Project: 2674 (Run 0, Clone 97, Gen 99)
bollix47
Post by bollix47 »
[06:44:17] Completed 217500 out of 250000 steps  (87%)
[06:51:15] Completed 220000 out of 250000 steps  (88%)
[06:58:13] Completed 222500 out of 250000 steps  (89%)
[07:04:24] - Autosending finished units... [February 18 07:04:24 UTC]
[07:04:24] Trying to send all finished work units
[07:04:24] + No unsent completed units remaining.
[07:04:24] - Autosend completed
[07:05:12] Completed 225000 out of 250000 steps  (90%)
Step 24975377, time 49950.8 (ps)  LINCS WARNING
relative constraint deviation after LINCS:
rms 0.363684, max 16.850767 (between atoms 14741 and 14743)
bonds that rotated more than 90 degrees:
 atom 1 atom 2  angle  previous, current, constraint length
  14741  14743   90.0    0.1091   1.9457      0.1090
Warning: 1-4 interaction between 14739 and 14743 at distance 3.865 which is larger than the 1-4 table size 2.200 nm
These are ignored for the rest of the simulation
This usually means your system is exploding,
if not, you should increase table-extension in your mdp file
or with user tables increase the table size
Step 24975378, time 49950.8 (ps)  LINCS WARNING
rms 9879595556853.123047, max 612950150742016.000000 (between atoms 14741 and 14743)
   7650   7651   90.0    0.1010 2049676935168.0000      0.1010
   7636   7638   90.0    0.1010 153184.7812      0.1010
   7636   7639   90.0    0.1010 151421.9531      0.1010
   7640   7641  103.9    0.1090  23.3808      0.1090
   7642   7644   90.0    0.1090 554774429696.0000      0.1090
   7671   7672   90.0    0.1090 64381.2852      0.1090
   7673   7676   90.0    0.1090 1094262.0000      0.1090
  14872  14873   90.0    0.1080  86.7748      0.1080
   7652   7653   90.0    0.1090   0.6394      0.1090
  14858  14859   90.0    0.1010 34740494336.0000      0.1010
  14862  14864   90.0    0.1090   1.1101      0.1090
  14874  14875   90.0    0.1080 9325786431488.0000      0.1080
  14845  14846   90.0    0.1090 17509.5215      0.1090
  14880  14881   90.0    0.1090   0.5167      0.1090
  14888  14889   90.0    0.1080 68263.2578      0.1080
  14741  14742   90.0    0.1079 9906506694656.0000      0.1090
  14741  14743   90.0    1.9457 66811567538176.0000      0.1090
  14658  14659   90.0    0.1090 12212251.0000      0.1090
  14658  14660   90.0    0.1090 19180.3887      0.1090
  14658  14661   90.0    0.1090 18741.8633      0.1090
  14662  14663   90.0    0.1090 10825.4648      0.1090
  14662  14664   90.1    0.1090 11067.6689      0.1090
  14662  14665   90.0    0.1090 320484.0312      0.1090
  14653  14654   90.0    0.1090   0.5339      0.1090
  14653  14655  167.4    0.1090   5.6493      0.1090
  14656  14657   90.0    0.1090 65738436.0000      0.1090
  14718  14719   90.0    0.1010   0.2622      0.1010
  14720  14721   90.0    0.1090 80657.0469      0.1090
  14722  14723   90.0    0.1090 434619328.0000      0.1090
  14722  14724   90.0    0.1090 26715846.0000      0.1090
  14722  14725   90.0    0.1090 25111434.0000      0.1090
  14754  14756   90.0    0.1090 12763.4619      0.1090
  14765  14766   90.0    0.1010   2.1860      0.1010
  14891  14892   90.0    0.0960 1553242.0000      0.0960
  14738  14740   90.0    0.1058 184446795776.0000      0.1090
   7059   7060   90.0    0.1090 12552460.0000      0.1090
  14670  14671  134.4    0.1090  20.2211      0.1090
  14672  14673  137.6    0.1090  10.3482      0.1090
  14672  14674  115.2    0.1090  18.0190      0.1090
  14757  14758   90.0    0.1090   0.2438      0.1090
   7035   7036   90.0    0.1090 22946.8535      0.1090
   7037   7039   90.0    0.1090   0.1528      0.1090
   7040   7041   90.0    0.1090 3791454.7500      0.1090
   7040   7042   90.0    0.1090 18666204.0000      0.1090
t = 49950.758 ps: Water molecule starting at atom 103084 can not be settled.
Check for bad contacts and/or reduce the timestep.
Wrote pdb files with previous and current coordinates
[07:06:16]
[07:06:16] Folding@home Core Shutdown: INTERRUPTED
[cli_0]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 102) - process 0
[0]0:Return code = 102
[0]1:Return code = 0, signaled with Segmentation fault
[0]2:Return code = 0, signaled with Segmentation fault
[0]3:Return code = 0, signaled with Quit
[07:06:21] CoreStatus = 66 (102)
[07:06:21] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (15)
[07:06:21] Killing all core threads
Folding@Home Client Shutdown.
bollix@challenger:~/fah/smp$ ./fah6
Note: Please read the license agreement (fah6 -license). Further
use of this software requires that you have read and accepted this agreement.
4 cores detected
--- Opening Log file [February 18 10:00:19 UTC]
# Linux SMP Console Edition ###################################################
                       Folding@Home Client Version 6.24beta
                          http://folding.stanford.edu
Launch directory: /home/bollix/fah/smp
Executable: ./fah6
Arguments: -smp -verbosity 9
[10:00:19] - Ask before connecting: No
[10:00:19] - User name: bollix47 (Team 39340)
[10:00:19] - User ID: 629DB96A76D95BCF
[10:00:19] - Machine ID: 1
[10:00:19]
[10:00:19] Loaded queue successfully.
[10:00:19] - Autosending finished units... [February 18 10:00:19 UTC]
[10:00:19] Trying to send all finished work units
[10:00:19] + No unsent completed units remaining.
[10:00:19] - Autosend completed
[10:00:19]
[10:00:19] + Processing work unit
[10:00:19] At least 4 processors must be requested.Core required: FahCore_a2.exe
[10:00:19] Core found.
[10:00:19] Working on queue slot 05 [February 18 10:00:19 UTC]
[10:00:19] + Working ...
[10:00:19] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -suffix 05 -priority 96 -checkpoint 30 -verbose -lifeline 19017 -version 624'
[10:00:19]
[10:00:19] *------------------------------*
[10:00:19] Folding@Home Gromacs SMP Core
[10:00:19] Version 2.04 (Thu Jan 29 16:43:57 PST 2009)
[10:00:19]
[10:00:19] Preparing to commence simulation
[10:00:19] - Ensuring status. Please wait.
[10:00:20] Called DecompressByteArray: compressed_data_size=4845248 data_size=24001501, decompressed_data_size=24001501 diff=0
[10:00:20] - Digital signature verified
[10:00:20]
[10:00:20] Project: 2674 (Run 0, Clone 97, Gen 99)
[10:00:20]
[10:00:20] Assembly optimizations on if available.
[10:00:20] Entering M.D.
[10:00:26] Will resume from checkpoint file
[10:00:30] ng M.D.
[10:00:36] Will resume from checkpoint file
NNODES=4, MYRANK=0, HOSTNAME=challenger
NNODES=4, MYRANK=2, HOSTNAME=challenger
NNODES=4, MYRANK=3, HOSTNAME=challenger
NNODES=4, MYRANK=1, HOSTNAME=challenger
NODEID=0 argc=20
                         :-)  G  R  O  M  A  C  S  (-:
                   Groningen Machine for Chemical Simulation
                          :-)  VERSION 4.0.3_pre  (-:
      Written by David van der Spoel, Erik Lindahl, Berk Hess, and others.
       Copyright (c) 1991-2000, University of Groningen, The Netherlands.
             Copyright (c) 2001-2008, The GROMACS development team,
            check out http://www.gromacs.org for more information.
                                :-)  mdrun  (-:
Reading file work/wudata_05.tpr, VERSION 3.3.99_development_20070618 (single precision)
NODEID=2 argc=20
NODEID=3 argc=20
NODEID=1 argc=20
Note: tpx file_version 48, software version 58
NOTE: The tpr file used for this simulation is in an old format, for less memory usage and possibly more performance create a new tpr file with an up to date version of grompp
Making 1D domain decomposition 1 x 1 x 4
starting mdrun '22878 system in water'
25000000 steps,  50000.0 ps (continuing from step 24750000,  49500.0 ps).
[10:00:38] data_05.log
[10:00:38] Verified work/wudata_05.trr
[10:00:39] Verified work/wudata_05.xtc
[10:00:39] Verified work/wudata_05.edr
[10:00:39] Completed 225010 out of 250000 steps  (90%)
[10:08:21] Completed 227500 out of 250000 steps  (91%)
[10:16:04] Completed 230000 out of 250000 steps  (92%)
[10:24:00] Completed 232500 out of 250000 steps  (93%)
It wasn't requested by me! Guessing it was the client???
It did not explode. :shock:
Running on a Q6600 @ stock using ubuntu 8.04 with an 8800GT running in wine. The gpu client had no problems.
As can be seen from the log a restart carried on from the checkpoint without incident(so far).
Re: Project: 2674 (Run 0, Clone 97, Gen 99)
bollix47 wrote:[07:06:21] CoreStatus = 66 (102)
It sometimes happens ... but I don't think anyone figured out why it stops instead of reporting an EUE :(
bollix47 wrote:This usually means your system is exploding,
:lol:
It is about the simulated system. ;)
