Project: 5014 (Run 0, Clone 437, Gen 95)
mpapad
Hardware configuration: 1) Q6600@2.4, Rampage Formula, 2x1GB Transcent AxeRam,
8800GTX with Zalman VM1000, X-Fi Elite Pro,
Seasonic 600W, Cosmos-S
2) Q6600@2.4, P5Q Deluxe, 2x1GB Mushkin,
2x8800GT,650W Corsair,Cosmos-S
Post by mpapad »
[02:19:13] Project: 5014 (Run 0, Clone 437, Gen 95)
[02:19:13]
[02:19:13] Assembly optimizations on if available.
[02:19:13] Entering M.D.
[02:19:19] Working on 576 p5005_supervillin_e1
[02:19:20] Client config found, loading data.
[02:19:20] mdrun_gpu returned
[02:19:20] NANs detected on GPU
[02:19:20]
[02:19:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:19:23] CoreStatus = 7A (122)
[02:19:23] Sending work to server
[02:19:23] Project: 5014 (Run 0, Clone 437, Gen 95)
Bad WU?
Re: Project: 5014 (Run 0, Clone 437, Gen 95)
There's no data for this WU in the DB yet ...
There's still no data in the db.
THe next few lines after the end of your FAHlog clip would be interesting. My guess is that after CoreStatus = 7A, the WU is deleted and the server gets no indication that anything is wrong -- just that you didn't return anything.
It generally looks like this.
[..] CoreStatus = 7A (122)
[..] Sending work to server
[..] Project: xxxx (Run xx, Clone xx, Gen xx)
[..] - Read packet limit of 540015616... Set to 524286976.
[..] - Error: Could not get length of results file work/wuresults_05.dat
[..] - Error: Could not read unit 05 file. Removing from queue.
The real conclusion is that there was nothing to send so it was removed from the queue without uploading a report.
I'm going to mark that WU as bad.
