Project: 5766 (Run 2, Clone 333, Gen 11)
statesidecoma
Post by statesidecoma »
I too am having a problem with this one project now for 2 days, no other projects but this one
[02:42:46] Project: 5766 (Run 2, Clone 333, Gen 11)
[02:42:46]
[02:42:46] Assembly optimizations on if available.
[02:42:46] Entering M.D.
[02:42:52] Working on Protein
[02:42:53] mdrun_gpu returned
[02:42:53] Self-test failure
[02:42:53]
[02:42:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:42:56] CoreStatus = 7A (122)
[02:42:56] Sending work to server
[02:42:56] Project: 5766 (Run 2, Clone 333, Gen 11)
[02:42:56] - Read packet limit of 540015616... Set to 524286976.
[02:42:56] - Error: Could not get length of results file work/wuresults_06.dat
[02:42:56] - Error: Could not read unit 06 file. Removing from queue.
[02:42:56] - Preparing to get new work unit...
[02:42:56] + Attempting to get work packet
[02:42:56] - Connecting to assignment server
[02:42:57] - Successful: assigned to (171.67.108.11).
[02:42:57] + News From Folding@Home: GPU folding beta
[02:42:57] Loaded queue successfully.
[02:42:57] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[02:43:04] + Attempting to get work packet
[02:43:04] - Connecting to assignment server
[02:43:04] - Successful: assigned to (171.67.108.11).
[02:43:04] + News From Folding@Home: GPU folding beta
[02:43:05] Loaded queue successfully.
[02:43:05] + Could not connect to Work Server
[02:43:05] - Attempt #2  to get work failed, and no other work to do.
[02:43:21] + Attempting to get work packet
[02:43:21] - Connecting to assignment server
[02:43:21] - Successful: assigned to (171.67.108.11).
[02:43:21] + News From Folding@Home: GPU folding beta
[02:43:21] Loaded queue successfully.
[02:43:23] + Closed connections
[02:43:28]
[02:43:28] + Processing work unit
[02:43:28] Core required: FahCore_11.exe
[02:43:28] Core found.
[02:43:28] Working on queue slot 07 [January 15 02:43:28 UTC]
[02:43:28] + Working ...
[02:43:28]
[02:43:28] *------------------------------*
[02:43:28] Folding@Home GPU Core - Beta
[02:43:28] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[02:43:28]
[02:43:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:43:28] Build host: amoeba
[02:43:28] Board Type: Nvidia
[02:43:28] Core      :
[02:43:28] Preparing to commence simulation
[02:43:28] - Looking at optimizations...
[02:43:28] - Created dyn
[02:43:28] - Files status OK
[02:43:28] - Expanded 98823 -> 492276 (decompressed 498.1 percent)
[02:43:28] Called DecompressByteArray: compressed_data_size=98823 data_size=492276, decompressed_data_size=492276 diff=0
[02:43:28] - Digital signature verified
[02:43:28]
[02:43:28] Project: 5749 (Run 8, Clone 257, Gen 2)
[02:43:28]
[02:43:28] Assembly optimizations on if available.
[02:43:28] Entering M.D.
[02:43:34] Working on Protein
[02:43:40] Client config found, loading data.
[02:43:40] Starting GUI Server
[02:46:02] Completed 1%
[02:48:25] Completed 2%
[02:50:49] Completed 3%
[02:53:15] Completed 4%
[02:55:37] Completed 5%
[02:57:59] Completed 6%
[03:00:21] Completed 7%
[03:02:42] Completed 8%
[03:05:04] Completed 9%
[03:07:26] Completed 10%
[03:09:47] Completed 11%
[03:12:09] Completed 12%
[03:14:30] Completed 13%
[03:16:53] Completed 14%
[03:19:22] Completed 15%
[03:21:44] Completed 16%
[03:24:05] Completed 17%
[03:26:27] Completed 18%
[03:28:48] Completed 19%
[03:31:13] Completed 20%
[03:33:40] Completed 21%
[03:36:07] Completed 22%
[03:38:34] Completed 23%
[03:41:02] Completed 24%
[03:43:28] Completed 25%
[03:45:49] Completed 26%
[03:48:11] Completed 27%
[03:50:36] Completed 28%
[03:53:03] Completed 29%
[03:55:30] Completed 30%
[03:57:57] Completed 31%
[04:00:22] Completed 32%
Re: Project: 5766 (Run 2, Clone 333, Gen 11)
I just found your post attached to the end of a thread about a different WU. Sorry for the delay in answering.
FWIW, this WU was successfully completed for full credit. I see that somebody (probably you) is using statesidecoma for their FAH UserName and that's not the UserName that completed it.
