Project:2446 R31 C13 G0
flatout
Hardware configuration: Intel 3770K @ 4300 MHZ
Video:2 X 560Ti @ Stock clocks
8 GB Memory @ 1600hz
Win 7 Ultimate.
Post by flatout »
I have been trying to upload this WU for quite a while. It is very large upload for a cpu wu.
Here is the first part of the log.
Also a snip of the log futher along, where it is attempting to upload for the 37th time.
                          http://folding.stanford.edu
Launch directory: C:\F@H
Executable: C:\F@H\Folding@home-Win32-x86.exe
Arguments: -verbosity 9 -forceasm -advmethods
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[23:34:32] - Ask before connecting: No
[23:34:32] - User name: flatout (Team 24)
[23:34:32] - User ID: 6F469313546986AD
[23:34:32] - Machine ID: 1
[23:34:32]
[23:34:32] Loaded queue successfully.
[23:34:32]
[23:34:32] + Processing work unit
[23:34:32] Core required: FahCore_78.exe
[23:34:32] - Autosending finished units... [February 21 23:34:32 UTC]
[23:34:32] Trying to send all finished work units
[23:34:32] Project: 2446 (Run 31, Clone 13, Gen 0)
[23:34:32] Core found.
[23:34:32] - Read packet limit of 540015616... Set to 524286976.
[23:34:32] + Attempting to send results [February 21 23:34:32 UTC]
[23:34:32] - Reading file work/wuresults_00.dat from core
[23:34:32] Working on queue slot 01 [February 21 23:34:32 UTC]
[23:34:32] + Working ...
[23:34:32] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 10 -forceasm -verbose -lifeline 3008 -version 623'
[23:34:32]   (Read 40694083 bytes from disk)
[23:34:32] Connecting to http://171.65.103.160:80/
[23:34:32]
[23:34:32] *------------------------------*
[23:34:32] Folding@Home Gromacs Core
[23:34:32] Version 1.90 (March 8, 2006)
[23:34:32]
[23:34:32] Preparing to commence simulation
[23:34:32] - Assembly optimizations manually forced on.
[23:34:32] - Not checking prior termination.
[23:34:33] - Couldn't send HTTP request to server
[23:34:33]   (Got status 503)
[23:34:33] + Could not connect to Work Server (results)
[23:34:33]     (171.65.103.160:80)
[23:34:33] + Retrying using alternative port
[23:34:33] Connecting to http://171.65.103.160:8080/
[23:34:38] - Couldn't send HTTP request to server
[23:34:38] + Could not connect to Work Server (results)
[23:34:38]     (171.65.103.160:8080)
[23:34:38] - Error: Could not transmit unit 00 (completed February 17) to work server.
[23:34:38] - Expanded 2978438 -> 15102705 (decompressed 507.0 percent)
[21:04:53] Timered checkpoint triggered.
[21:06:08] - Couldn't send HTTP request to server
[21:06:08] + Could not connect to Work Server (results)
[21:06:08]     (171.65.103.160:8080)
[21:06:08] - Error: Could not transmit unit 00 (completed February 17) to work server.
[21:06:08] - 37 failed uploads of this unit.
[21:06:08] - Read packet limit of 540015616... Set to 524286976.
[21:06:14] + Attempting to send results [February 23 21:06:14 UTC]
[21:06:14] - Reading file work/wuresults_00.dat from core
[21:06:24]   (Read 40694083 bytes from disk)
[21:06:29] Connecting to http://171.67.108.17:80/
[21:06:34] - Couldn't send HTTP request to server
[21:06:34]   (Got status 503)
[21:06:34] + Could not connect to Work Server (results)
[21:06:39]     (171.67.108.17:80)
[21:06:39] + Retrying using alternative port
[21:06:39] Connecting to http://171.67.108.17:8080/
[21:06:45] - Couldn't send HTTP request to server
[21:06:45]   (Got status 503)
[21:06:50] + Could not connect to Work Server (results)
[21:06:50]     (171.67.108.17:8080)
[21:06:50]   Could not transmit unit 00 to Collection server; keeping in queue.
[21:06:55] Project: 2446 (Run 31, Clone 13, Gen 0)
[21:06:55] - Read packet limit of 540015616... Set to 524286976.
[21:07:00] + Attempting to send results [February 23 21:07:00 UTC]
[21:07:00] - Reading file work/wuresults_00.dat from core
[21:07:10]   (Read 40694083 bytes from disk)
[21:07:10] Connecting to http://171.65.103.160:80/
[21:07:38] - Couldn't send HTTP request to server
[21:07:38] + Could not connect to Work Server (results)
[21:07:38]     (171.65.103.160:80)
[21:07:38] + Retrying using alternative port
[21:07:43] Connecting to http://171.65.103.160:8080/
[21:14:50] Timered checkpoint triggered.
any help or explanation will be apreciated.
flatout
Team 24...OCAU 3450000 PPW Club
39,000,000 Points for Team 24.
Re: Project:2446 R31 C13 G0
Please be patient ... I returned a similar WU yesterday, but it took about two days before it was able to get through ...
