Project: 4742 (Run 8, Clone 381, Gen 7)
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Post by MtM »
As reported in the ati specific section by two users. As they haven't posted it here yet I'm taking the liberty to do so.
CPUacreage wrote:I searched the forum and found two hits on "SHAKE" from back in November, so I thought I'd start a new thread.
Machine
XP SP3 Q6600 OC 3.0GHz, 4GB mem
Catalyst version 08.12
2xHD3780 folding 24/7 stock clocks
SHAKE violations on GPU
details in code:
[08:55:58] Completed 100%
[08:55:58] Successful run
[08:55:58] DynamicWrapper: Finished Work Unit: sleep=10000
[08:56:08] Reserved 1943200 bytes for xtc file; Cosm status=0
[08:56:08] Allocated 1943200 bytes for xtc file
[08:56:08] - Reading up to 1943200 from "work/wudata_04.xtc": Read 1943200
[08:56:08] Read 1943200 bytes from xtc file; available packet space=784487264
[08:56:08] xtc file hash check passed.
[08:56:08] Reserved 30216 30216 784487264 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[08:56:08] Allocated 30216 bytes for arc file
[08:56:08] - Reading up to 30216 from "work/wudata_04.trr": Read 30216
[08:56:08] Read 30216 bytes from arc file; available packet space=784457048
[08:56:08] trr file hash check passed.
[08:56:08] Allocated 560 bytes for edr file
[08:56:08] Read bedfile
[08:56:08] edr file hash check passed.
[08:56:08] Allocated 96569 bytes for logfile
[08:56:08] Read logfile
[08:56:08] GuardedRun: success in DynamicWrapper
[08:56:08] GuardedRun: done
[08:56:08] Run: GuardedRun completed.
[08:56:08] - Writing 2071057 bytes of core data to disk...
[08:56:08] Done: 2070545 -> 1976071 (compressed to 95.4 percent)
[08:56:08]   ... Done.
[08:56:08] - Shutting down core
[08:56:08]
[08:56:08] Folding@home Core Shutdown: FINISHED_UNIT
[08:56:11] CoreStatus = 64 (100)
[08:56:11] Sending work to server
[08:56:11] Project: 4744 (Run 7, Clone 140, Gen 16)
[08:56:11] + Attempting to send results [March 7 08:56:11 UTC]
[08:56:28] + Results successfully sent
[08:56:28] Thank you for your contribution to Folding@Home.
[08:56:28] + Number of Units Completed: 341
[08:56:32] - Preparing to get new work unit...
[08:56:32] + Attempting to get work packet
[08:56:32] - Connecting to assignment server
[08:56:32] - Successful: assigned to (171.64.65.103).
[08:56:32] + News From Folding@Home: GPU folding beta
[08:56:32] Loaded queue successfully.
[08:56:33] + Closed connections
[08:56:33]
[08:56:33] + Processing work unit
[08:56:33] Core required: FahCore_11.exe
[08:56:33] Core found.
[08:56:33] Working on queue slot 05 [March 7 08:56:33 UTC]
[08:56:33] + Working ...
[08:56:34]
[08:56:34] *------------------------------*
[08:56:34] Folding@Home GPU Core - Beta
[08:56:34] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[08:56:34]
[08:56:34] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:56:34] Build host: amoeba
[08:56:34] Board Type: AMD
[08:56:34] Core      :
[08:56:34] Preparing to commence simulation
[08:56:34] - Looking at optimizations...
[08:56:34] - Created dyn
[08:56:34] - Files status OK
[08:56:34] - Expanded 88080 -> 447304 (decompressed 507.8 percent)
[08:56:34] Called DecompressByteArray: compressed_data_size=88080 data_size=447304, decompressed_data_size=447304 diff=0
[08:56:34] - Digital signature verified
[08:56:34]
[08:56:34] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:56:34]
[08:56:34] Assembly optimizations on if available.
[08:56:34] Entering M.D.
[08:56:40] Working on p4742_lam5w_300K
[08:56:40] Client config found, loading data.
[08:56:40] Starting GUI Server
[08:56:45] mdrun_gpu returned
[08:56:45] SHAKE violations on GPU
[08:56:45]
[08:56:45] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:56:48] CoreStatus = 7A (122)
[08:56:48] Sending work to server
[08:56:48] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:56:48] - Error: Could not get length of results file work/wuresults_05.dat
[08:56:48] - Error: Could not read unit 05 file. Removing from queue.
[08:56:48] - Preparing to get new work unit...
[08:56:48] + Attempting to get work packet
[08:56:48] - Connecting to assignment server
[08:56:48] - Successful: assigned to (171.64.65.103).
[08:56:48] + News From Folding@Home: GPU folding beta
[08:56:48] Loaded queue successfully.
[08:56:49] + Closed connections
[08:56:54]
[08:56:54] + Processing work unit
[08:56:54] Core required: FahCore_11.exe
[08:56:54] Core found.
[08:56:54] Working on queue slot 06 [March 7 08:56:54 UTC]
[08:56:54] + Working ...
[08:56:55]
[08:56:55] *------------------------------*
[08:56:55] Folding@Home GPU Core - Beta
[08:56:55] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[08:56:55]
[08:56:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:56:55] Build host: amoeba
[08:56:55] Board Type: AMD
[08:56:55] Core      :
[08:56:55] Preparing to commence simulation
[08:56:55] - Looking at optimizations...
[08:56:55] - Created dyn
[08:56:55] - Files status OK
[08:56:55] - Expanded 88080 -> 447304 (decompressed 507.8 percent)
[08:56:55] Called DecompressByteArray: compressed_data_size=88080 data_size=447304, decompressed_data_size=447304 diff=0
[08:56:55] - Digital signature verified
[08:56:55]
[08:56:55] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:56:55]
[08:56:55] Assembly optimizations on if available.
[08:56:55] Entering M.D.
[08:57:01] Working on p4742_lam5w_300K
[08:57:01] Client config found, loading data.
[08:57:01] Starting GUI Server
[08:57:06] mdrun_gpu returned
[08:57:06] SHAKE violations on GPU
[08:57:06]
[08:57:06] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:57:09] CoreStatus = 7A (122)
[08:57:09] Sending work to server
[08:57:09] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:57:09] - Error: Could not get length of results file work/wuresults_06.dat
[08:57:09] - Error: Could not read unit 06 file. Removing from queue.
[08:57:09] - Preparing to get new work unit...
[08:57:09] + Attempting to get work packet
[08:57:09] - Connecting to assignment server
[08:57:09] - Successful: assigned to (171.64.65.103).
[08:57:09] + News From Folding@Home: GPU folding beta
[08:57:09] Loaded queue successfully.
[08:57:10] + Closed connections
[08:57:15]
[08:57:15] + Processing work unit
[08:57:15] Core required: FahCore_11.exe
[08:57:15] Core found.
[08:57:15] Working on queue slot 07 [March 7 08:57:15 UTC]
[08:57:15] + Working ...
[08:57:16]
[08:57:16] *------------------------------*
[08:57:16] Folding@Home GPU Core - Beta
[08:57:16] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[08:57:16]
[08:57:16] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:57:16] Build host: amoeba
[08:57:16] Board Type: AMD
[08:57:16] Core      :
[08:57:16] Preparing to commence simulation
[08:57:16] - Looking at optimizations...
[08:57:16] - Created dyn
[08:57:16] - Files status OK
[08:57:16] - Expanded 88080 -> 447304 (decompressed 507.8 percent)
[08:57:16] Called DecompressByteArray: compressed_data_size=88080 data_size=447304, decompressed_data_size=447304 diff=0
[08:57:16] - Digital signature verified
[08:57:16]
[08:57:16] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:57:16]
[08:57:16] Assembly optimizations on if available.
[08:57:16] Entering M.D.
[08:57:22] Working on p4742_lam5w_300K
[08:57:22] Client config found, loading data.
[08:57:22] Starting GUI Server
[08:57:27] mdrun_gpu returned
[08:57:27] SHAKE violations on GPU
[08:57:27]
[08:57:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:57:30] CoreStatus = 7A (122)
[08:57:30] Sending work to server
[08:57:30] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:57:30] - Error: Could not get length of results file work/wuresults_07.dat
[08:57:30] - Error: Could not read unit 07 file. Removing from queue.
[08:57:30] - Preparing to get new work unit...
[08:57:30] + Attempting to get work packet
[08:57:30] - Connecting to assignment server
[08:57:30] - Successful: assigned to (171.64.65.103).
[08:57:30] + News From Folding@Home: GPU folding beta
[08:57:30] Loaded queue successfully.
[08:57:31] + Closed connections
[08:57:36]
[08:57:36] + Processing work unit
[08:57:36] Core required: FahCore_11.exe
[08:57:36] Core found.
[08:57:36] Working on queue slot 08 [March 7 08:57:36 UTC]
[08:57:36] + Working ...
[08:57:36]
[08:57:36] *------------------------------*
[08:57:36] Folding@Home GPU Core - Beta
[08:57:36] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[08:57:36]
[08:57:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:57:36] Build host: amoeba
[08:57:36] Board Type: AMD
[08:57:36] Core      :
[08:57:36] Preparing to commence simulation
[08:57:36] - Looking at optimizations...
[08:57:36] - Created dyn
[08:57:36] - Files status OK
[08:57:36] - Expanded 88080 -> 447304 (decompressed 507.8 percent)
[08:57:36] Called DecompressByteArray: compressed_data_size=88080 data_size=447304, decompressed_data_size=447304 diff=0
[08:57:36] - Digital signature verified
[08:57:36]
[08:57:36] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:57:36]
[08:57:36] Assembly optimizations on if available.
[08:57:36] Entering M.D.
[08:57:43] Working on p4742_lam5w_300K
[08:57:43] Client config found, loading data.
[08:57:43] Starting GUI Server
[08:57:47] mdrun_gpu returned
[08:57:47] SHAKE violations on GPU
[08:57:47]
[08:57:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:57:50] CoreStatus = 7A (122)
[08:57:50] Sending work to server
[08:57:50] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:57:50] - Error: Could not get length of results file work/wuresults_08.dat
[08:57:50] - Error: Could not read unit 08 file. Removing from queue.
[08:57:50] - Preparing to get new work unit...
[08:57:50] + Attempting to get work packet
[08:57:50] - Connecting to assignment server
[08:57:51] - Successful: assigned to (171.64.65.103).
[08:57:51] + News From Folding@Home: GPU folding beta
[08:57:51] Loaded queue successfully.
[08:57:52] + Closed connections
[08:57:57]
[08:57:57] + Processing work unit
[08:57:57] Core required: FahCore_11.exe
[08:57:57] Core found.
[08:57:57] Working on queue slot 09 [March 7 08:57:57 UTC]
[08:57:57] + Working ...
[08:57:57]
[08:57:57] *------------------------------*
[08:57:57] Folding@Home GPU Core - Beta
[08:57:57] Version 1.18 (Mon Oct 13 11:11:30 PDT 2008)
[08:57:57]
[08:57:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:57:57] Build host: amoeba
[08:57:57] Board Type: AMD
[08:57:57] Core      :
[08:57:57] Preparing to commence simulation
[08:57:57] - Looking at optimizations...
[08:57:57] - Created dyn
[08:57:57] - Files status OK
[08:57:57] - Expanded 88080 -> 447304 (decompressed 507.8 percent)
[08:57:57] Called DecompressByteArray: compressed_data_size=88080 data_size=447304, decompressed_data_size=447304 diff=0
[08:57:57] - Digital signature verified
[08:57:57]
[08:57:57] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:57:57]
[08:57:57] Assembly optimizations on if available.
[08:57:57] Entering M.D.
[08:58:04] Working on p4742_lam5w_300K
[08:58:04] Client config found, loading data.
[08:58:04] Starting GUI Server
[08:58:08] mdrun_gpu returned
[08:58:08] SHAKE violations on GPU
[08:58:08]
[08:58:08] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:58:11] CoreStatus = 7A (122)
[08:58:11] Sending work to server
[08:58:11] Project: 4742 (Run 8, Clone 381, Gen 7)
[08:58:11] - Error: Could not get length of results file work/wuresults_09.dat
[08:58:11] - Error: Could not read unit 09 file. Removing from queue.
[08:58:11] EUE limit exceeded. Pausing 24 hours.
planetclown wrote:I'm also seeing SHAKE violations on Project 4742 (Run 8, Clone 381, Gen 7)
Machine
XP SP3 Athlon 64 3700+, 1GB mem
Catalyst version 9.2
Folding GPU client 6.23
HD4850 folding 24/7 on stock clocks
code:
[16:44:41] *------------------------------*
[16:44:41] Folding@Home GPU Core - Beta
[16:44:41] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[16:44:41]
[16:44:41] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:44:41] Build host: amoeba
[16:44:41] Board Type: AMD
[16:44:41] Core      :
[16:44:41] Preparing to commence simulation
[16:44:41] - Looking at optimizations...
[16:44:41] - Created dyn
[16:44:41] - Files status OK
[16:44:41] - Expanded 88080 -> 447304 (decompressed 507.8 percent)
[16:44:41] Called DecompressByteArray: compressed_data_size=88080 data_size=447304, decompressed_data_size=447304 diff=0
[16:44:41] - Digital signature verified
[16:44:41]
[16:44:41] Project: 4742 (Run 8, Clone 381, Gen 7)
[16:44:41]
[16:44:41] Assembly optimizations on if available.
[16:44:41] Entering M.D.
[16:44:47] Working on p4742_lam5w_300K
[16:44:48] Client config found, loading data.
[16:44:48] Starting GUI Server
[16:44:54] mdrun_gpu returned
[16:44:54] SHAKE violations on GPU
[16:44:54]
[16:44:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:44:57] CoreStatus = 7A (122)
[16:44:57] Sending work to server
[16:44:57] Project: 4742 (Run 8, Clone 381, Gen 7)
[16:44:57] - Read packet limit of 540015616... Set to 524286976.
[16:44:57] - Error: Could not get length of results file work/wuresults_00.dat
[16:44:57] - Error: Could not read unit 00 file. Removing from queue.
[16:44:57] EUE limit exceeded. Pausing 24 hours.
[13:02:33] Service stop request received.
susato
Re: Project: 4742 (Run 8, Clone 381, Gen 7)
Post by susato »
Yikes! there must have been 200 submissions of this wu in the database dating back to October 5, 2008. :shock: :e( :eo
Marvin, thank you for reporting it here.
Without a doubt it is a horrible, terrible, no good, very bad WU - and I have reported it as such.
MtM
Post by MtM »
susato wrote:Yikes! there must have been 200 submissions of this wu in the database dating back to October 5, 2008. :shock: :e( :eo
I advised them to post it here but as they have not been online since I posted it here. No need for thanks, just trying to help :e?:
