Project 4756 - Run 7, Clone 39, Gen 5
Biskquik
Post by Biskquik »
I've been running the GPU2 client for about a week now since I replaced the cooler on my 4850. It seems that I am getting NaNs on this specific WU causing an Unstable_Machine and eventual pause.
Just going to show my last WU finishing without any issues and the immediate Unstable_Machines on this specific project
[22:50:12] *------------------------------*
[22:50:12] Folding@Home GPU Core - Beta
[22:50:12] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[22:50:12]
[22:50:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[22:50:12] Build host: amoeba
[22:50:12] Board Type: AMD
[22:50:12] Core      :
[22:50:12] Preparing to commence simulation
[22:50:12] - Looking at optimizations...
[22:50:12] - Created dyn
[22:50:12] - Files status OK
[22:50:12] - Expanded 98614 -> 492188 (decompressed 499.1 percent)
[22:50:12] Called DecompressByteArray: compressed_data_size=98614 data_size=492188, decompressed_data_size=492188 diff=0
[22:50:12] - Digital signature verified
[22:50:12]
[22:50:12] Project: 5732 (Run 3, Clone 30, Gen 90)
[22:50:12]
[22:50:12] Assembly optimizations on if available.
[22:50:12] Entering M.D.
[22:50:18] Working on Protein
[22:50:18] Client config found, loading data.
[22:50:18] Starting GUI Server
[22:53:38] Completed 1%
[22:56:55] Completed 2%
...SNIP...
[04:12:08] Completed 98%
[04:15:24] Completed 99%
[04:18:53] Completed 100%
[04:18:53] Successful run
[04:18:53] DynamicWrapper: Finished Work Unit: sleep=10000
[04:19:03] Reserved 219076 bytes for xtc file; Cosm status=0
[04:19:03] Allocated 219076 bytes for xtc file
[04:19:03] - Reading up to 219076 from "work/wudata_04.xtc": Read 219076
[04:19:03] Read 219076 bytes from xtc file; available packet space=786211388
[04:19:03] xtc file hash check passed.
[04:19:03] Reserved 33528 33528 786211388 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[04:19:03] Allocated 33528 bytes for arc file
[04:19:03] - Reading up to 33528 from "work/wudata_04.trr": Read 33528
[04:19:03] Read 33528 bytes from arc file; available packet space=786177860
[04:19:03] trr file hash check passed.
[04:19:03] Allocated 560 bytes for edr file
[04:19:03] Read bedfile
[04:19:03] edr file hash check passed.
[04:19:03] Allocated 51124 bytes for logfile
[04:19:03] Read logfile
[04:19:03] GuardedRun: success in DynamicWrapper
[04:19:03] GuardedRun: done
[04:19:03] Run: GuardedRun completed.
[04:19:07] - Writing 304800 bytes of core data to disk...
[04:19:07] Done: 304288 -> 263856 (compressed to 86.7 percent)
[04:19:07]   ... Done.
[04:19:07] - Shutting down core
[04:19:07]
[04:19:07] Folding@home Core Shutdown: FINISHED_UNIT
[04:19:10] CoreStatus = 64 (100)
[04:19:10] Sending work to server
[04:19:10] Project: 5732 (Run 3, Clone 30, Gen 90)
[04:19:10] - Read packet limit of 540015616... Set to 524286976.
[04:19:10] + Attempting to send results [February 24 04:19:10 UTC]
[04:19:16] + Results successfully sent
[04:19:16] Thank you for your contribution to Folding@Home.
[04:19:16] + Number of Units Completed: 24
[04:19:20] - Preparing to get new work unit...
[04:19:20] + Attempting to get work packet
[04:19:20] - Connecting to assignment server
[04:19:20] - Successful: assigned to (171.64.65.103).
[04:19:20] + News From Folding@Home: GPU folding beta
[04:19:20] Loaded queue successfully.
[04:19:21] + Closed connections
[04:19:21]
[04:19:21] + Processing work unit
[04:19:21] Core required: FahCore_11.exe
[04:19:21] Core found.
[04:19:21] Working on queue slot 05 [February 24 04:19:21 UTC]
[04:19:21] + Working ...
[04:19:21]
[04:19:21] *------------------------------*
[04:19:21] Folding@Home GPU Core - Beta
[04:19:21] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[04:19:21]
[04:19:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:19:21] Build host: amoeba
[04:19:21] Board Type: AMD
[04:19:21] Core      :
[04:19:21] Preparing to commence simulation
[04:19:21] - Looking at optimizations...
[04:19:21] - Created dyn
[04:19:21] - Files status OK
[04:19:21] - Expanded 85751 -> 444252 (decompressed 518.0 percent)
[04:19:21] Called DecompressByteArray: compressed_data_size=85751 data_size=444252, decompressed_data_size=444252 diff=0
[04:19:21] - Digital signature verified
[04:19:21]
[04:19:21] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:19:21]
[04:19:21] Assembly optimizations on if available.
[04:19:21] Entering M.D.
[04:19:27] Working on 1254 p4756_lam5w_300K_g91
[04:19:28] Client config found, loading data.
[04:19:28] Starting GUI Server
[04:19:31] mdrun_gpu returned
[04:19:31] NANs detected on GPU
[04:19:31]
[04:19:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:19:36] CoreStatus = 7A (122)
[04:19:36] Sending work to server
[04:19:36] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:19:36] - Read packet limit of 540015616... Set to 524286976.
[04:19:36] - Error: Could not get length of results file work/wuresults_05.dat
[04:19:36] - Error: Could not read unit 05 file. Removing from queue.
[04:19:36] - Preparing to get new work unit...
[04:19:36] + Attempting to get work packet
[04:19:36] - Connecting to assignment server
[04:19:36] - Successful: assigned to (171.64.65.103).
[04:19:36] + News From Folding@Home: GPU folding beta
[04:19:36] Loaded queue successfully.
[04:19:37] + Closed connections
[04:19:42]
[04:19:42] + Processing work unit
[04:19:42] Core required: FahCore_11.exe
[04:19:42] Core found.
[04:19:42] Working on queue slot 06 [February 24 04:19:42 UTC]
[04:19:42] + Working ...
[04:19:42]
[04:19:42] *------------------------------*
[04:19:42] Folding@Home GPU Core - Beta
[04:19:42] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[04:19:42]
[04:19:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:19:42] Build host: amoeba
[04:19:42] Board Type: AMD
[04:19:42] Core      :
[04:19:42] Preparing to commence simulation
[04:19:42] - Looking at optimizations...
[04:19:42] - Created dyn
[04:19:42] - Files status OK
[04:19:42] - Expanded 85751 -> 444252 (decompressed 518.0 percent)
[04:19:42] Called DecompressByteArray: compressed_data_size=85751 data_size=444252, decompressed_data_size=444252 diff=0
[04:19:42] - Digital signature verified
[04:19:42]
[04:19:42] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:19:42]
[04:19:42] Assembly optimizations on if available.
[04:19:42] Entering M.D.
[04:19:48] Working on 1254 p4756_lam5w_300K_g91
[04:19:49] Client config found, loading data.
[04:19:49] Starting GUI Server
[04:19:53] mdrun_gpu returned
[04:19:53] NANs detected on GPU
[04:19:53]
[04:19:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:19:57] CoreStatus = 7A (122)
[04:19:57] Sending work to server
[04:19:57] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:19:57] - Read packet limit of 540015616... Set to 524286976.
[04:19:57] - Error: Could not get length of results file work/wuresults_06.dat
[04:19:57] - Error: Could not read unit 06 file. Removing from queue.
[04:19:57] - Preparing to get new work unit...
[04:19:57] + Attempting to get work packet
[04:19:57] - Connecting to assignment server
[04:19:57] - Successful: assigned to (171.64.65.103).
[04:19:57] + News From Folding@Home: GPU folding beta
[04:19:57] Loaded queue successfully.
[04:19:58] + Closed connections
[04:20:03]
[04:20:03] + Processing work unit
[04:20:03] Core required: FahCore_11.exe
[04:20:03] Core found.
[04:20:03] Working on queue slot 07 [February 24 04:20:03 UTC]
[04:20:03] + Working ...
[04:20:03]
[04:20:03] *------------------------------*
[04:20:03] Folding@Home GPU Core - Beta
[04:20:03] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[04:20:03]
[04:20:03] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:20:03] Build host: amoeba
[04:20:03] Board Type: AMD
[04:20:03] Core      :
[04:20:03] Preparing to commence simulation
[04:20:03] - Looking at optimizations...
[04:20:03] - Created dyn
[04:20:03] - Files status OK
[04:20:03] - Expanded 85751 -> 444252 (decompressed 518.0 percent)
[04:20:03] Called DecompressByteArray: compressed_data_size=85751 data_size=444252, decompressed_data_size=444252 diff=0
[04:20:03] - Digital signature verified
[04:20:03]
[04:20:03] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:20:03]
[04:20:03] Assembly optimizations on if available.
[04:20:03] Entering M.D.
[04:20:09] Working on 1254 p4756_lam5w_300K_g91
[04:20:10] Client config found, loading data.
[04:20:10] Starting GUI Server
[04:20:14] mdrun_gpu returned
[04:20:14] NANs detected on GPU
[04:20:14]
[04:20:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:20:18] CoreStatus = 7A (122)
[04:20:18] Sending work to server
[04:20:18] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:20:18] - Read packet limit of 540015616... Set to 524286976.
[04:20:18] - Error: Could not get length of results file work/wuresults_07.dat
[04:20:18] - Error: Could not read unit 07 file. Removing from queue.
[04:20:18] - Preparing to get new work unit...
[04:20:18] + Attempting to get work packet
[04:20:18] - Connecting to assignment server
[04:20:18] - Successful: assigned to (171.64.65.103).
[04:20:18] + News From Folding@Home: GPU folding beta
[04:20:18] Loaded queue successfully.
[04:20:19] + Closed connections
[04:20:24]
[04:20:24] + Processing work unit
[04:20:24] Core required: FahCore_11.exe
[04:20:24] Core found.
[04:20:24] Working on queue slot 08 [February 24 04:20:24 UTC]
[04:20:24] + Working ...
[04:20:24]
[04:20:24] *------------------------------*
[04:20:24] Folding@Home GPU Core - Beta
[04:20:24] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[04:20:24]
[04:20:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:20:24] Build host: amoeba
[04:20:24] Board Type: AMD
[04:20:24] Core      :
[04:20:24] Preparing to commence simulation
[04:20:24] - Looking at optimizations...
[04:20:24] - Created dyn
[04:20:24] - Files status OK
[04:20:24] - Expanded 85751 -> 444252 (decompressed 518.0 percent)
[04:20:24] Called DecompressByteArray: compressed_data_size=85751 data_size=444252, decompressed_data_size=444252 diff=0
[04:20:24] - Digital signature verified
[04:20:24]
[04:20:24] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:20:24]
[04:20:24] Assembly optimizations on if available.
[04:20:24] Entering M.D.
[04:20:31] Working on 1254 p4756_lam5w_300K_g91
[04:20:31] Client config found, loading data.
[04:20:31] Starting GUI Server
[04:20:35] mdrun_gpu returned
[04:20:35] NANs detected on GPU
[04:20:35]
[04:20:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:20:39] CoreStatus = 7A (122)
[04:20:39] Sending work to server
[04:20:39] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:20:39] - Read packet limit of 540015616... Set to 524286976.
[04:20:39] - Error: Could not get length of results file work/wuresults_08.dat
[04:20:39] - Error: Could not read unit 08 file. Removing from queue.
[04:20:39] - Preparing to get new work unit...
[04:20:39] + Attempting to get work packet
[04:20:39] - Connecting to assignment server
[04:20:39] - Successful: assigned to (171.64.65.103).
[04:20:39] + News From Folding@Home: GPU folding beta
[04:20:39] Loaded queue successfully.
[04:20:40] + Closed connections
[04:20:45]
[04:20:45] + Processing work unit
[04:20:45] Core required: FahCore_11.exe
[04:20:45] Core found.
[04:20:45] Working on queue slot 09 [February 24 04:20:45 UTC]
[04:20:45] + Working ...
[04:20:45]
[04:20:45] *------------------------------*
[04:20:45] Folding@Home GPU Core - Beta
[04:20:45] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[04:20:45]
[04:20:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:20:45] Build host: amoeba
[04:20:45] Board Type: AMD
[04:20:45] Core      :
[04:20:45] Preparing to commence simulation
[04:20:45] - Looking at optimizations...
[04:20:45] - Created dyn
[04:20:45] - Files status OK
[04:20:45] - Expanded 85751 -> 444252 (decompressed 518.0 percent)
[04:20:45] Called DecompressByteArray: compressed_data_size=85751 data_size=444252, decompressed_data_size=444252 diff=0
[04:20:45] - Digital signature verified
[04:20:45]
[04:20:45] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:20:45]
[04:20:45] Assembly optimizations on if available.
[04:20:45] Entering M.D.
[04:20:52] Working on 1254 p4756_lam5w_300K_g91
[04:20:52] Client config found, loading data.
[04:20:52] Starting GUI Server
[04:20:56] mdrun_gpu returned
[04:20:56] NANs detected on GPU
[04:20:56]
[04:20:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:21:00] CoreStatus = 7A (122)
[04:21:00] Sending work to server
[04:21:00] Project: 4756 (Run 7, Clone 39, Gen 5)
[04:21:00] - Read packet limit of 540015616... Set to 524286976.
[04:21:00] - Error: Could not get length of results file work/wuresults_09.dat
[04:21:00] - Error: Could not read unit 09 file. Removing from queue.
[04:21:00] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
Computer Specs (If relevant):
Intel Q6600
Visiontek Radeon HD4850
2*2GB G.Skill DDR2 800
Gigabyte EP45-DS3L
Corsair 520HX
Everything is stock.
Thanks.
Re: Project 4756 - Run 7, Clone 39, Gen 5
There's no data for this WU in the DB ... this is (probably) a bad WU.
