assign.stanford.edu:8080/ - Connect Failures
brityank
Post by brityank »
Seem to be having the devil of a time picking up a new WU:
[23:40:08] Completed 1485000 out of 1500000 steps  (99%)
[23:48:18] - Autosending finished units... [February 24 23:48:18 UTC]
[23:48:18] Trying to send all finished work units
[23:48:18] + No unsent completed units remaining.
[23:48:18] - Autosend completed
[23:55:08] Timered checkpoint triggered.
[00:00:27] Writing local files
[00:00:27] Completed 1500000 out of 1500000 steps  (100%)
[00:00:27] Writing final coordinates.
[00:00:27] Past main M.D. loop
[00:01:27]
[00:01:27] Finished Work Unit:
[00:01:27] - Reading up to 188856 from "work/wudata_09.arc": Read 188856
[00:01:27] - Reading up to 17888 from "work/wudata_09.xtc": Read 17888
[00:01:27] goefile size: 0
[00:01:27] logfile size: 59632
[00:01:27] Leaving Run
[00:01:30] - Writing 273380 bytes of core data to disk...
[00:01:30] Done: 272868 -> 209845 (compressed to 76.9 percent)
[00:01:30]   ... Done.
[00:01:30] - Shutting down core
[00:01:30]
[00:01:30] Folding@home Core Shutdown: FINISHED_UNIT
[00:01:34] CoreStatus = 64 (100)
[00:01:34] Unit 9 finished with 98 percent of time to deadline remaining.
[00:01:34] Updated performance fraction: 0.981927
[00:01:34] Sending work to server
[00:01:34] Project: 4441 (Run 738, Clone 3, Gen 9)
[00:01:34] + Attempting to send results [February 25 00:01:34 UTC]
[00:01:34] - Reading file work/wuresults_09.dat from core
[00:01:34]   (Read 210357 bytes from disk)
[00:01:34] Connecting to http://171.67.108.13:8080/
[00:01:40] Posted data.
[00:01:41] Initial: 0000; - Uploaded at ~29 kB/s
[00:01:41] - Averaged speed for that direction ~33 kB/s
[00:01:41] + Results successfully sent
[00:01:41] Thank you for your contribution to Folding@Home.
[00:01:41] + Number of Units Completed: 293
[00:01:45] Trying to send all finished work units
[00:01:45] + No unsent completed units remaining.
[00:01:45] - Preparing to get new work unit...
[00:01:45] + Attempting to get work packet
[00:01:45] - Will indicate memory of 1536 MB
[00:01:45] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[00:01:45] - Connecting to assignment server
[00:01:45] Connecting to http://assign.stanford.edu:8080/
[00:01:46] Posted data.
[00:01:46] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[00:01:46] + Couldn't get work instructions.
[00:01:46] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
 by ~ by ~ by ~ by ~ by ~ by ~ by ~ by ~ by ~ by ~ snipped ~ by ~ by ~ by ~ by ~ by
                       Folding@Home Client Version 6.20
                          http://folding.stanford.edu
Launch directory: C:\F@H6
Executable: C:\F@H6\Folding@home-Win32-x86.exe
Arguments: -local -verbosity 9
[03:48:08] - Ask before connecting: No
[03:48:08] - User name: brityank (Team 36120)
[03:48:08] - User ID: 3B5FF3DF58448207
[03:48:08] - Machine ID: 1
[03:48:08]
[03:48:08] Loaded queue successfully.
[03:48:08] - Preparing to get new work unit...
[03:48:08] - Autosending finished units... [February 25 03:48:08 UTC]
[03:48:08] + Attempting to get work packet
[03:48:08] Trying to send all finished work units
[03:48:08] - Will indicate memory of 1536 MB
[03:48:08] + No unsent completed units remaining.
[03:48:08] - Autosend completed
[03:48:08] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[03:48:08] - Connecting to assignment server
[03:48:08] Connecting to http://assign.stanford.edu:8080/
[03:48:09] Posted data.
[03:48:09] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:48:09] + Couldn't get work instructions.
[03:48:09] - Attempt #1  to get work failed, and no other work to do.
[03:48:21] + Attempting to get work packet
[03:48:21] - Will indicate memory of 1536 MB
[03:48:21] - Connecting to assignment server
[03:48:21] Connecting to http://assign.stanford.edu:8080/
[03:48:21] Posted data.
[03:48:21] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:48:21] + Couldn't get work instructions.
[03:48:21] - Attempt #2  to get work failed, and no other work to do.
[03:48:44] + Attempting to get work packet
[03:48:44] - Will indicate memory of 1536 MB
[03:48:44] - Connecting to assignment server
[03:48:44] Connecting to http://assign.stanford.edu:8080/
[03:48:45] Posted data.
[03:48:45] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:48:45] + Couldn't get work instructions.
[03:48:45] - Attempt #3  to get work failed, and no other work to do.
[03:49:08] + Attempting to get work packet
[03:49:08] - Will indicate memory of 1536 MB
[03:49:08] - Connecting to assignment server
[03:49:08] Connecting to http://assign.stanford.edu:8080/
[03:49:09] Posted data.
[03:49:09] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:49:09] + Couldn't get work instructions.
[03:49:09] - Attempt #4  to get work failed, and no other work to do.
[03:49:49] + Attempting to get work packet
[03:49:49] - Will indicate memory of 1536 MB
[03:49:49] - Connecting to assignment server
[03:49:49] Connecting to http://assign.stanford.edu:8080/
[03:49:49] Posted data.
[03:49:49] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:49:49] + Couldn't get work instructions.
[03:49:49] - Attempt #5  to get work failed, and no other work to do.
[03:51:18] + Attempting to get work packet
[03:51:18] - Will indicate memory of 1536 MB
[03:51:18] - Connecting to assignment server
[03:51:18] Connecting to http://assign.stanford.edu:8080/
[03:51:19] Posted data.
[03:51:19] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:51:19] + Couldn't get work instructions.
[03:51:19] - Attempt #6  to get work failed, and no other work to do.
[03:54:01] + Attempting to get work packet
[03:54:01] - Will indicate memory of 1536 MB
[03:54:01] - Connecting to assignment server
[03:54:01] Connecting to http://assign.stanford.edu:8080/
[03:54:02] Posted data.
[03:54:02] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:54:02] + Couldn't get work instructions.
[03:54:02] - Attempt #7  to get work failed, and no other work to do.
[03:59:33] + Attempting to get work packet
[03:59:33] - Will indicate memory of 1536 MB
[03:59:33] - Connecting to assignment server
[03:59:33] Connecting to http://assign.stanford.edu:8080/
[03:59:33] Posted data.
[03:59:33] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[03:59:33] + Couldn't get work instructions.
[03:59:33] - Attempt #8  to get work failed, and no other work to do.
[04:10:22] + Attempting to get work packet
[04:10:22] - Will indicate memory of 1536 MB
[04:10:22] - Connecting to assignment server
[04:10:22] Connecting to http://assign.stanford.edu:8080/
[04:10:23] Posted data.
[04:10:23] Initial: 43AB; - Successful: assigned to (171.67.108.13).
[04:10:23] + News From Folding@Home: Welcome to Folding@Home
[04:10:23] Loaded queue successfully.
[04:10:23] Connecting to http://171.67.108.13:8080/
[04:10:23] Initial: 0000; + Could not connect to Work Server
[04:10:23] - Attempt #9  to get work failed, and no other work to do.
[04:31:57] + Attempting to get work packet
[04:31:57] - Will indicate memory of 1536 MB
[04:31:57] - Connecting to assignment server
[04:31:57] Connecting to http://assign.stanford.edu:8080/
[04:31:58] Posted data.
[04:31:58] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[04:31:58] + Couldn't get work instructions.
[04:31:58] - Attempt #10  to get work failed, and no other work to do.
I shut the instance down, and took care of a couple of other things, then restarted it again, twice; the first time (at thetop) it went 12 tries before I shut down. The second I let run 7 times, then shut down and wited a while. My third start is still running, or should I say waiting.
Pings to all of the servers, either with Ports 8080 or 80 all come back OK. However, a tracert shows two or sometimes three nodes that fail to respond and show 100% packet loss within the Stanford server complex.
Is this related to the server problems from earlier in the week, or something else hanging fire?
... ... Free Republic Folders - A Tribute to Ronald Reagan ... ...
Re: assign.stanford.edu:8080/ - Connect Failures
There are two things you could try : fist upgrade your client to 6.23, it will prevent further issues. Then, you could try to change your settings (add -advmethods, change the preferred WU size, change the reporter memory amount).
