2484 (Run 207, Clone 7, Gen 12) - lost results
Monterone
Post by Monterone »
I have obviously lost results for 2484 (Run 207, Clone 7, Gen 12).
Yesterday, when I came back in the evening, I shut down my CPU-Clients (not Services) with Ctrl-C and the computer. Then I restarted the computer, because I forgot to check something, which started my CPU-Clients automatically (script in the autostart-folder). I immediately stopped them.
As I started the computer today, one client restarted from the last checkpoint, but the other restarted at 0%. Are the results lost? And if yes, why? Have I shut down too early? Should I wait, until the core started?
[22:14:19] Completed 147500 out of 250000 steps  (59%)
Folding@Home Client Shutdown.
[22:14:21]
--- Opening Log file [February 20 22:37:45 UTC]
[...snip...]
[22:37:49] - Machine ID: 1
[22:37:49]
[22:37:50] Loaded queue successfully.
[22:37:50]
[22:37:50] + Processing work unit
[22:37:50] Core required: FahCore_78.exe
[22:37:50] Core found.
[22:37:51] Working on queue slot 04 [February 20 22:37:51 UTC]
[22:37:51] + Working ...
[...snip...]
[06:39:48] - Machine ID: 1
[06:39:48]
[06:39:49] Loaded queue successfully.
[06:39:49]
[06:39:49] + Processing work unit
[06:39:49] Core required: FahCore_78.exe
[06:39:50] Core found.
[06:39:50] Working on queue slot 04 [February 21 06:39:50 UTC]
[06:39:50] + Working ...
[06:39:51]
[06:39:52] *------------------------------*
[06:39:52] Folding@Home Gromacs Core
[06:39:53] Version 1.90 (March 8, 2006)
[06:39:53]
[06:39:53] Preparing to commence simulation
[06:39:53] - Ensuring status. Please wait.
[06:40:08] - Looking at optimizations...
[06:40:08] - Working with standard loops on this execution.
[06:40:11] - Created dyn
[06:40:11] - Files status OK
[06:40:15] - Expanded 2969701 -> 15072673 (decompressed 507.5 percent)
[06:40:15] - Starting from initial work packet
[06:40:16]
[06:40:16] Project: 2484 (Run 207, Clone 7, Gen 12)
[06:40:16]
[06:40:16] Entering M.D.
[06:40:24] Protein: system
[06:40:25]
[06:40:41] Writing local files
[06:40:47] Writing local files
[06:40:47] Completed 0 out of 250000 steps  (0%)
Re: 2484 (Run 207, Clone 7, Gen 12) - lost results
Monterone wrote: Are the results lost? And if yes, why? Have I shut down too early? Should I wait, until the core started?
Yes. I don't know. Probably. Of course. :mrgreen:
