Project: 2671 (Run 20, Clone 12, Gen 77)
bollix47
Post by bollix47 »
i7 940 @ stock
Ubuntu 8.04
6.24 with -smp 8 -verbosity 9 -advmethods
core version 2.01
Not sure what to make of this one:
[18:06:20] Completed 155008 out of 250000 steps  (62%)
[18:11:07] Completed 157508 out of 250000 steps  (63%)
[18:15:50] Completed 160008 out of 250000 steps  (64%)
[18:20:36] Completed 162508 out of 250000 steps  (65%)
[18:25:22] Completed 165008 out of 250000 steps  (66%)
Step 19415958, time 38831.9 (ps)  LINCS WARNING
relative constraint deviation after LINCS:
rms 0.056375, max 1.843163 (between atoms 5579 and 5581)
rms 0.029260, max 1.843163 (between atoms 5579 and 5581)
bonds that rotated more than 90 degrees:
 atom 1 atom 2  angle  previous, current, constraint length
   5579   5581   90.0    0.1090   0.3099      0.1090
   5576   5577   90.0    0.1090   0.2778      0.1090
Step 19415959, time 38831.9 (ps)  LINCS WARNING
rms 1.108131, max 69.803444 (between atoms 5579 and 5581)
   5579   5581   90.0    0.3099   7.7176      0.1090
rms 1.378295, max 69.803444 (between atoms 5579 and 5581)
   5569   5570   90.0    0.1010   0.2150      0.1010
   5576   5577   90.0    0.2778   0.3789      0.1090
t = 38831.922 ps: Water molecule starting at atom 110713 can not be settled.
Check for bad contacts and/or reduce the timestep.
Wrote pdb files with previous and current coordinates
Step 19415960:
The charge group starting at atom 5581 moved than the distance allowed by the domain decomposition (1.200000) in direction X
distance out of cell -15.704895
Old coordinates:    0.628    4.004   11.131
New coordinates:  -15.705    4.169    0.643
Old cell boundaries in direction X:    0.000    5.089
New cell boundaries in direction X:    0.000    5.271
Program mdrun, VERSION 3.3.99_development_200800503
Source code file: domdec.c, line: 2644
Fatal error:
A charge group move too far between two domain decomposition steps
Thanx for Using GROMACS - Have a Nice Day
Error on node 3, will try to stop all the nodes
Halting parallel program mdrun on CPU 3 out of 8
gcq#0: Thanx for Using GROMACS - Have a Nice Day
[cli_3]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
[18:27:10]
[18:27:10] Folding@home Core Shutdown: INTERRUPTED
[cli_0]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 102) - process 0
[cli_1]: aborting job:
Fatal error in MPI_Sendrecv: Error message texts are not available
[cli_2]: aborting job:
[cli_7]: aborting job:
[19:33:44] - Autosending finished units... [February 2 19:33:44 UTC]
[19:33:44] Trying to send all finished work units
[19:33:44] + No unsent completed units remaining.
[19:33:44] - Autosend completed
Restarted it and the WU progressed on to 67% ... 68%. :roll:
Re: Project: 2671 (Run 20, Clone 12, Gen 77)
Strange :
Hi bollix47 (team 39340),
Your WU (P2671 R20 C12 G77) was added to the stats database on 2009-02-02 15:23:37 for 1920 points of credit.
There are 3 additional reports for full credit for this WU ...
