Issue with My Team
CCRunner
Issue with My Team
Post by CCRunner »
I registered a few hours ago and I have an issue with the team I'm on. When I click the "Team Stats" button, it takes me to the team I want to be on,TeamCFC. However, when I click "User Stats", it says I'm part of Team Mustang World. This(MustangWorld) is the team that I show up as being a part of. I've checked multiple times to see that I entered the number correctly and I have. What could be the problem?
Also, I seem to have 65,000 points already, leading me to believe that I somehow took over someones account possibly :(?
47958 =TeamCFC ID number
37092 = Team Mustang ID number
Don't you think not letting me post links is a little harsh? :? Also, I apologize if I put this is the wrong section
MstrBlstr
Re: Issue with My Team
Post by MstrBlstr »
There can be more than one identical donor name used. But only one donor name/team # combination.
If you have not turned in any work units under your donor name and team # combination, you will not show in the stats yet until you have.
The donor under the 37092 = Team Mustang ID number is someone else that happened to use the same donor name that you picked. It will not interfere with any score that you turn in under that same donor name for team 47958 =TeamCFC.
You should show up under your donor name and team # after you have successfully returned a work unit.
Harsh, perhaps. But, it is board security feature. Not meant just for you. Nobody can post links until after they have more than 10 posts in the forum. This prevents spam bots from being able to post links.
-=MB=-
CCRunner
Post by CCRunner »
I see now, Thank you.
