Project: 2665 (Run 3, Clone 767, Gen 98)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Now on Big Red's SMP:
[08:50:34] + Closed connections
[08:50:34]
[08:50:34] + Processing work unit
[08:50:34] Work type a1 not eligible for variable processors
[08:50:34] Core required: FahCore_a1.exe
[08:50:34] Core found.
[08:50:34] Using generic mpiexec calls
[08:50:34] Working on queue slot 01 [February 21 08:50:34 UTC]
[08:50:34] + Working ...
[08:50:34] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 3088 -version 623'
[08:50:34]
[08:50:34] *------------------------------*
[08:50:34] Folding@Home Gromacs SMP Core
[08:50:34] Version 1.74 (March 10, 2007)
[08:50:34]
[08:50:34] Preparing to commence simulation
[08:50:34] - Looking at optimizations...
[08:50:34] - Created dyn
[08:50:34] - Files status OK
[08:50:39] - Expanded 4724368 -> 24426905 (decompressed 517.0 percent)
[08:50:39] - Starting from initial work packet
[08:50:39]
[08:50:39] Project: 2665 (Run 3, Clone 767, Gen 98)
[08:50:39]
[08:50:40] Assembly optimizations on if available.
[08:50:40] Entering M.D.
[08:51:01]  percent)
[08:51:01] - Starting from initial work packet
[08:51:01]
[08:51:01] Project: 2665 (Run 3, Clone 767, Gen 98)
[08:51:01]
[08:51:02] Entering M.D.
[08:51:09] Rejecting checkpoint
[08:51:10] Protein: HGG in water
[08:51:10] Writing local files
[08:51:19] Extra SSE boost OK.
[08:51:19] Writing local files
[08:51:19] Completed 0 out of 250000 steps  (0 percent)
[09:06:19] Timered checkpoint triggered.
[09:06:44] Writing local files
[09:06:44] Completed 2500 out of 250000 steps  (1 percent)
          {snip}
[11:25:04] Timered checkpoint triggered.
[11:25:29] Writing local files
[11:25:29] Completed 25000 out of 250000 steps  (10 percent)
[11:32:33] Warning:  long 1-4 interactions
[11:32:33] Quit 101 - NaN detected: (ener[20])
[11:32:33]
[11:32:33] Simulation instability has been encountered. The run has entered a
[11:32:33]   state from which no further progress can be made.
[11:32:33] This may be the correct result of the simulation, however if you
[11:32:33]   often see other project units terminating early like this
[11:32:33]   too, you may wish to check the stability of your computer (issues
[11:32:33]   such as high temperature, overclocking, etc.).
[11:32:33] Going to send back what have done.
[11:32:33] logfile size: 27894
[11:32:33] - Writing 28444 bytes of core data to disk...
[11:32:33]   ... Done.
[11:32:33] No C.P. to delete.
[11:34:33]
[11:34:33] Folding@home Core Shutdown: EARLY_UNIT_END
[11:34:33]
[11:34:36] CoreStatus = 7B (123)
[11:34:36] Sending work to server
[11:34:36] Project: 2665 (Run 3, Clone 767, Gen 98)
[11:34:36] + Attempting to send results [February 21 11:34:36 UTC]
[11:34:36] - Reading file work/wuresults_01.dat from core
[11:34:36]   (Read 28444 bytes from disk)
[11:34:36] Connecting to http://171.64.65.64:8080/
[11:34:36] Posted data.
[11:34:37] Initial: 0000; - Uploaded at ~28 kB/s
[11:34:37] - Averaged speed for that direction ~245 kB/s
[11:34:37] + Results successfully sent
[11:34:37] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 3, Clone 767, Gen 98)
There are five reports for partial credit for this WU. I've marked it.
anko1
Post by anko1 »
As always, thanks for checking toTOW.
