Project: 2665 (Run 3, Clone 94, Gen 90)
Zagen30
Post by Zagen30 »
EUE'd on me, which is an extreme rarity nowadays what with 6.23 being pretty stable:
[07:14:04] Completed 210000 out of 250000 steps  (84 percent)
[07:44:51] Writing local files
[07:44:52] Completed 212500 out of 250000 steps  (85 percent)
[08:08:10] Warning:  long 1-4 interactions
[08:08:12] Gromacs cannot continue further.
[08:08:12] Going to send back what have done.
[08:08:12] logfile size: 172796
[08:08:12] - Writing 173332 bytes of core data to disk...
[08:08:12]   ... Done.
[08:08:12] - Failed to delete work/wudata_05.arc
[08:08:12] No C.P. to delete.
[08:08:12] Warning:  check for stray files
[08:10:13]
[08:10:13] Folding@home Core Shutdown: EARLY_UNIT_END
[08:10:13]
[08:10:19] CoreStatus = 7B (123)
[08:10:19] Sending work to server
[08:10:19] Project: 2665 (Run 3, Clone 94, Gen 90)
It doesn't look like I was credited based on the update amounts shown on EOC stats (85% of 1920 should be around 1600 points, and I didn't get that or more any time around the failure). And the log says it did return the partially completed WU successfully.
Re: Project: 2665 (Run 3, Clone 94, Gen 90)
Hi Zagen30 (team 0),
Your WU (P2665 R3 C94 G90) was added to the stats database on 2009-02-11 00:27:53 for 620.86 points of credit.
There are two other reports of EUE for this WU in the DB.
Zagen30
Post by Zagen30 »
I guess that would explain the weird # of points I got in the 6 am update. At this point I have 6 clients running, so trying to figure what turned in when can sometimes be confusing.
Is partial credit supposed to be exactly proportional to the percentage done? I seem to recall on other EUEs getting x*y credit where x was the percentage complete and y was the full credit for that WU (i.e. where this would have gotten me 85% of 1920 points = 1634).
Zagen30 wrote:Is partial credit supposed to be exactly proportional to the percentage done?
I don't think so. It's proportional to science value (or to the part which can be useful). I've already seen some EUE at 90+% giving only a couple of points for credit :(
Zagen30
Post by Zagen30 »
Bummer. Oh well.
