Stopping at end of WU
Tom_te_tom_te_tom
Post by Tom_te_tom_te_tom »
I've got a 2 machines* running FAH I want to upgrade and was wondering how to set it so it stops after the uploading the results of the current WU?
* One W2K - going to Kubuntu so complete wipe..
One Suse10.3 which may survive a change to Kubuntu but may not...
noorman
Hardware configuration: Folders: Intel C2D E6550 @ 3.150 GHz + GPU XFX 9800GTX+ @ 765 MHZ w. WinXP-GPU
AMD A2X64 3800+ @ stock + GPU XFX 9800GTX+ @ 775 MHZ w. WinXP-GPU
Main rig: an old Athlon Barton 2500+ @2.25 GHz & 2* 512 MB RAM Apacer, Radeon 9800Pro, WinXP SP3+
Location: Belgium, near the International Sea-Port of Antwerp
Re: Stopping at end of WU
Post by noorman »
You need to stop the Client and restart it with the -oneunit switch added.
This will indicate to the Client that you want it to finish the WU, you want it sent and you want no new job downloaded.
After this is done, the lient will exit/shutdown itself ... :)
- stopped Linux SMP w. HT on i7-860@3.5 GHz
Folded since 10-06-04 till 09-2010
vossron
Post by vossron »
How do I do this with the Mac System Preferences FAH control pane? If I click "Stop Folding@home" it stops immediately. I'm willing to let it finish the current WU, but then I want to stop due to Leopard no longer honoring -nice.
Can someone get John Hennessy to call Steve Jobs to put pressure on someone to put support for -nice back into 10.5.x?
