Project: 3064 (Run 2, Clone 355, Gen 6)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE.
[23:15:54] + Closed connections
[23:15:54]
[23:15:54] + Processing work unit
[23:15:54] Work type a1 not eligible for variable processors
[23:15:54] Core required: FahCore_a1.exe
[23:15:54] Core found.
[23:15:54] Using generic mpiexec calls
[23:15:54] Working on queue slot 07 [March 4 23:15:54 UTC]
[23:15:54] + Working ...
[23:15:54] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 2456 -version 623'
[23:15:54]
[23:15:54] *------------------------------*
[23:15:54] Folding@Home Gromacs SMP Core
[23:15:54] Version 1.74 (March 10, 2007)
[23:15:54]
[23:15:54] Preparing to commence simulation
[23:15:54] - Ensuring status. Please wait.
[23:15:55] - Starting from initial work packet
[23:15:55]
[23:15:55] Project: 3064 (Run 2, Clone 355, Gen 6)
[23:15:55]
[23:15:55] Assembly optimizations on if available.
[23:15:55] Entering M.D.
[23:16:12] 4 percent)
[23:16:12] - Starting from initial work packet
[23:16:12]
[23:16:12] Project: 3Entering M.D.
[23:16:12] one 355, Gen 6)
[23:16:12]
[23:16:12] Entering M.D.
[23:16:18] Rejecting checkpoint
[23:16:18] a SSE boost OK.
[23:16:18] ambda5_2003Extra SSE boost OK.
[23:16:18]
[23:16:18] Extra SSE boost OK.
[23:16:18] Writing local files
[23:16:18] Completed 0 out of 5000000 steps  (0 percent)
[23:20:23] - Autosending finished units... [March 4 23:20:23 UTC]
[23:20:23] Trying to send all finished work units
[23:20:23] + No unsent completed units remaining.
[23:20:23] - Autosend completed
[23:27:03] Writing local files
[23:27:03] Completed 50000 out of 5000000 steps  (1 percent)
            {snip}
[06:35:13] Writing local files
[06:35:13] Completed 2050000 out of 5000000 steps  (41 percent)
[06:45:41] Warning:  long 1-4 interactions
[06:45:41] Gromacs cannot continue further.
[06:45:41] Going to send back what have done.
[06:45:41] logfile size: 60371
[06:45:41] - Writing 60907 bytes of core data to disk...
[06:45:41]   ... Done.
[06:45:41] - Failed to delete work/wudata_07.pdo
[06:45:41] Warning:  check for stray files
[06:47:41]
[06:47:41] Folding@home Core Shutdown: EARLY_UNIT_END
[06:47:41]
[06:47:44] CoreStatus = 7B (123)
[06:47:44] Sending work to server
[06:47:44] Project: 3064 (Run 2, Clone 355, Gen 6)
[06:47:44] + Attempting to send results [March 5 06:47:44 UTC]
[06:47:44] - Reading file work/wuresults_07.dat from core
[06:47:44]   (Read 60907 bytes from disk)
[06:47:44] Connecting to http://171.64.65.63:8080/
[06:47:44] Posted data.
[06:47:45] Initial: 0000; - Uploaded at ~60 kB/s
[06:47:45] - Averaged speed for that direction ~283 kB/s
[06:47:45] + Results successfully sent
[06:47:45] Thank you for your contribution to Folding@Home.
Re: Project: 3064 (Run 2, Clone 355, Gen 6)
There is another report of EUE in the DB for this WU.
anko1
Post by anko1 »
Thanks for checking, toTOW.
