Can't connect to 171.67.108.25 & assign2.stanford.edu
rahein
503 when contacting server
Post by rahein »
MacPro, all updates,
Edited client info after first line...
Feb 23 10:36:03 Man-G10-H00563 edu.stanford.folding.client[716]: --- Opening Log file [February 23 10:36:03 UTC]
Feb 23 10:36:03 # Mac OS X SMP Console Edition ################################################
Feb 23 10:36:03 ###############################################################################
Feb 23 10:36:03                         Folding@Home Client Version 6.20
Feb 23 10:36:03                          (edit to remove link) folding.stanford.edu
Feb 23 10:36:03 Man-G10-H00563 edu.stanford.folding.client[716]: Launch directory: /Users/ladmin/Library/Folding@home
Feb 23 10:36:03  Executable: /Applications/Folding@home.app/fah6
Feb 23 10:36:03  [10:36:03] - Ask before connecting: No
Feb 23 10:36:03  [10:36:03] - Proxy: (correctproxy&port)
Feb 23 10:36:03  [10:36:03] - User name: rahein (Team 158735)
Feb 23 10:36:03 [10:36:03] - User ID: 141DD8AB6FB703B2
Feb 23 10:36:03 [10:36:03] - Machine ID: 1
Feb 23 10:36:03 {10:36:03] Loaded queue successfully.
Feb 23 10:36:03 [10:36:03] - Preparing to get new work unit...
Feb 23 10:36:03[10:36:03] + Attempting to get work packet
Feb 23 10:36:03 [10:36:03] - Connecting to assignment server
Feb 23 10:36:14 [10:36:14] - Successful: assigned to (171.64.65.63).
Feb 23 10:36:14 [10:36:14] + News From Folding@Home: Welcome to Folding@Home
Feb 23 10:36:14 [10:36:14] Loaded queue successfully.
Feb 23 10:36:14  [10:36:14] - Couldn't send HTTP request to server
Feb 23 10:36:14 [10:36:14]   (Got status 503)
Feb 23 10:36:14 [10:36:14] + Could not connect to Work Server
Feb 23 10:36:14  [10:36:14] - Attempt #1  to get work failed, and no other work to do.
Feb 23 10:36:14 Man-G10-H00563 edu.stanford.folding.client[716]: Waiting before retry.
And that's it - loops there, then after 6 tries changed server to Successful: assigned to (171.64.65.56) and returned(Got status 500)
Rick
susato
Re: 503 when contacting server
Post by susato »
Hi rahein - Welcome to the forum and thanks for posting. What you've seen here is the assignment server making sure you have work for your Mac Pro even when the regular server for it was unresponsive.
Here's what happened: your Mac Pro, with either 4 or 8 cores Folding, was identified as a quad-plus machine by the assignment server (the "queue loaded successfully" line which directed it to get a work unit from work server 171.64.65.63 (which provisions mainly quad and higher-plex Linux and OSX folding rigs). However, this server was either down or busy and did not respond. After several unsuccessful tries, the AS caught on that you were not getting anywhere with the original server, so it sent you to server 171.64.65.56 (which serves mostly OSX and Linux dual core SMP folding rigs) where you picked up a work unit- presumably a small work unit best suited for a duallie. The AS wants to keep all donors supplied with work so when the original work server is unreachable it goes through a flowchart of alternatives to find the most suitable work unit for you and assign it to you.
I looked at the server logs and found a net load of 200 (very high) on that server at the time you were trying to reach it.
Your machine should go back to the 171.64.65.63 or 171.67.108.24 server after finishing the current WU.
Thanks for Folding - I hope to read more of your posts here on the forum.
rahein
Post by rahein »
Any sign of my presence? Been running for eight hours and in the last hour it looks to me like two out of six requests got work.
23/02/2009 15:35:51 edu.stanford.folding.client[49] [15:35:51] + Attempting to get work packet
23/02/2009 15:35:51 edu.stanford.folding.client[49] [15:35:51] - Connecting to assignment server
23/02/2009 15:37:06 edu.stanford.folding.client[49] [15:37:06] - Couldn't send HTTP request to server
23/02/2009 15:37:06 edu.stanford.folding.client[49] [15:37:06] + Could not connect to Assignment Server
23/02/2009 15:38:21 edu.stanford.folding.client[49] [15:38:21] - Couldn't send HTTP request to server
23/02/2009 15:38:21 edu.stanford.folding.client[49] [15:38:21] + Could not connect to Assignment Server 2
23/02/2009 15:38:21 edu.stanford.folding.client[49] [15:38:21] + Couldn't get work instructions.
23/02/2009 15:38:21 edu.stanford.folding.client[49] [15:38:21] - Attempt #17  to get work failed, and no other work to do.
23/02/2009 15:38:21 edu.stanford.folding.client[49] Waiting before retry.
23/02/2009 15:42:27 edu.stanford.folding.client[1257] [15:42:27] + Attempting to get work packet
23/02/2009 15:42:27 edu.stanford.folding.client[1257] [15:42:27] - Will indicate memory of 4096 MB
23/02/2009 15:42:27 edu.stanford.folding.client[1257] [15:42:27] - Connecting to assignment server
23/02/2009 15:42:27 edu.stanford.folding.client[1257] [15:42:27] Connecting to http://assign.stanford.edu:8080/
23/02/2009 15:42:37 edu.stanford.folding.client[1257] [15:42:37] Posted data.
23/02/2009 15:42:37 edu.stanford.folding.client[1257] [15:42:37] Initial: 40AB;
23/02/2009 15:42:37 edu.stanford.folding.client[1257] - Successful: assigned to (171.64.65.63).
23/02/2009 15:42:37 edu.stanford.folding.client[1257] [15:42:37] + News From Folding@Home: Welcome to Folding@Home
23/02/2009 15:42:37 edu.stanford.folding.client[1257] [15:42:37] Loaded queue successfully.
23/02/2009 15:42:37 edu.stanford.folding.client[1257] [15:42:37] Connecting to http://171.64.65.63:8080/
23/02/2009 15:42:38 edu.stanford.folding.client[1257] [15:42:38] - Couldn't send HTTP request to server
23/02/2009 15:42:38 edu.stanford.folding.client[1257] [15:42:38]   (Got status 503)
23/02/2009 15:42:38 edu.stanford.folding.client[1257] [15:42:38] + Could not connect to Work Server
23/02/2009 15:42:38 edu.stanford.folding.client[1257] [15:42:38] - Attempt #13  to get work failed, and no other work to do.
23/02/2009 15:42:38 edu.stanford.folding.client[1257] Waiting before retry.
23/02/2009 16:26:34 edu.stanford.folding.client[49] [16:26:34] + Attempting to get work packet
23/02/2009 16:26:34 edu.stanford.folding.client[49] [16:26:34] - Connecting to assignment server
23/02/2009 16:27:49 edu.stanford.folding.client[49] [16:27:49] - Couldn't send HTTP request to server
23/02/2009 16:27:49 edu.stanford.folding.client[49] [16:27:49] + Could not connect to Assignment Server
23/02/2009 16:29:04 edu.stanford.folding.client[49] [16:29:04] - Couldn't send HTTP request to server
23/02/2009 16:29:04 edu.stanford.folding.client[49] [16:29:04] + Could not connect to Assignment Server 2
23/02/2009 16:29:04 edu.stanford.folding.client[49] [16:29:04] + Couldn't get work instructions.
23/02/2009 16:29:04 edu.stanford.folding.client[49] [16:29:04] - Attempt #18  to get work failed, and no other work to do.
23/02/2009 16:29:04 edu.stanford.folding.client[49] Waiting before retry.
23/02/2009 16:30:49 edu.stanford.folding.client[1257] [16:30:49] + Attempting to get work packet
23/02/2009 16:30:49 edu.stanford.folding.client[1257] [16:30:49] - Will indicate memory of 4096 MB
23/02/2009 16:30:49 edu.stanford.folding.client[1257] [16:30:49] - Connecting to assignment server
23/02/2009 16:30:49 edu.stanford.folding.client[1257] [16:30:49] Connecting to http://assign.stanford.edu:8080/
23/02/2009 16:30:59 edu.stanford.folding.client[1257] [16:30:59] Posted data.
23/02/2009 16:30:59 edu.stanford.folding.client[1257] [16:30:59] Initial: 40AB;
23/02/2009 16:30:59 edu.stanford.folding.client[1257] - Successful: assigned to (171.64.65.63).
23/02/2009 16:30:59 edu.stanford.folding.client[1257] [16:30:59] + News From Folding@Home: Welcome to Folding@Home
23/02/2009 16:31:00 edu.stanford.folding.client[1257] [16:31:00] Loaded queue successfully.
23/02/2009 16:31:00 edu.stanford.folding.client[1257] [16:31:00] Connecting to http://171.64.65.63:8080/
23/02/2009 16:31:00 edu.stanford.folding.client[1257] [16:31:00] - Couldn't send HTTP request to server
23/02/2009 16:31:00 edu.stanford.folding.client[1257] [16:31:00]   (Got status 503)
23/02/2009 16:31:00 edu.stanford.folding.client[1257] [16:31:00] + Could not connect to Work Server
23/02/2009 16:31:00 edu.stanford.folding.client[1257] [16:31:00] - Attempt #14  to get work failed, and no other work to do.
In Activity Monitor it looks like I've got two FaH 6 processes running, taking up 0% of CPU.
Rick
susato
Post by susato »
You're right - something is wrong. The only work unit listed as completed by rahein was back on January 29.
You appear to have two different Folding clients running, one with process ID 1257, the other with process ID 49. Do they show up in the System Preferences panel as two different icons? When you configured them, did you place them in different folders or assign different machine ID's? When two instances have the same machine ID, or when they try to operate on the same work folder, the interference can crash the work units, forcing them to start over.
I suggest that you kill both processes from Activity Monitor and then start up one of them only, and see what happens.
Is your Mac Pro a quad core or a dual quad core? If a quad core, then there is no need to run two instances of Folding.
If it's a dual quad, maxing out your CPU will require two instances, and I think you will need to run at least one of those instances from the Console.
rahein
Post by rahein »
Thanks. I turned off the Folding in the one pref pane installed, then I killed, killed again, and they kept on coming!
Restarted, and I appear to be running one process, Gromacs, on four instances of FahCOre_a2.exe
IF you can check to see that I'm "online", then I can let the machine idle in peace...
Thank you!
Rick
There isn't any way to check if you're online; only you can do that.
The FAH client contacts the servers to get an initial work assignment (WU) and the software to process it (FahCore_xx.exe). Then there is no communications until the WU is finished. From the server's perspective, it can't tell whether you're processing something or you've shut down your machine. (Well, that's not 100% true. I will eventually know the total time between downloading the WU and uploading the results.)
rahein
Post by rahein »
My bad. REalised it just after I hit enter. My stas have been updated, so everything must be prety hunky dory.
Thanks!
Rick
rahein
Post by rahein »
Back again - problems posting results:
[10:26:03] - Autosending finished units... [February 25 10:26:03 UTC]
[10:26:03] Trying to send all finished work units
[10:26:03] Project: 2669 (Run 12, Clone 178, Gen 74)
[10:26:03] + Attempting to send results [February 25 10:26:03 UTC]
[10:26:03] - Reading file work/wuresults_03.dat from core
[10:26:03]   (Read 26003962 bytes from disk)
[10:26:03] Connecting to http://171.64.65.56:8080/
[10:27:18] - Couldn't send HTTP request to server
[10:27:18] + Could not connect to Work Server (results)
[10:27:18]     (171.64.65.56:8080)
[10:27:18] + Retrying using alternative port
[10:27:18] Connecting to http://171.64.65.56:80/
[10:27:31] + Attempting to get work packet
[10:27:31] - Will indicate memory of 4096 MB
[10:27:31] - Connecting to assignment server
[10:27:31] Connecting to http://assign.stanford.edu:8080/
[10:28:33] - Couldn't send HTTP request to server
[10:28:33] + Could not connect to Work Server (results)
[10:28:33]     (171.64.65.56:80)
[10:28:33] - Error: Could not transmit unit 03 (completed February 24) to work server.
[10:28:33] - 5 failed uploads of this unit.
[10:28:33] + Attempting to send results [February 25 10:28:33 UTC]
[10:28:33] - Reading file work/wuresults_03.dat from core
[10:28:33]   (Read 26003962 bytes from disk)
[10:28:33] Connecting to http://171.67.108.25:8080/
[10:28:46] - Couldn't send HTTP request to server
[10:28:46] + Could not connect to Assignment Server
[10:28:46] Connecting to http://assign2.stanford.edu:80/
susato
Post by susato »
That server was down for some time last night, coming back up between 2 and 3 am EST. It seems to be rather busy (CPU load) now.
The thing to do in a case like this is to check the server stats page and to post any apparent problems with the server to the "Issues with a specific server" section of the forum, where you will find threads for each of the servers.
To force upload of a completed unit, and/or a download of new work, you might try stopping and restarting the client, because the first thing the client does when restarted is to try to contact Stanford. One caveat when doing so is that the FahCore processes sometimes take as long as 3-5 minutes to terminate after you stop the client. So it's only safe to restart right after stopping, when that client isn't folding anything. If you look in the thread on 171.64.65.56 in the server issues sub-forum, you'll see the discussion from last night... and the work unit I (oops) trashed by mistake by not following my own advice.
rahein
Post by rahein »
8 hours - no connections - since 2:30 zulu I've had this, with the port variations
171.67.108.25:8080 - Couldn't send HTTP Request to server
assign2.stanford.edu:80  - Couldn't send HTTP Request to server  - also on :8080
[14:29:07] - Couldn't send HTTP request to server
[14:29:07] + Could not connect to Work Server (results)
[14:29:07]     (171.67.108.25:8080)
[14:29:07] + Retrying using alternative port
[14:29:07] Connecting to http://171.67.108.25:80/
[14:29:43] - Couldn't send HTTP request to server
[14:29:43] + Could not connect to Assignment Server 2
[14:29:43] + Couldn't get work instructions.
ending today with
[16:59:09] + Attempting to get work packet
[16:59:09] - Will indicate memory of 4096 MB
[16:59:09] - Connecting to assignment server
[16:59:09] Connecting to http://assign.stanford.edu:8080/
[17:00:24] - Couldn't send HTTP request to server
[17:00:24] + Could not connect to Assignment Server
[17:00:24] Connecting to http://assign2.stanford.edu:80/
[17:01:39] - Couldn't send HTTP request to server
[17:01:39] + Could not connect to Assignment Server 2
[17:01:39] + Couldn't get work instructions.
[17:01:39] - Attempt #19  to get work failed, and no other work to do.
When I enter 171.67.108.25:8080 or 171.67.108.25:80 in the browser I get "OK". When the System PReferences Client tries, it gets nowhere.
rahein
Post by rahein »
Since 8:30 zulu, o connections -
Since 14:30 zulu I've had this, with the port variations
ending today with
When I enter 171.67.108.25:8080 or 171.67.108.25:80 in the browser I get "OK". When the Mac OSX System Preferences Client tries, it gets nowhere. MacPro all uptodate.
Rick
Re: Can't connect to 171.67.108.25 & assign2.stanford.edu
I think there is a thread about this server already... http://foldingforum.org/viewtopic.php?f=18&t=7884
And another thread about the connection errors here: http://foldingforum.org/viewtopic.php?f ... 0&start=15
Edited by susato, 5 Mar 2009 to change 2nd URL after "another thread about the connection errors" was merged into
this thread.
rahein wrote:[16:59:09] - Connecting to assignment server
Click on those two URLs in your browser. I get a page containing "OK" from both of them.
If you do get the OK, your connection is good and something local (such as security software) must be blocking the connection.
If you do NOT get the OK, it's probably your connection, although one server might be down. [I don't remember the last time either of them was down.]
rahein
Post by rahein »
When I click on the links, niothing appears and after 45 seconds the window closes and a file is downloaded, not displayed with the contents "OK".
RIck
rahein
Post by rahein »
Sorry, I could find no problem other than my own post about connecting to assign2 and another server at the same time.
rant
Thanks for referring me back to myself.
This is frustrating. There are errors. They need to get fixed. No one is fixing them. I can't do it from my end.
It's great to have a distributed project, but it is hard to get involved when the system doesn't work and hardware that could be helping is better switched off because it is doing just as much work for the project while shut down and saving energy in the process.
/rant
Off to post the same info for the third time....maybe a solution will arise - it's another 16 hours of console report filled with "Could not ../send http request, connect. retrying, could not send, could not connect." Guess I should just shut down the client, wait a week, and see if anything has changed.
Rick
