Project: 3062 (Run 3, Clone 179, Gen 35)
Zagen30
Post by Zagen30 »
EUE'd on me:
[07:33:05] Completed 1750000 out of 5000000 steps  (35 percent)
[08:10:47] Writing local files
[08:10:47] Completed 1800000 out of 5000000 steps  (36 percent)
[08:38:25] Warning:  long 1-4 interactions
[11:25:47] At least 3 hours since checkpoint written...
[11:27:47]
[11:27:47] Folding@home Core Shutdown: EARLY_UNIT_END
[11:27:47]
[11:27:52] CoreStatus = 7B (123)
[11:27:52] Sending work to server
[11:27:52] Project: 3062 (Run 3, Clone 179, Gen 35)
susato
Re: Project: 3062 (Run 3, Clone 179, Gen 35)
Post by susato »
EUE'd on another user right before you, but at a different point in the simulation.
The preceding generation finished 2 days before the unit was assigned to you, which may indicate another failure or 'hang' (1.8 day timeout)
This report needs to be re-checked by a Mod in a couple of days; if it accumulates another EUE or two, one of the Mods will tag it as a bad WU, but it's too soon to mark it now.
As for the timeout error code (at least 3 hours...) did your machine perhaps go to sleep/standby during that time?
Also, if you get a lot of CoreStatus = 7B (123) reports, please try a memtest.
Thanks for reporting it, Zagen30.
