Unable to connect to work server, project 2526
project 2526 (run 39, clone 63, gen 14)
it said it put it in the queue and would attempt to send, what could be stopping the sending.
tyvm
tyvm
Re: Unable to connect to work server, project 2526
Welcome to the foldingform, Fixitomg.
Please post your FAHlog.txt file, so we have a bit more information to help you with.
Just a guess, but some of the work servers as well as the collection servers have been having issues over the last few days.
This situation should be corrected tomorrow morning, or shortly there after, but we have to wait for the Pande Group to return from the weekend.
As long as it placed the WU in your queue, the client will continue trying (every six hours) to send the unit in until it is successfully uploaded.
In the interim, it would help if you would post the contents of your FHAlog.txt here, so we can see if there is any other possible reason for it not sending.
Edit: Upon further inspection 2526 is from server 171.64.122.136. Please see this post. >> viewtopic.php?f=18&t=8688
-=MB=-
ummm i cant exactly find the fah log file. i had the fah in zip form that's the one that completed 2526, when i extracted all it wanted me to restart(user name , team id) , so i didn't get rid of the zipped because it has the other file completed.
aslo a question does fah use the temporary files? and if so will cleaning the cache destroy all completed work thus far?
just wondering i havent cleaned it and its starting to get full(buggin me):P. anyway how do i get them on the same unzipped folder?
tyvm sry for the problems and questions
o hey i just found that in the program properties that that windows blocked it, that may be it
woot it just successfully sent but still need to switch over any ideas
If you need to change username and team, just start the client with -config to start with the config options again, or -configonly to configure and exit. Is that what you mean?
eg
replace location and executable with the proper paths. Alternatively, delete client.cfg and starting the client will archieve the same thing.
eg
...\folding location\folding.exe -config
I think they mean that they want all the client files in one folder.
Not sure why they are zipping things up though, unless transferring it somewhere?
What client are they running.
And NO FAH FILES go into your computers chached dirs., so you can clean them as you wish.
-=MB=-
Ahh he downloaded the deino zip package I think which would be the zip file he is talking about.MstrBlstr wrote:I think they mean that they want all the client files in one folder.
I think he is asking how to get the work folder in the same location as the executable as opposed to the appdata location as well.
If I'm right Fixitomg, you could use -local to force the client to look for the work folder at the executable's startup path. Copy the workfolder from appdata to not loose anything of value there ( though if you exited the client after it uploaded the wu it finished and before it downloaded a new one you could skip this as well it's pretty hard to time that manually so I'm assuming you didn't ).
The current location should be users\*account name*\appdata\local\fah\ depending on operating system.
ok heres what i did i found the folder for the zipped and the unzipped, i deleted the zipped client thingy and replaced with the unzipped one
then i took all the files out of the unzipped one place in the docs and settings/local directory. after deleting all the zipped files except the zipped work file which i deleted the unzipped and replaced. hard to understand im even lost but its now workin on 4447 and said it sent in 2526 how could i check to make sure? i still have a queue file that is 7kb, the work folder has files with 01 and 02 in them does that mean on on 2 atm? i just need 1
ok nvm i figured it out i read the info logs 01 and 02 and yes i got 2 projects going is this gana be a problem or will it finish one then to the other? i got projects 4455 and 4447 now
lol sry i tend to answer some of my questions im a weird one
ummm ha where do i find my team and ppl in my team 160158 that completed work? we are having a in team race. and i still need to know if having 2 projects at the same time will mess anything up. sry bout the confusion on my last post
http://folding.extremeoverclocking.com/team_list.php?s=
http://folding.stanford.edu/stats.html
First is EOC, I think it's easier and it has more graphs
Second is official stats.
Search for your team ( either name or number ) or your username.
The work folder is best left alone
There will be some files which the client doesn't delete, but their small and of no importance ( unless something goes wrong but fahlog would show that ). If you really need to mess with it, the number on the end indicates the slot the files belong to. Never touch files from the current active slot ( it's listed in fahlog.txt as 'currently processing slot x' ), and never touch files with the words wuresult in them ( these are completed projects which needs to be uploaded. After upload they will be removed automaticly ). Other files are dismisable but like I said they are mostly text files which are a few kb at max. Not worth cleaning them out.
Still not sure what you mean with most of what you type btw, maybe if you asked someone from your team to help you out?
the members from my team wouldn't know they use the visual version, i tried to use that one and it had a solid black background and didn't do much and when i checked after a few days nothing was done, it just wasted time 0% done. so i switched to the console version at least i can see progress. any idea why the visual one didn't work i have a 10 GB hard drive with 2 GB free (temporary mind you) and 512 Mb ram. CPU is a Pentium 4 idk how fast that is and graphics card is a ati catalyst R again not sure speed on that. ty for the links but i still have no idea how to check them can u be more specific? i already downloaded both of them but when i try to open it cant find right program to view. that was the 2nd link i got. my teams not on the 1st link.
lol i feel stupid now sry bout that i found the team stats
