytes downloaded
[02:46:33] + 194560 bytes downloaded
[02:46:33] + 204800 bytes downloaded
[02:46:33] + 215040 bytes downloaded
[02:46:33] + 225280 bytes downloaded
[02:46:33] + 235520 bytes downloaded
[02:46:33] + 245760 bytes downloaded
[02:46:33] + 256000 bytes downloaded
[02:46:33] + 266240 bytes downloaded
[02:46:33] + 276480 bytes downloaded
[02:46:33] + 286720 bytes downloaded
[02:46:35] + 296960 bytes downloaded
[02:46:38] + 307200 bytes downloaded
[02:46:41] + 317440 bytes downloaded
[02:46:42] + 327680 bytes downloaded
[02:46:46] + 337920 bytes downloaded
[02:46:48] + 348160 bytes downloaded
[02:46:52] + 358400 bytes downloaded
[02:46:54] + 368640 bytes downloaded
[02:46:57] + 378880 bytes downloaded
[02:46:59] + 389120 bytes downloaded
[02:47:03] + 399360 bytes downloaded
[02:47:04] + 409600 bytes downloaded
[02:47:04] + 419840 bytes downloaded
[02:47:04] + 430080 bytes downloaded
[02:47:05] + 440320 bytes downloaded
[02:47:05] + 450560 bytes downloaded
[02:47:05] + 460800 bytes downloaded
[02:47:05] + 471040 bytes downloaded
[02:47:05] + 481280 bytes downloaded
[02:47:05] + 491520 bytes downloaded
[02:47:05] + 501760 bytes downloaded
[02:47:05] + 512000 bytes downloaded
[02:47:05] + 522240 bytes downloaded
[02:47:05] + 532480 bytes downloaded
[02:47:05] + 542720 bytes downloaded
[02:47:05] + 552960 bytes downloaded
[02:47:05] + 563200 bytes downloaded
[02:47:05] + 573440 bytes downloaded
[02:47:05] + 583680 bytes downloaded
[02:47:05] + 593920 bytes downloaded
[02:47:05] + 604160 bytes downloaded
[02:47:05] + 614400 bytes downloaded
[02:47:05] + 624640 bytes downloaded
[02:47:05] + 634880 bytes downloaded
[02:47:05] + 645120 bytes downloaded
[02:47:05] + 655360 bytes downloaded
[02:47:05] + 665600 bytes downloaded
[02:47:06] + 675840 bytes downloaded
[02:47:06] + 686080 bytes downloaded
[02:47:06] + 696320 bytes downloaded
[02:47:07] + 706560 bytes downloaded
[02:47:07] + 716800 bytes downloaded
[02:47:07] + 727040 bytes downloaded
[02:47:08] + 737280 bytes downloaded
[02:47:08] + 747520 bytes downloaded
[02:47:08] + 757760 bytes downloaded
[02:47:08] + 768000 bytes downloaded
[02:47:08] + 778240 bytes downloaded
[02:47:08] + 788480 bytes downloaded
[02:47:08] + 795847 bytes downloaded
[02:47:08] Verifying core Core_a1.fah...
[02:47:08] Signature is VALID
[02:47:08]
[02:47:08] Trying to unzip core FahCore_a1.exe
[02:47:08] Decompressed FahCore_a1.exe (2117632 bytes) successfully
[02:47:13] + Core successfully engaged
[02:47:18]
[02:47:18] + Processing work unit
[02:47:18] Work type a1 not eligible for variable processors
[02:47:18] Core required: FahCore_a1.exe
[02:47:18] Core found.
[02:47:18] Working on queue slot 01 [March 11 02:47:18 UTC]
[02:47:18] + Working ...
[02:49:33] CoreStatus = 1 (1)
[02:49:33] Sending work to server
[02:49:33] Project: 2653 (Run 30, Clone 41, Gen 129)
[02:49:33] - Error: Could not get length of results file work/wuresults_01.dat
[02:49:33] - Error: Could not read unit 01 file. Removing from queue.
[02:49:33] - Preparing to get new work unit...
[02:49:33] + Attempting to get work packet
[02:49:33] - Connecting to assignment server
[02:49:33] - Successful: assigned to (171.64.65.64).
[02:49:33] + News From Folding@Home: Welcome to Folding@Home
[02:49:34] Loaded queue successfully.
[02:50:40] + Closed connections
[02:50:45]
[02:50:45] + Processing work unit
[02:50:45] Work type a1 not eligible for variable processors
[02:50:45] Core required: FahCore_a1.exe
[02:50:45] Core found.
[02:50:45] Working on queue slot 02 [March 11 02:50:45 UTC]
[02:50:45] + Working ...
[02:52:59] CoreStatus = 1 (1)
[02:52:59] Sending work to server
[02:52:59] Project: 2653 (Run 30, Clone 41, Gen 129)
[02:52:59] - Error: Could not get length of results file work/wuresults_02.dat
[02:52:59] - Error: Could not read unit 02 file. Removing from queue.
[02:52:59] - Preparing to get new work unit...
[02:52:59] + Attempting to get work packet
[02:52:59] - Connecting to assignment server
[02:53:00] - Successful: assigned to (171.64.65.63).
[02:53:00] + News From Folding@Home: Welcome to Folding@Home
[02:53:00] Loaded queue successfully.
[02:53:20] + Closed connections
[02:53:25]
[02:53:25] + Processing work unit
[02:53:25] Work type a1 not eligible for variable processors
[02:53:25] Core required: FahCore_a1.exe
[02:53:25] Core found.
[02:53:25] Working on queue slot 03 [March 11 02:53:25 UTC]
[02:53:25] + Working ...
[02:55:37] CoreStatus = 1 (1)
[02:55:37] Sending work to server
[02:55:37] Project: 3065 (Run 1, Clone 404, Gen 5)
[02:55:37] - Error: Could not get length of results file work/wuresults_03.dat
[02:55:37] - Error: Could not read unit 03 file. Removing from queue.
[02:55:37] - Preparing to get new work unit...
[02:55:37] + Attempting to get work packet
[02:55:37] - Connecting to assignment server
[02:55:38] - Successful: assigned to (171.64.65.63).
[02:55:38] + News From Folding@Home: Welcome to Folding@Home
[02:55:38] Loaded queue successfully.
[02:55:57] + Closed connections
[02:56:02]
[02:56:02] + Processing work unit
[02:56:02] Work type a1 not eligible for variable processors
[02:56:02] Core required: FahCore_a1.exe
[02:56:02] Core found.
[02:56:02] Working on queue slot 04 [March 11 02:56:02 UTC]
[02:56:02] + Working ...
[02:58:15] CoreStatus = 1 (1)
[02:58:15] Sending work to server
[02:58:15] Project: 3065 (Run 1, Clone 404, Gen 5)
[02:58:15] - Error: Could not get length of results file work/wuresults_04.dat
[02:58:15] - Error: Could not read unit 04 file. Removing from queue.
[02:58:15] - Preparing to get new work unit...
[02:58:15] + Attempting to get work packet
[02:58:15] - Connecting to assignment server
[02:58:16] - Successful: assigned to (171.64.65.63).
[02:58:16] + News From Folding@Home: Welcome to Folding@Home
[02:58:16] Loaded queue successfully.
[02:58:59] + Closed connections
[02:59:04]
[02:59:04] + Processing work unit
[02:59:04] Work type a1 not eligible for variable processors
[02:59:04] Core required: FahCore_a1.exe
[02:59:04] Core found.
[02:59:04] Working on queue slot 05 [March 11 02:59:04 UTC]
[02:59:04] + Working ...
[03:01:17] CoreStatus = 1 (1)
[03:01:17] Sending work to server
[03:01:17] Project: 3065 (Run 1, Clone 404, Gen 5)
[03:01:17] - Error: Could not get length of results file work/wuresults_05.dat
[03:01:17] - Error: Could not read unit 05 file. Removing from queue.
[03:01:17] - Preparing to get new work unit...
[03:01:17] + Attempting to get work packet
[03:01:17] - Connecting to assignment server
[03:01:18] - Successful: assigned to (171.64.65.64).
[03:01:18] + News From Folding@Home: Welcome to Folding@Home
[03:01:18] Loaded queue successfully.
[03:01:19] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[03:01:31] + Attempting to get work packet
[03:01:31] - Connecting to assignment server
[03:01:32] - Successful: assigned to (171.64.65.64).
[03:01:32] + News From Folding@Home: Welcome to Folding@Home
[03:01:33] Loaded queue successfully.
[03:02:08] + Closed connections
[03:02:13]
[03:02:13] + Processing work unit
[03:02:13] Work type a1 not eligible for variable processors
[03:02:13] Core required: FahCore_a1.exe
[03:02:13] Core found.
[03:02:13] Working on queue slot 06 [March 11 03:02:13 UTC]
[03:02:13] + Working ...
