Workunit completion statistics.
HD580
Hardware configuration: Gigabyte EP45-UD3P -- C2Q Q6600 G0 L737A843 @ 3.6 GHz 1.504v 400x9 -- OCZ 8GB DDR2 800 5-5-5-15
EVGA GTX295+ 756/16556/1026 1150mV -- 2xVelociRaptor 300 GB -- Seagate 1TB -- VistaUltimate 64bit
PC Power & Cooling 750w -- D-TEK FuZionv2 -- 2xSwiftech mcp655 -- 2xXSPC RX360 -- EK-GTX295 Water block -- Antec Basiq 500w -- Sennheiser HD 580
Post by HD580 »
Which tool keeps statistics of how a unit finishes in regards to the log reporting of CoreStatus, NANS, and other errors, or successful work unit completion percentage?
Re: Workunit completion statistics.
This information is not published. However, Stanford likely has some kind of internal reporting they do for that kind of data.
If you just want to track your personal folding, Fahmon seems to be the popular tool at the moment. Check the 3rd Party Apps section of the forum, Tools List thread. If there is a tool to do what you asked, it would be listed there.
