Project: 5749 (Run 7, Clone 305, Gen 54)
mpapad
Hardware configuration: 1) Q6600@2.4, Rampage Formula, 2x1GB Transcent AxeRam,
8800GTX with Zalman VM1000, X-Fi Elite Pro,
Seasonic 600W, Cosmos-S
2) Q6600@2.4, P5Q Deluxe, 2x1GB Mushkin,
2x8800GT,650W Corsair,Cosmos-S
Post by mpapad »
[15:21:47] Folding@Home GPU Core - Beta
[15:21:47] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:21:47]
[15:21:47] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:21:47] Build host: amoeba
[15:21:47] Board Type: Nvidia
[15:21:47] Core      :
[15:21:47] Preparing to commence simulation
[15:21:47] - Looking at optimizations...
[15:21:47] - Created dyn
[15:21:47] - Files status OK
[15:21:47] - Expanded 98759 -> 492276 (decompressed 498.4 percent)
[15:21:47] Called DecompressByteArray: compressed_data_size=98759 data_size=492276, decompressed_data_size=492276 diff=0
[15:21:47] - Digital signature verified
[15:21:47]
[15:21:47] Project: 5749 (Run 7, Clone 305, Gen 54)
[15:21:47]
[15:21:47] Assembly optimizations on if available.
[15:21:47] Entering M.D.
[15:21:54] Working on Protein
[15:21:56] Client config found, loading data.
[15:21:57] Starting GUI Server
[15:21:57] mdrun_gpu returned
[15:21:57] NANs detected on GPU
[15:21:57]
[15:21:57] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:21:59] CoreStatus = 7A (122)
[15:21:59] Sending work to server
[15:21:59] Project: 5749 (Run 7, Clone 305, Gen 54)
[15:21:59] - Read packet limit of 540015616... Set to 524286976.
[15:21:59] - Error: Could not get length of results file work/wuresults_07.dat
[15:21:59] - Error: Could not read unit 07 file. Removing from queue.
[15:21:59] Trying to send all finished work units
[15:21:59] + No unsent completed units remaining.
[15:21:59] - Preparing to get new work unit...
[15:21:59] + Attempting to get work packet
[15:21:59] - Will indicate memory of 2046 MB
[15:21:59] - Connecting to assignment server
[15:21:59] Connecting to http://assign-GPU.stanford.edu:8080/
[15:22:00] Posted data.
[15:22:00] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[15:22:00] + News From Folding@Home: GPU folding beta
[15:22:00] Loaded queue successfully.
[15:22:00] Connecting to http://171.67.108.11:8080/
[15:22:03] Posted data.
[15:22:03] Initial: 0000; - Receiving payload (expected size: 99271)
[15:22:03] Conversation time very short, giving reduced weight in bandwidth avg
[15:22:03] - Downloaded at ~193 kB/s
[15:22:03] - Averaged speed for that direction ~149 kB/s
[15:22:03] + Received work.
[15:22:03] Trying to send all finished work units
[15:22:03] + No unsent completed units remaining.
[15:22:03] + Closed connections
[15:22:08]
[15:22:08] + Processing work unit
[15:22:08] Core required: FahCore_11.exe
[15:22:08] Core found.
[15:22:08] Working on queue slot 08 [February 5 15:22:08 UTC]
[15:22:08] + Working ...
[15:22:08] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 7776 -version 620'
[15:22:08]
[15:22:08] *------------------------------*
[15:22:08] Folding@Home GPU Core - Beta
[15:22:08] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:22:08]
[15:22:08] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:22:08] Build host: amoeba
[15:22:08] Board Type: Nvidia
[15:22:08] Core      :
[15:22:08] Preparing to commence simulation
[15:22:08] - Looking at optimizations...
[15:22:08] - Created dyn
[15:22:08] - Files status OK
[15:22:08] - Expanded 98759 -> 492276 (decompressed 498.4 percent)
[15:22:08] Called DecompressByteArray: compressed_data_size=98759 data_size=492276, decompressed_data_size=492276 diff=0
[15:22:08] - Digital signature verified
[15:22:08]
[15:22:08] Project: 5749 (Run 7, Clone 305, Gen 54)
[15:22:08]
[15:22:08] Assembly optimizations on if available.
[15:22:08] Entering M.D.
[15:22:14] Working on Protein
[15:22:17] Client config found, loading data.
[15:22:17] Starting GUI Server
[15:22:17] mdrun_gpu returned
[15:22:17] NANs detected on GPU
[15:22:17]
[15:22:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:22:20] CoreStatus = 7A (122)
[15:22:20] Sending work to server
[15:22:20] Project: 5749 (Run 7, Clone 305, Gen 54)
[15:22:20] - Read packet limit of 540015616... Set to 524286976.
[15:22:20] - Error: Could not get length of results file work/wuresults_08.dat
[15:22:20] - Error: Could not read unit 08 file. Removing from queue.
[15:22:20] EUE limit exceeded. Pausing 24 hours.
Three bad WU's in three days.
This is a record for me.
Re: Project: 5749 (Run 7, Clone 305, Gen 54)
There's another report of immediate failure in the DB.
