This info is for dedicated folding computer owners. Windows has automatic update feature. Its mostly good thing, sometimes annoying, but its usually good to keep all system software up-to-date.
TIP: switch Automatic Updates (Control Panel) settings from default setting "Install updates automatically" to "Download automatically, but let me choose when to install".
In default setting You computer updates and performs automatic restart. You find several hours/days later, that folder has been restarted and not folding.
Jaak
Tip of the day: Automatic Windows Update
jaak ennuste
- Hardware configuration: 3 x Nvidia Geforce GTX 295 cards (total 6 GPU's)
AMD Phenom x4 2600MHz Black Edition
MSI 790FX K9A2 Platinum system board, 4GB RAM
ATX case, 1000 W Chieftec PS
Windows XP 64-bit
More: http://estoniadonates.wordpress.com/ - Location: Tallinn, Estonia, EU
building 32 GPU folding rig: 16 x NVIDIA GeForce GTX 295 cards; dual PSU solution; 4 nodes.
Website: Estonia Donates, ambitious 400 PPD supercomputer project
Sponsored by AdlerFlow ceramic coated Porsche exhausts
Re: Tip of the day: Automatic Windows Update
All my machines are set to only notice me that some updates are available, but to do nothing else.
codysluder
You do have a choice. If you leave automatic updating, you can install the classic FAH client as a service (which starts before anyone logs on). You can also configure Windows to log you on automatically (even if you have a password for SMP) provided you're not concerned about security. Then even the SMP and the GPU clients can resume work with shortcuts in startup.
Personally, I prefer to install updates manually, though, because I don't trust the FAH clients to shut down cleanly so I always want to wait for a checkpoint an then CTRL-C before allowing WIndows to reboot.
jaak ennuste
Windows XP 64-bit
Yes, but running additionally 6 or 8 GPU clients needs manual restart. I'm thinking about adding them to startup directory wit fahmon, not done yet.
Jaak
Jaak
metal03326
- Hardware configuration: Mainboard: Asus M2R32-MVP (AMD 580X CrossFire Chipset)
CPU: AMD Athlon X2 3800+@2.4GHz
CPU cooler: Arctic Cooling Freezer 64 Pro PWM
RAM: 2x1 GB Team XTreme Dark 800MHz@5-5-5-16 in Dual Channel mode
Video Card: Sapphire HD 2600 XT@850MHz GDDR4@2200MHz
HDD: WESTERN DIGITAL 640GB Caviar® Black™ SATA2 7200rpm 32MB
OS: Microsoft Windows 7 Ultimate x64
Clients (always latest version): SMP2
Dell Inspiron 1000 (Celeron@2.2GHz) - Location: Vratsa, Bulgaria.
I have turned off Automatic Updates. I've even disabled Windows Update service. Processor time is expensive, you know
If there is an important update, I'll download and install it manually, but until now, I haven't done so.
PeterA
- Hardware configuration: PC: AMD Sempron(tm) Processor 2800+, 1024 MB RAM, Microsoft Windows XP (Home Edition) SP3
Laptop: Mobile AMD Sempron(tm) Processor 3500+, 896 MB RAM, Microsoft Windows Vista (Home Premium) - Location: Blaine, MN
I find that after a major Windows Update F@H will start up again; but sometimes it can't resume folding the WU it was previously folding. I get some error code and then it starts a new WU. Could the update somehow corrupt the WU?
codysluder
What is the error code that you get?
I suppose the update could corrupt the WU. I suppose the shutdown sequence may not follow the "normal" shutdown procedure, but that's a very elusive thing to try to test.
