Changing teams mid-folding
damien_moore
Post by damien_moore »
Here is a small question I have.
I want to change teams, and I have changed my clients so they go to my new team.
The question I have is does the WU I am currently working on go to my new group or the old group?
FahMon sill says the old team, but the client says the new team.
So which is it? :S
Member of Nyx Online (160109)
Pick2
Hardware configuration: Linux & CPUs
Re: Changing teams mid-folding
Post by Pick2 »
The only right answer is what your FAHlog.txt file says when you restart the client. If you stop the client , make the change and then restart the client , it will go to your new team.
All the rest are using the old data , it doesn't change till your next WU starts ... FahMon , qd , all show the wrong data from when the WU was first downloaded.
damien_moore
The logs check out.
Ok, so it should go to the new team?
Pick2
Post by Pick2 »
Yes it should ! The last restart from your FAHlog is the Real Deal.
damien_moore
Ah kk thx :)
