[20:15:53] - Starting from initial work packet
[20:15:53]
[20:15:53] Project: 2495 (Run 0, Clone 6, Gen 0)
[20:15:53]
[20:15:53] Assembly optimizations on if available.
[20:15:53] Entering M.D.
[20:16:01] Protein: system
[20:16:01]
[20:16:01] Writing local files
[20:16:01] Gromacs error.
[20:16:01]
[20:16:01] Folding@home Core Shutdown: UNKNOWN_ERROR
[20:16:03] CoreStatus = 79 (121)
[20:16:03] Client-core communications error: ERROR 0x79
[20:16:03] This is a sign of more serious problems, shutting down.
Re: Project: 2495 (Run 0, Clone 6, Gen 0)
Howieh, please post some info about your system and client - thanks in advance.
The system is an Intel quad core Q6600 @ 2.40 Ghz , not OC'd, 3 GB ram, Vista Home Premium 32 bit. I run 4 clients on the system. The client log file is below.
The log below is my last attempt to run this wu. I had deleted the work folder and queue.dat prior to starting the client. I also had previously deleted the core and had it re-download.
--- Opening Log file [March 10 20:46:13 UTC]
Folding@Home Client Version 6.20
http://folding.stanford.edu
Launch directory: C:\Users\X000658\FAH62
Executable: C:\Users\X000658\FAH62\Folding@home-Win32-x86.exe
Arguments: -local -forceasm -verbosity 9
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[20:46:13] - Ask before connecting: No
[20:46:13] - User name: howieh_ (Team 4)
[20:46:13] - User ID: 797C3FAF7D1BABB1
[20:46:13] - Machine ID: 2
[20:46:13]
[20:46:13] Work directory not found. Creating...
[20:46:13] Could not open work queue, generating new queue...
[20:46:13] - Preparing to get new work unit...
[20:46:13] + Attempting to get work packet
[20:46:13] - Autosending finished units... [March 10 20:46:13 UTC]
[20:46:13] - Will indicate memory of 3069 MB
[20:46:13] Trying to send all finished work units
[20:46:13] - Detect CPU.[20:46:13] + No unsent completed units remaining.
Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[20:46:13] - Autosend completed
[20:46:13] - Connecting to assignment server
[20:46:13] Connecting to http://assign.stanford.edu:8080/
[20:46:17] Posted data.
[20:46:17] Initial: 41AB; - Successful: assigned to (171.65.103.160).
[20:46:17] + News From Folding@Home: Welcome to Folding@Home
[20:46:17] Loaded queue successfully.
[20:46:17] Connecting to http://171.65.103.160:8080/
[20:46:20] Posted data.
[20:46:20] Initial: 0000; - Receiving payload (expected size: 98607)
[20:46:21] - Downloaded at ~96 kB/s
[20:46:21] - Averaged speed for that direction ~96 kB/s
[20:46:21] + Received work.
[20:46:21] + Closed connections
[20:46:21]
[20:46:21] + Processing work unit
[20:46:21] Core required: FahCore_78.exe
[20:46:21] Core found.
[20:46:21] Working on queue slot 01 [March 10 20:46:21 UTC]
[20:46:21] + Working ...
[20:46:21] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -forceasm -verbose -lifeline 164 -version 620'
[20:46:21]
[20:46:21] *------------------------------*
[20:46:21] Folding@Home Gromacs Core
[20:46:21] Version 1.90 (March 8, 2006)
[20:46:21]
[20:46:21] Preparing to commence simulation
[20:46:21] - Assembly optimizations manually forced on.
[20:46:21] - Not checking prior termination.
[20:46:22] - Expanded 98095 -> 6897665 (decompressed 7031.6 percent)
[20:46:22] - Starting from initial work packet
[20:46:22]
[20:46:22] Project: 2495 (Run 0, Clone 6, Gen 0)
[20:46:22]
[20:46:22] Assembly optimizations on if available.
[20:46:22] Entering M.D.
[20:46:29] Protein: system
[20:46:29]
[20:46:29] Writing local files
[20:46:29] Gromacs error.
[20:46:29]
[20:46:29] Folding@home Core Shutdown: UNKNOWN_ERROR
[20:46:31] CoreStatus = 79 (121)
[20:46:31] Client-core communications error: ERROR 0x79
[20:46:31] This is a sign of more serious problems, shutting down.
It looks like the data file for your WU is invalid ... the downloaded size seems too low.
From your log :
From your log :
From a log from one of my machines :[20:46:20] Initial: 0000; - Receiving payload (expected size: 98607)
[23:26:15] Initial: 0000; - Receiving payload (expected size: 2208340)
[23:26:37] Project: 2495 (Run 22, Clone 34, Gen 0)
This unit came back to me tonight, any suggestions on how to avoid it?
anandhanju
Ubfortunately, no
. You can delete the queue again but that isn't going to stop it from coming back again. I hope one of the mods marks this as a bad WU so that a researcher can decide to run it internally in their lab.
I've marked it as a bad WU ...
Thank you.
