Project: 2665 (Run 0, Clone 194, Gen 94)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Hmm. Another EUE. Had some problems with my GPU client, which I haven't had time to post about. The restart seemed to clear out the gremlins for the GPU, but I got this SMP EUE. Hope it's just an aberration to get two so close together.
--- Opening Log file [February 11 20:15:58 UTC]
                       Folding@Home Client Version 6.23 Beta R1
                          http://folding.stanford.edu
Launch directory: C:\SMP
Executable: C:\SMP\SMP.exe
Arguments: -verbosity 9 -smp
[20:15:58] - Ask before connecting: No
[20:15:58] - User name: anko1 (Team 47815)
[20:15:58] - User ID: 74362D0123E30B26
[20:15:58] - Machine ID: 1
[20:15:58]
[20:15:58] Loaded queue successfully.
[20:15:58]
[20:15:58] - Autosending finished units... [February 11 20:15:58 UTC]
[20:15:58] + Processing work unit
[20:15:58] Trying to send all finished work units
[20:15:58] Work type a1 not eligible for variable processors
[20:15:58] + No unsent completed units remaining.
[20:15:58] Core required: FahCore_a1.exe
[20:15:58] - Autosend completed
[20:15:58] Core found.
[20:15:58] Using generic mpiexec calls
[20:15:58] Working on queue slot 08 [February 11 20:15:58 UTC]
[20:15:58] + Working ...
[20:15:58] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 08 -checkpoint 15 -verbose -lifeline 3304 -version 623'
[20:15:59]
[20:15:59] *------------------------------*
[20:15:59] Folding@Home Gromacs SMP Core
[20:15:59] Version 1.74 (March 10, 2007)
[20:15:59]
[20:15:59] Preparing to commence simulation
[20:15:59] - Ensuring status. Please wait.
[20:16:16] - Looking at optimizations...
[20:16:16] - Working with standard loops on this execution.
[20:16:17] - Previous termination of core was improper.
[20:16:17] - Going to use standard loops.
[20:16:17] - Files status OK
[20:16:28] - Expanded 4778259 -> 24426905 (decompressed 511.2 percent)
[20:16:30]
[20:16:30] Project: 2665 (Run 0, Clone 194, Gen 94)
[20:16:30]
[20:16:31] Entering M.D.
[20:16:41] Calling FAH init
[20:16:43] Read topology
[20:16:43] ocal files
[20:16:43] Completed 64780 out of 250000 steps  (25 percent)
[20:16:43] ter
[20:16:43] Writing local files
[20:16:53] Extra SSE boost OK.
               {snip}
[07:09:00] Writing local files
[07:09:01] Completed 150000 out of 250000 steps  (60 percent)
[07:24:01] Timered checkpoint triggered.
[07:25:23] Warning:  long 1-4 interactions
[07:25:24] Quit 101 - NaN detected: (ener[20])
[07:25:24]
[07:25:24] Simulation instability has been encountered. The run has entered a
[07:25:24]   state from which no further progress can be made.
[07:25:24] This may be the correct result of the simulation, however if you
[07:25:24]   often see other project units terminating early like this
[07:25:24]   too, you may wish to check the stability of your computer (issues
[07:25:24]   such as high temperature, overclocking, etc.).
[07:25:24] Going to send back what have done.
[07:25:24] logfile size: 131735
[07:25:24] - Writing 132285 bytes of core data to disk...
[07:25:24]   ... Done.
[07:25:24] - Failed to delete work/wudata_08.arc
[07:25:24] Warning:  check for stray files
[07:27:24]
[07:27:24] Folding@home Core Shutdown: EARLY_UNIT_END
[07:27:24]
[07:27:29] CoreStatus = 7B (123)
[07:27:29] Sending work to server
[07:27:29] Project: 2665 (Run 0, Clone 194, Gen 94)
[07:27:29] + Attempting to send results [February 12 07:27:29 UTC]
[07:27:29] - Reading file work/wuresults_08.dat from core
[07:27:29]   (Read 132285 bytes from disk)
[07:27:29] Connecting to http://171.64.65.64:8080/
[07:27:33] Posted data.
[07:27:40] Initial: 0000; - Uploaded at ~11 kB/s
[07:27:40] - Averaged speed for that direction ~233 kB/s
[07:27:40] + Results successfully sent
[07:27:40] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 0, Clone 194, Gen 94)
There is another report for partial credit ... no one was able to complete it yet.
