Hello,
I am having the problem that submitting the results from Project: 3858 (Run 10632, Clone 0, Gen 27) continues to fail:
[01:27:56] + Attempting to send results [March 4 01:27:56 UTC]
[01:28:17] - Couldn't send HTTP request to server
[01:28:17] + Could not connect to Work Server (results)
[01:28:17] (128.59.74.4:8080)
[01:28:17] + Retrying using alternative port
[01:28:38] - Couldn't send HTTP request to server
[01:28:38] + Could not connect to Work Server (results)
[01:28:38] (128.59.74.4:80)
[01:28:38] - Error: Could not transmit unit 01 (completed February 25) to work server.
[01:28:38] - Read packet limit of 540015616... Set to 524286976.
[01:28:38] + Attempting to send results [March 4 01:28:38 UTC]
[01:28:38] (Got status 503)
[01:28:38] (171.65.103.100:8080)
[01:28:38] + Retrying using alternative port
[01:28:38] (171.65.103.100:80)
[01:28:38] Could not transmit unit 01 to Collection server; keeping in queue.
The same client already submitted a newer result without problems ?!?
Best regards, Jorge
Project: 3858 (Run 10632, Clone 0, Gen 27) - submit results
- Hardware configuration: ASUS M2A-VM Motherboard
AMD Athlon 6000+ 64 X2 @ 3.00GHz (Stock)
nVidia GeForce 9800GT @ 650MHz GPU/950MHz Memory/1620MHz Shader (Stock)
2GB DDR2 RAM
Re: Project: 3858 (Run 10632, Clone 0, Gen 27) - submit results
http://publib.boulder.ibm.com/infocente ... 52514.html
According to that article, it looks like the collection server may possibly be down.
Eveofwar, on top of the forums is a link to 'serverstatus', think that is more up to date then an article from a 3rd party agreed
171.65.103.100 is full and bussy, 128.59.74.4 is on fail and rejecting. Nothing you can do about it tossa-fan.
2GB DDR2 RAM
Was just explaining the HTTP 503 response code =]MtM wrote:Eveofwar, on top of the forums is a link to 'serverstatus', think that is more up to date then an article from a 3rd party agreed
Yes, I know you wanted to help and it's appriciated I'm sure, but it is best done without linking to a 3rd party article when there is a direct link to a server status page don't you agree?Eveofwar wrote:Was just explaining the HTTP 503 response code =]MtM wrote:Eveofwar, on top of the forums is a link to 'serverstatus', think that is more up to date then an article from a 3rd party agreed
See official announcement here about 128.59.74.4 : viewtopic.php?f=24&t=8601
The server is still under maintenance ...
