Help with gkrellm widgets installation
Post by muziqaz »
I am having a nightmare with gkrellm widgets installation :(
have gkrellm installed all good and working, but when I try to install gkrellmfah plugin, 'make' command drops an error saying
In file included from gkrellfah.c:33:
gkrellfah.h:5:29: error: gkrellm/gkrellm.h: No such file or directory
goodle suggested that I haven't got some of the headers installed for gtk and other engines(or whatever they are). so I got all of them installed(or so I think).
Then I lost the hope with gkrellmfah, and found gkrellm-gkrellfah2-1.2.3
thought give that thing a try.
Compiling gkrellfah2S.sosrc/gfahS.c:25:31: error: gkrellm2/gkrellmd.h: No such file or directory
niice.
I even 'build-dep' for gkrellm package, nothing...
going to bed now.
I just need a widget for gnome.
by the way ubuntu 8.10 64bit here
FAH Omega tester
