Noob Geek Wants Help.
GeekGuga
Post by GeekGuga »
Hello this is my questions:
1-i want to know how can i start the folding after i reach 100% progress in the first work, how can i send the data to you when im done?
2-I can't find my name on the team that im currently in.
Sorry for the dumb questions im a begginer.
I'll Fold For The LULZ
MstrBlstr
Re: Noob Geek Wants Help.
Post by MstrBlstr »
The client sends and retrieves new work as needed. As long as you have an active online connection.
You will not see your name appear in the stats until you return your first unit, and they are added to the stats.
-=MB=-
metal03326
Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz)
Post by metal03326 »
Also the stats are showing maximum of 1000 users, arranged by score. That means if your team have more than 1000 users, the stats will show only the first 1000 and you'll be left out, until you beat the 1000th's score.
MstrBlstr
Post by MstrBlstr »
#988 GeekGuga 895 2
on team 13802
Personal stats:
http://fah-web.stanford.edu/cgi-bin/mai ... e=GeekGuga
I see these two:
Donor, Score, WU's, Team
GeekGuga 895 2 13802
GeekGuga 384 1 0
Assume that they are both you?
-=MB=-
whynot
Post by whynot »
GeekGuga wrote:1-i want to know how can i start the folding after i reach 100% progress in the first work, how can i send the data to you when im done?
  • You either enable automatic sending (start client with -configonly option and answer correctly to 'ask before connection' question).
  • Monitor ab ovo your client and when unit completes start client with -send # (-queueinfo option can hint what to send).
  • You know what RTFM means?
I'm counting for science.
Points just make me sick.
