Project: 2669 (Run 4, Clone 130, Gen 93)
alpha754293
Post by alpha754293 »
error:
console output:
[13:31:34] - Preparing to get new work unit...
[13:31:34] + Attempting to get work packet
[13:31:34] - Connecting to assignment server
[13:32:04] + Could not connect to Assignment Server
[13:32:09] - Successful: assigned to (171.64.65.56).
[13:32:09] + News From Folding@Home: Welcome to Folding@Home
[13:32:10] Loaded queue successfully.
[13:32:32] + Closed connections
[13:32:32]
[13:32:32] + Processing work unit
[13:32:32] Core required: FahCore_a2.exe
[13:32:32] Core found.
[13:32:32] Working on queue slot 03 [February 2 13:32:32 UTC]
[13:32:32] + Working ...
[13:32:32]
[13:32:32] *------------------------------*
[13:32:32] Folding@Home Gromacs SMP Core
[13:32:32] Version 2.01 (Wed Aug 13 13:11:25 PDT 2008)
[13:32:32]
[13:32:32] Preparing to commence simulation
[13:32:32] - Ensuring status. Please wait.
[13:32:33] Called DecompressByteArray: compressed_data_size=4843187 data_size=23
991465, decompressed_data_size=23991465 diff=0
[13:32:33] - Digital signature verified
[13:32:33]
[13:32:33] Project: 2669 (Run 4, Clone 130, Gen 93)
[13:32:33]
[13:32:34] Assembly optimizations on if available.
[13:32:34] Entering M.D.
[13:32:43] Run 4, Clone 130, Gen 93)
[13:32:43]
[13:32:43] Entering M.D.
NNODES=4, MYRANK=1, HOSTNAME=computenode
NNODES=4, MYRANK=3, HOSTNAME=computenode
NNODES=4, MYRANK=0, HOSTNAME=computenode
NNODES=4, MYRANK=2, HOSTNAME=computenode
NODEID=0 argc=19
NODEID=1 argc=19
                         :-)  G  R  O  M  A  C  S  (-:
                   Groningen Machine for Chemical Simulation
                 :-)  VERSION 3.3.99_development_200800503  (-:
      Written by David van der Spoel, Erik Lindahl, Berk Hess, and others.
       Copyright (c) 1991-2000, University of Groningen, The Netherlands.
             Copyright (c) 2001-2008, The GROMACS development team,
            check out http://www.gromacs.org for more information.
                                :-)  mdrun  (-:
NODEID=2 argc=19
Reading file work/wudata_03.tpr, VERSION 3.3.99_development_20070618 (single pre
cision)
NODEID=3 argc=19
Note: tpx file_version 48, software version 56
Making 1D domain decomposition 1 x 1 x 4
starting mdrun '22908 system'
250000 steps,    500.0 ps.
Writing checkpoint, step 23254310 at Mon Feb  2 08:47:53 2009
[13:50:17] Completed 5000 out of 250000 steps  (2%)
Warning: 1-4 interaction between 4304 and 4307 at distance 4.253 which is larger
 than the 1-4 table size 2.200 nm
These are ignored for the rest of the simulation
This usually means your system is exploding,
if not, you should increase table-extension in your mdp file
or with user tables increase the table size
Step 23255150, time 46510.3 (ps)  LINCS WARNING
relative constraint deviation after LINCS:rms 119.100666, max 1250.533325 (between atoms 1784 and 1786)
bonds that rotated more than 90 degrees:
 atom 1 atom 2  angle  previous, current, constraint length
   4284   4285   90.0    0.1090   0.2877      0.1090
   1048   1049   90.0    0.4149  43.0812      0.1090
   1839   1841   90.0    0.4356  39.8000      0.1090
   4326   4327   90.0    4.0366   4.6309      0.1090
rms 11.641771, max 741.092529 (between atoms 648 and 649)
   3796   3797  109.7    0.1496  37.6851      0.1090
    748    749   90.0    0.5155   1.2280      0.1090
    759    761   90.0    0.2801   4.5306      0.1090
   1722   1723   90.0    0.7101  16.9347      0.1080
   2747   2749   90.0    0.2495  54.1120      0.1090
   2747   2750   90.0    0.1090   0.6444      0.1090
  11028  11031   90.0    0.6327   0.6224      0.1090
    648    649   90.0    4.8884  80.8881      0.1090
    648    650   90.0    0.1090   0.8178      0.1090
   1714   1715   90.0    4.5846   4.0031      0.1010
   2703   2704   90.0    0.1514   0.1961      0.1090
   1136   1138  100.8    0.3025  38.8230      0.1090
   4288   4289   90.0    4.2014  13.4680      0.1080
   4290   4291   90.0    4.4915   0.7988      0.1080
   4295   4296   90.0    0.1332   1.8362      0.1080
   4308   4309   90.0    0.1466   1.2763      0.1010
   4317   4319   90.0    0.2096   0.1839      0.1010
   4322   4323   90.0    0.4110   0.2573      0.1010
    755    757   90.0    0.0957   0.2070      0.1090
    755    758   90.0    4.4688  17.6286      0.1090
   1105   1106   90.0    0.2139   0.6048      0.1090
   1105   1107   90.0    0.3077   0.7556      0.1090
   1105   1108   90.0    0.2780  17.3693      0.1090
   1109   1111   90.0    0.1786   1.3798      0.1090
   1109   1112   90.0    0.2535  45.5130      0.1090
   1751   1752   90.0    0.5871   1.4279      0.1090
   1753   1754   90.0    0.2095   0.5934      0.1090
   4004   4005   90.0    0.5697   4.5967      0.1080
   4006   4007   90.0    0.5475  20.8929      0.1080
   4013   4014   90.0    0.2475  30.2776      0.1080
   1759   1761   90.0    0.1010   3.4092      0.1090
   1762   1763   90.0    0.2171   6.3100      0.1090
   1771   1772   90.0    0.1514   0.2821      0.1010
   1781   1782   90.0    0.1316   0.8647      0.1090
   3988   3989   90.0    0.1356   3.6785      0.1090
   3996   3997   90.0    0.3458   2.1064      0.1010
   1773   1774   90.0    0.0957   0.1213      0.1090
   3967   3968   90.0    0.5545  31.0942      0.1090
   3969   3971   98.3    0.2804   5.2844      0.1090
   3980   3981   90.0    0.2871   0.3412      0.1080
   1811   1812   90.0    0.0957   0.5598      0.1090
   1813   1814   90.0    3.8905   0.7083      0.1090
   1813   1816   90.0    3.9632  18.7577      0.1090
   1817   1818   90.0    0.1679   5.2708      0.1090
   1820   1821   90.0    0.1090   1.3929      0.1090
   1820   1822   90.0    0.1090   1.3820      0.1090
   1820   1823   90.0    0.1565  34.9529      0.1090
   2589   2590   90.0    0.9175   7.8300      0.1080
   2596   2597   90.0    0.1429   0.1758      0.1080
   2712   2713   90.0    2.9174   1.4521      0.1090
   2743   2744   90.0    0.7324   8.1218      0.1090
   2743   2745  107.9    0.1090  28.8564      0.1090
   3695   3696   90.0    0.1758   5.4562      0.1090
   3695   3697   90.0    0.2697   5.2099      0.1090
   1809   1810   90.0    0.2273   0.5567      0.1090
   1846   1848   90.0    0.2644   1.3768      0.1090
   1849   1850   90.0    0.9625   3.8481      0.1090
   1849   1851   90.0    1.0533   3.8508      0.1090
   2568   2569   90.0    0.0957   0.1832      0.1010
   2570   2571   90.0    4.3239   0.7156      0.1090
   2572   2573   90.0    0.2134   0.2034      0.1090
   2572   2574   90.0    0.2981   0.1973      0.1090
   2583   2584  130.3    0.2043  17.0944      0.1090
   3765   3766   90.0    0.2262   0.6822      0.1090
   3767   3768   90.0    0.5670   9.9597      0.1090
   3773   3774   90.0    0.2085   3.5425      0.1010
   3779   3781   90.0    0.1473   0.9097      0.1090
   2538   2539   90.0    0.1514   0.9233      0.1010
   2538   2541   90.0    3.9077   2.1298      0.1010
    689    690   90.0    0.1236   3.0329      0.1090
    712    713   90.0    0.4285   0.4445      0.1090
    714    716   90.0    0.2052   0.5545      0.1090
    717    719   90.0    4.6208   4.4334      0.1090
    720    721   90.0    0.1090  20.9946      0.1090
    720    722   90.0    0.1552  22.2096      0.1090
    723    724   90.0    0.1090   0.2717      0.1090
   1116   1118   90.0    0.5591   0.5412      0.1090
   1738   1739   90.0    0.2121   0.3723      0.1090
   1777   1778   90.0    0.7630 113.2012      0.1090
   1777   1779   90.0    0.8289 112.4427      0.1090
   4017   4018   90.0    0.0957   0.2896      0.1010
   4021   4022   90.0    0.1514   5.8779      0.1090
   4021   4023   90.0    0.5614  12.9137      0.1090
   4027   4028   90.0    0.1514   4.2149      0.1090
   2592   2593   90.0    0.0957   0.1759      0.0960
   2633   2634   90.0    0.0957   0.3069      0.1090
   2602   2603   90.0    0.0957   0.2395      0.1090
   2609   2610   90.0    0.1514   1.1208      0.1010
   7592   7593   90.0    1.2159  98.9983      0.1092
   7629   7630   90.0    1.0133  63.1244      0.1010
t = 46510.301 ps: Water molecule starting at atom 82915 can not be settled.
Check for bad contacts and/or reduce the timestep.
Wrote pdb files with previous and current coordinates
A list of missing interactions:
              Settle of  41097 missing     -8
          exclusions of 249888 missing    615
Program mdrun, VERSION 3.3.99_development_200800503
Source code file: domdec_top.c, line: 87
Software inconsistency error:
Some interactions seem to be assigned multiple times
Thanx for Using GROMACS - Have a Nice Day
Error on node 3, will try to stop all the nodes
Halting parallel program mdrun on CPU 3 out of 4
gcq#0: Thanx for Using GROMACS - Have a Nice Day
[cli_3]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
[13:50:50]
[13:50:50] Folding@home Core Shutdown: INTERRUPTED
[cli_0]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 102) - process 0
FAHlog.txt:
--- Opening Log file [February 2 21:34:40 UTC]
# Linux SMP Console Edition ###################################################
                       Folding@Home Client Version 6.24beta
                          http://folding.stanford.edu
Launch directory: /share/fah1
Executable: ./fah6
Arguments: -smp 4
[21:34:40] - Ask before connecting: No
[21:34:40] - User name: alpha754293 (Team 596)
[21:34:40] - User ID: 47FBD1D4056DB49E
[21:34:40] - Machine ID: 1
[21:34:40]
[21:34:41] Loaded queue successfully.
[21:34:41]
[21:34:41] + Processing work unit
[21:34:41] Core required: FahCore_a2.exe
[21:34:41] Core found.
[21:34:41] Working on queue slot 03 [February 2 21:34:41 UTC]
[21:34:41] + Working ...
[21:34:41]
[21:34:41] *------------------------------*
[21:34:41] Folding@Home Gromacs SMP Core
[21:34:41] Version 2.01 (Wed Aug 13 13:11:25 PDT 2008)
[21:34:41]
[21:34:41] Preparing to commence simulation
[21:34:41] - Ensuring status. Please wait.
[21:34:42] Called DecompressByteArray: compressed_data_size=4843187 data_size=23991465, decompressed_data_size=23991465 diff=0
[21:34:42] - Digital signature verified
[21:34:42]
[21:34:42] Project: 2669 (Run 4, Clone 130, Gen 93)
[21:34:42]
[21:34:42] Assembly optimizations on if available.
[21:34:42] Entering M.D.
[21:34:48] Will resume from checkpoint file
[21:34:52] ng M.D.
[21:34:58] Will resume from checkpoint file
[21:34:59] Resuming from checkpoint
[21:34:59] Verified work/wudata_03.log
[21:34:59] Verified work/wudata_03.trr
[21:34:59] Verified work/wudata_03.xtc
[21:34:59] Verified work/wudata_03.edr
[21:34:59] Completed 5010 out of 250000 steps  (2%)
[21:43:52] Completed 7500 out of 250000 steps  (3%)
CTRL+C to exit to shell.
Restarted the client, and seems to be running ok for the time being.
Re: Project: 2669 (Run 4, Clone 130, Gen 93)
There's no data for this WU in the DB yet ...
alpha754293
currently resuming from checkpoint. 27% complete. ETA: Feb 3 11:48 UTC 2009
alpha754293
FInished running.
Hi alpha754293 (team 596),
Your WU (P2669 R4 C130 G93) was added to the stats database on 2009-02-03 18:27:24 for 1920 points of credit.
alpha754293
bruce wrote:Hi alpha754293 (team 596),
Thank you.
