NotFred SMP writes checkpoints?
Jonchilds
Post by Jonchilds »
Does anyone know if the NotFred SMP clients write checkpoint files to a local filesystem eg, if I ran the machine in a VM, and needed to reboot the host, would I lose any progress on the current WU?
Currently running ubuntu 8.04 and the linux6.24beta and finding it faster but I'm having issues with the wireless card which requires rebooting the system once or twice a day.
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Re: NotFred SMP writes checkpoints?
Post by MtM »
Best support for NF is given on techpowerup as the author resides there mostly. In general, if you selected the option to install to an usb drive, the checkpoints will be written there. If not, if you're using workstation/server you can suspend the vm instead of stopping it, this will also ensure it will continue from current progress. I use the last option myself, never had an issue that way. Only trouble would be if you forgot to suspend the vm and close it, or if your system would crash. In both cases no checkpoint resume is possible and a new wu will be downloaded and started.
AL2000
Hardware configuration: 1: Vista 64 - Q9450 @ 3.45 G + GTX 285 @ stock ( 3 CPU client + 1 GPU client)
2: Fedora 10 - E7400 @ 3 G - P5Q-VM
3: PS3
Post by AL2000 »
You mean TechReport instead of Techpowerup.
http://techreport.com/forums/viewtopic.php?f=9&t=53576
As i know, you have to mount a USB KEY . The work files will be writed on the USB key so if you reboot, nothing will be lost.
Instruction here: http://www.overclock.net/overclock-net- ... are-w.html
2: Fedora 10 - E7400 @ 3.2 G - P5Q-VM
3: PS3
MtM
Post by MtM »
Thanks for the correction, you're right :oops:
As I said, suspending the vm will also work.
bollix47
Post by bollix47 »
notfred's most recent thread is located via the following link:
http://techreport.com/forums/viewtopic.php?f=9&t=64562
MtM
Post by MtM »
Hey great, temperature monitoring is added, hallaluja! :)
codysluder
Post by codysluder »
AL2000 wrote:As i know, you have to mount a USB KEY . The work files will be writed on the USB key so if you reboot, nothing will be lost.
I've used the version of NF that boots from a USB key rather than running in a VM. I think that I need to use a second USB key to provide a place for the work files to be stored but I've never done that. When I reboot, I do lose the current WU (which I'm not happy about) but a second key sounds like something I could/should do.
Does anybody know if this is correct?
bollix47
Post by bollix47 »
I only use a single USB on one of my computers and as long as I don't stop the computer while it's writing to the USB when I restart it does continue on from where it left off. I use 2GB USB sticks but it should work with less. Certainly no need for a second one.
codysluder
Thanks bollix47
patonb
Post by patonb »
The vmware does write to the vmware disk.
I've used it in vmware for over a month.
Jonchilds
Post by Jonchilds »
patonb: Do you find that the VMWare client makes certain tasks within the windows desktop environment lag?
It seems like the VMWare processes have a slightly higher priority than the standard FAH clients/cores...
Veix
Post by Veix »
open taskmanager and set vmware-vmx.exe priority from normal to low.... It will stay that way until you pause vmware or restart it.
kiore
Post by kiore »
Well I run this without a usb drive, and stop and start without losing work, when I restart it nearly always restarts from the last checkpoint, only time that hasn't happened was when another process caused the system to crash, power cuts didn't do it.
kiore.
