Hi all,
Just got back home and i've tried to dispaly fahmon and nothing comes up on the screen? its working in the stry and detailing my PPD but when i go to show fahmon i only get a tab?
i've uninstalled and re installed an i get them same thing? and it was fine yesterday
Any ideas
FAHMON not being dispalyed
Re: FAHMON not being dispalyed
I don't know if this is your problem or not, but at one time my FahMon managed to get moved to the edge of my desktop and I could see nothing. I had to delete one of the files in config but I don't remember which one. Uninstall/reinstall probably doesn't touch those files.
uncle_fungus
Unfortunately the only easy way of fixing this user-side is to delete your prefs.dat file (%APPDATA%\FahMon\config\prefs.dat). The down-side of this is you lose all your settings (but not client lists/benchmarks etc.).
There is another fix for this in SVN, and it shouldn't be too long before this makes it to release.
http://trac.fahmon.net/ticket/190
http://trac.fahmon.net/changeset/428
