Project: 3858 (Run 5043, Clone 0, Gen 34) Fractional Credit
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hello,
Per a recent attempt on Project: 3858 (Run 5043, Clone 0, Gen 34). My computer successfully completed about 94 percent of this job before it failed/ended with a mdrun returned -1 after about 21 hours of work. Instead of a possible 450 points, I only get 9. :( This is about the third or fourth time a job failed to finish, this one was closest to completion with a nice number of points lost. Most were in the 385x series from the past few weeks or so. Seems one would get more points, especially being so close to completion....
Is there a reason some of the jobs are failing to complete ~ could one be -advmethods setting in the client's configuration? This has helped me on the whole gain more points despite an 'aging' platform, compared to folding without it. I thought this system was underpowered to use a 'high performance' client, but reading through the documentation is giving me second thoughts. Thought you needed a 4-core machine for that, or it was recommended. A GPU upgrade is out of the question with my current setup; as my ATI Radeon X1600 Pro graphic card is too old for what you are doing now. I am folding 24/7 except when thunderstorms get too close or for maintenance.
Current FAH settings on this AMD-X2 4200 platform with 1 gig of RAM --- slightly overclocked.
Using CPU Client, created 6.23 November 23, 2008
  • set at 'lowest possible' core priority
    but uses all of the CPU when it is folding
    am using -advmethods as my only additional parameter
    checks progress of a job every 9 or 10 minutes or so
    no other settings under 'Advanced' is checked
Thanks,
Robby /// Team Firefox
[02:31:47] Timer requesting checkpoint
[02:34:22] Completed 1000000 out of 1000000 steps  (100%)
[02:35:23]
[02:35:23] Finished Work Unit:
[02:35:23] - Reading up to 400592 from "work/wudata_07.trr": Read 400592
[02:35:23] - Reading up to 23180 from "work/wudata_07.xtc": Read 23180
[02:35:23] xvg file size: 321369
[02:35:23] logfile size: 37410
[02:35:23] Leaving Run
[02:35:26] - Writing 867243 bytes of core data to disk...
[02:35:26]   ... Done.
[02:35:26] - Shutting down core
[02:35:26]
[02:35:26] Folding@home Core Shutdown: FINISHED_UNIT
[02:35:30] CoreStatus = 64 (100)
[02:35:30] Sending work to server
[02:35:30] Project: 3859 (Run 9055, Clone 0, Gen 5)
[02:35:30] + Attempting to send results [February 1 02:35:30 UTC]
[02:35:31] - Couldn't send HTTP request to server
[02:35:31]   (Got status 503)
[02:35:31] + Could not connect to Work Server (results)
[02:35:31]     (128.59.74.4:8080)
[02:35:31] + Retrying using alternative port
[02:35:31]     (128.59.74.4:80)
[02:35:31] - Error: Could not transmit unit 07 (completed February 1) to work server.
[02:35:31]   Keeping unit 07 in queue.
[02:35:31] Project: 3859 (Run 9055, Clone 0, Gen 5)
[02:35:31] + Attempting to send results [February 1 02:35:31 UTC]
[02:35:34] - Couldn't send HTTP request to server
[02:35:34]   (Got status 503)
[02:35:34] + Could not connect to Work Server (results)
[02:35:34]     (128.59.74.4:8080)
[02:35:34] + Retrying using alternative port
[02:35:34]     (128.59.74.4:80)
[02:35:34] - Error: Could not transmit unit 07 (completed February 1) to work server.
[02:35:34] + Attempting to send results [February 1 02:35:34 UTC]
[02:35:54] - Server reports packet it received specified a data size of 0.
[02:35:54]   (May be due to corruption during network transmission or a corrupted file.)
[02:35:54]   Could not transmit unit 07 to Collection server; keeping in queue.
[02:35:54] - Preparing to get new work unit...
[02:35:54] + Attempting to get work packet
[02:35:54] - Connecting to assignment server
[02:35:55] - Successful: assigned to (128.59.74.4).
[02:35:55] + News From Folding@Home: Welcome to Folding@Home
[02:35:55] Loaded queue successfully.
[02:35:55] - Couldn't send HTTP request to server
[02:35:55]   (Got status 503)
[02:35:55] + Could not connect to Work Server
[02:35:55] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[02:36:01] + Attempting to get work packet
[02:36:01] - Connecting to assignment server
[02:36:01] - Successful: assigned to (128.59.74.4).
[02:36:01] + News From Folding@Home: Welcome to Folding@Home
[02:36:01] Loaded queue successfully.
[02:36:01] - Couldn't send HTTP request to server
[02:36:01]   (Got status 503)
[02:36:01] + Could not connect to Work Server
[02:36:01] - Attempt #2  to get work failed, and no other work to do.
[02:36:26] + Attempting to get work packet
[02:36:26] - Connecting to assignment server
[02:36:26] - Successful: assigned to (128.59.74.4).
[02:36:26] + News From Folding@Home: Welcome to Folding@Home
[02:36:26] Loaded queue successfully.
[02:36:30] Project: 3859 (Run 9055, Clone 0, Gen 5)
[02:36:30] + Attempting to send results [February 1 02:36:30 UTC]
[02:36:30] - Couldn't send HTTP request to server
[02:36:30]   (Got status 503)
[02:36:30] + Could not connect to Work Server (results)
[02:36:30]     (128.59.74.4:8080)
[02:36:30] + Retrying using alternative port
[02:36:51] + Results successfully sent
[02:36:51] Thank you for your contribution to Folding@Home.
[02:36:51] + Number of Units Completed: 397
[02:36:51] + Closed connections
[02:36:51]
[02:36:51] + Processing work unit
[02:36:51] Core required: FahCore_7c.exe
[02:36:51] Core found.
[02:36:51] Working on queue slot 08 [February 1 02:36:51 UTC]
[02:36:51] + Working ...
[02:36:52]
[02:36:52] *------------------------------*
[02:36:52] Folding@Home Double Gromacs Core C
[02:36:52] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[02:36:52]
[02:36:52] Preparing to commence simulation
[02:36:52] - Files status OK
[02:36:52] - Expanded 1200473 -> 3324453 (decompressed 276.9 percent)
[02:36:52]
[02:36:52] Project: 3858 (Run 5043, Clone 0, Gen 34)
[02:36:52]
[02:36:52] Assembly optimizations on if available.
[02:36:52] Entering M.D.
[02:37:01] Working on p3851_fkbprelative_complex
[02:37:01] Completed 0 out of 200000 steps  (0%)
[02:37:01] Extra SSE2 boost OK
[02:46:02] Timer requesting checkpoint
[02:50:15] Completed 2000 out of 200000 steps  (1%)
[02:59:16] Timer requesting checkpoint
[03:03:22] Completed 4000 out of 200000 steps  (2%)
[03:12:24] Timer requesting checkpoint
[03:16:29] Completed 6000 out of 200000 steps  (3%)
[03:25:30] Timer requesting checkpoint
[03:29:35] Completed 8000 out of 200000 steps  (4%)
[03:38:36] Timer requesting checkpoint
[03:42:42] Completed 10000 out of 200000 steps  (5%)
[03:51:43] Timer requesting checkpoint
[03:55:49] Completed 12000 out of 200000 steps  (6%)
[04:04:51] Timer requesting checkpoint
[04:08:55] Completed 14000 out of 200000 steps  (7%)
[04:17:57] Timer requesting checkpoint
[04:22:02] Completed 16000 out of 200000 steps  (8%)
[04:31:03] Timer requesting checkpoint
[04:35:07] Completed 18000 out of 200000 steps  (9%)
[04:44:09] Timer requesting checkpoint
[04:48:17] Completed 20000 out of 200000 steps  (10%)
[04:57:18] Timer requesting checkpoint
[05:01:27] Completed 22000 out of 200000 steps  (11%)
[05:10:28] Timer requesting checkpoint
[05:14:33] Completed 24000 out of 200000 steps  (12%)
[05:23:34] Timer requesting checkpoint
[05:27:39] Completed 26000 out of 200000 steps  (13%)
[05:36:41] Timer requesting checkpoint
[05:40:44] Completed 28000 out of 200000 steps  (14%)
[05:49:46] Timer requesting checkpoint
[05:53:51] Completed 30000 out of 200000 steps  (15%)
[06:02:52] Timer requesting checkpoint
[06:06:59] Completed 32000 out of 200000 steps  (16%)
[06:16:01] Timer requesting checkpoint
[06:20:05] Completed 34000 out of 200000 steps  (17%)
[06:29:06] Timer requesting checkpoint
[06:33:12] Completed 36000 out of 200000 steps  (18%)
[06:34:24] + Working...
[06:42:13] Timer requesting checkpoint
[06:46:19] Completed 38000 out of 200000 steps  (19%)
[06:55:20] Timer requesting checkpoint
[06:59:27] Completed 40000 out of 200000 steps  (20%)
[07:08:28] Timer requesting checkpoint
[07:12:33] Completed 42000 out of 200000 steps  (21%)
[07:21:35] Timer requesting checkpoint
[07:25:39] Completed 44000 out of 200000 steps  (22%)
[07:34:40] Timer requesting checkpoint
[07:38:44] Completed 46000 out of 200000 steps  (23%)
[07:47:46] Timer requesting checkpoint
[07:51:52] Completed 48000 out of 200000 steps  (24%)
[08:00:53] Timer requesting checkpoint
[08:04:59] Completed 50000 out of 200000 steps  (25%)
[08:14:00] Timer requesting checkpoint
[08:18:07] Completed 52000 out of 200000 steps  (26%)
[08:27:08] Timer requesting checkpoint
[08:31:15] Completed 54000 out of 200000 steps  (27%)
[08:40:16] Timer requesting checkpoint
[08:44:22] Completed 56000 out of 200000 steps  (28%)
[08:53:24] Timer requesting checkpoint
[08:57:29] Completed 58000 out of 200000 steps  (29%)
[09:06:30] Timer requesting checkpoint
[09:10:36] Completed 60000 out of 200000 steps  (30%)
[09:19:38] Timer requesting checkpoint
[09:23:45] Completed 62000 out of 200000 steps  (31%)
[09:32:46] Timer requesting checkpoint
[09:36:52] Completed 64000 out of 200000 steps  (32%)
[09:45:53] Timer requesting checkpoint
[09:50:00] Completed 66000 out of 200000 steps  (33%)
[09:59:01] Timer requesting checkpoint
[10:03:07] Completed 68000 out of 200000 steps  (34%)
[10:12:08] Timer requesting checkpoint
[10:16:23] Completed 70000 out of 200000 steps  (35%)
[10:25:25] Timer requesting checkpoint
[10:29:29] Completed 72000 out of 200000 steps  (36%)
[10:38:30] Timer requesting checkpoint
[10:42:36] Completed 74000 out of 200000 steps  (37%)
[10:51:37] Timer requesting checkpoint
[10:55:42] Completed 76000 out of 200000 steps  (38%)
[11:04:43] Timer requesting checkpoint
[11:08:49] Completed 78000 out of 200000 steps  (39%)
[11:17:50] Timer requesting checkpoint
[11:21:55] Completed 80000 out of 200000 steps  (40%)
[11:30:57] Timer requesting checkpoint
[11:35:03] Completed 82000 out of 200000 steps  (41%)
[11:44:04] Timer requesting checkpoint
[11:48:08] Completed 84000 out of 200000 steps  (42%)
[11:57:10] Timer requesting checkpoint
[12:01:15] Completed 86000 out of 200000 steps  (43%)
[12:10:16] Timer requesting checkpoint
[12:14:22] Completed 88000 out of 200000 steps  (44%)
[12:23:23] Timer requesting checkpoint
[12:27:29] Completed 90000 out of 200000 steps  (45%)
[12:34:24] + Working...
[12:36:30] Timer requesting checkpoint
[12:40:35] Completed 92000 out of 200000 steps  (46%)
[12:49:37] Timer requesting checkpoint
[12:53:42] Completed 94000 out of 200000 steps  (47%)
[13:02:43] Timer requesting checkpoint
[13:06:50] Completed 96000 out of 200000 steps  (48%)
[13:15:51] Timer requesting checkpoint
[13:19:58] Completed 98000 out of 200000 steps  (49%)
[13:28:59] Timer requesting checkpoint
[13:33:04] Completed 100000 out of 200000 steps  (50%)
[13:42:06] Timer requesting checkpoint
[13:46:10] Completed 102000 out of 200000 steps  (51%)
[13:55:11] Timer requesting checkpoint
[13:59:18] Completed 104000 out of 200000 steps  (52%)
[14:08:19] Timer requesting checkpoint
[14:12:25] Completed 106000 out of 200000 steps  (53%)
[14:21:26] Timer requesting checkpoint
[14:25:32] Completed 108000 out of 200000 steps  (54%)
[14:34:33] Timer requesting checkpoint
[14:38:39] Completed 110000 out of 200000 steps  (55%)
[14:47:40] Timer requesting checkpoint
[14:51:46] Completed 112000 out of 200000 steps  (56%)
[15:00:47] Timer requesting checkpoint
[15:04:53] Completed 114000 out of 200000 steps  (57%)
[15:13:55] Timer requesting checkpoint
[15:18:01] Completed 116000 out of 200000 steps  (58%)
[15:27:03] Timer requesting checkpoint
[15:31:11] Completed 118000 out of 200000 steps  (59%)
[15:40:13] Timer requesting checkpoint
[15:44:45] Completed 120000 out of 200000 steps  (60%)
[15:53:46] Timer requesting checkpoint
[15:58:18] Completed 122000 out of 200000 steps  (61%)
[16:07:19] Timer requesting checkpoint
[16:12:32] Completed 124000 out of 200000 steps  (62%)
[16:21:33] Timer requesting checkpoint
[16:26:01] Completed 126000 out of 200000 steps  (63%)
[16:35:03] Timer requesting checkpoint
[16:39:30] Completed 128000 out of 200000 steps  (64%)
[16:48:33] Timer requesting checkpoint
[16:53:18] Completed 130000 out of 200000 steps  (65%)
[17:02:20] Timer requesting checkpoint
[17:07:05] Completed 132000 out of 200000 steps  (66%)
[17:16:08] Timer requesting checkpoint
[17:21:07] Completed 134000 out of 200000 steps  (67%)
[17:30:08] Timer requesting checkpoint
[17:34:50] Completed 136000 out of 200000 steps  (68%)
[17:43:51] Timer requesting checkpoint
[17:47:56] Completed 138000 out of 200000 steps  (69%)
[17:56:57] Timer requesting checkpoint
[18:01:03] Completed 140000 out of 200000 steps  (70%)
[18:10:04] Timer requesting checkpoint
[18:14:11] Completed 142000 out of 200000 steps  (71%)
[18:23:12] Timer requesting checkpoint
[18:27:17] Completed 144000 out of 200000 steps  (72%)
[18:34:24] + Working...
[18:36:18] Timer requesting checkpoint
[18:40:25] Completed 146000 out of 200000 steps  (73%)
[18:49:26] Timer requesting checkpoint
[18:53:31] Completed 148000 out of 200000 steps  (74%)
[19:02:33] Timer requesting checkpoint
[19:06:39] Completed 150000 out of 200000 steps  (75%)
[19:15:41] Timer requesting checkpoint
[19:19:45] Completed 152000 out of 200000 steps  (76%)
[19:28:47] Timer requesting checkpoint
[19:32:52] Completed 154000 out of 200000 steps  (77%)
[19:41:54] Timer requesting checkpoint
[19:45:59] Completed 156000 out of 200000 steps  (78%)
[19:55:01] Timer requesting checkpoint
[19:59:06] Completed 158000 out of 200000 steps  (79%)
[20:08:08] Timer requesting checkpoint
[20:12:12] Completed 160000 out of 200000 steps  (80%)
[20:21:15] Timer requesting checkpoint
[20:25:20] Completed 162000 out of 200000 steps  (81%)
[20:34:22] Timer requesting checkpoint
[20:38:27] Completed 164000 out of 200000 steps  (82%)
[20:47:29] Timer requesting checkpoint
[20:51:34] Completed 166000 out of 200000 steps  (83%)
[21:00:36] Timer requesting checkpoint
[21:04:40] Completed 168000 out of 200000 steps  (84%)
[21:13:43] Timer requesting checkpoint
[21:17:47] Completed 170000 out of 200000 steps  (85%)
[21:26:49] Timer requesting checkpoint
[21:30:52] Completed 172000 out of 200000 steps  (86%)
[21:39:54] Timer requesting checkpoint
[21:43:59] Completed 174000 out of 200000 steps  (87%)
[21:53:01] Timer requesting checkpoint
[21:57:06] Completed 176000 out of 200000 steps  (88%)
[22:06:08] Timer requesting checkpoint
[22:10:12] Completed 178000 out of 200000 steps  (89%)
[22:19:14] Timer requesting checkpoint
[22:23:18] Completed 180000 out of 200000 steps  (90%)
[22:32:20] Timer requesting checkpoint
[22:36:25] Completed 182000 out of 200000 steps  (91%)
[22:45:27] Timer requesting checkpoint
[22:49:31] Completed 184000 out of 200000 steps  (92%)
[22:58:33] Timer requesting checkpoint
[23:02:39] Completed 186000 out of 200000 steps  (93%)
[23:11:41] Timer requesting checkpoint
[23:15:46] Completed 188000 out of 200000 steps  (94%)
[23:16:51] mdrun returned -1
[23:16:51] Going to send back what have done.
[23:16:51] logfile size: 138268
[23:16:51] - Writing 138806 bytes of core data to disk...
[23:16:51]   ... Done.
[23:16:51]
[23:16:51] Folding@home Core Shutdown: EARLY_UNIT_END
[23:16:53] CoreStatus = 72 (114)
[23:16:53] Sending work to server
[23:16:53] Project: 3858 (Run 5043, Clone 0, Gen 34)
[23:16:53] + Attempting to send results [February 1 23:16:53 UTC]
[23:16:59] + Results successfully sent
[23:16:59] Thank you for your contribution to Folding@Home.
[23:17:03] - Preparing to get new work unit...
[23:17:03] + Attempting to get work packet
[23:17:03] - Connecting to assignment server
[23:17:03] - Successful: assigned to (128.59.74.4).
[23:17:03] + News From Folding@Home: Welcome to Folding@Home
[23:17:03] Loaded queue successfully.
[23:17:07] - Couldn't send HTTP request to server
[23:17:07]   (Got status 503)
[23:17:07] + Could not connect to Work Server
[23:17:07] - Attempt #1  to get work failed, and no other work to do.
[23:17:26] + Attempting to get work packet
[23:17:26] - Connecting to assignment server
[23:17:26] - Successful: assigned to (128.59.74.4).
[23:17:26] + News From Folding@Home: Welcome to Folding@Home
[23:17:26] Loaded queue successfully.
[23:17:27] - Couldn't send HTTP request to server
[23:17:27]   (Got status 503)
[23:17:27] + Could not connect to Work Server
[23:17:27] - Attempt #2  to get work failed, and no other work to do.
[23:17:45] + Attempting to get work packet
[23:17:45] - Connecting to assignment server
[23:17:46] - Successful: assigned to (128.59.74.4).
[23:17:46] + News From Folding@Home: Welcome to Folding@Home
[23:17:46] Loaded queue successfully.
[23:17:52] + Closed connections
[23:17:57]
[23:17:57] + Processing work unit
[23:17:57] Core required: FahCore_7c.exe
[23:17:57] Core found.
[23:17:57] Working on queue slot 09 [February 1 23:17:57 UTC]
[23:17:57] + Working ...
[23:17:57]
[23:17:57] *------------------------------*
[23:17:57] Folding@Home Double Gromacs Core C
[23:17:57] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[23:17:57]
[23:17:57] Preparing to commence simulation
[23:17:57] - Files status OK
[23:17:58] - Expanded 1266758 -> 3498433 (decompressed 276.1 percent)
[23:17:58]
[23:17:58] Project: 3855 (Run 509, Clone 1, Gen 30)
[23:17:58]
[23:17:58] Assembly optimizations on if available.
[23:17:58] Entering M.D.
[23:18:07] Working on p3851_fkbprelative_complex
[23:18:07] Completed 0 out of 200000 steps  (0%)
[23:18:07] Extra SSE2 boost OK
[23:27:08] Timer requesting checkpoint
[23:32:22] Completed 2000 out of 200000 steps  (1%)
[23:41:24] Timer requesting checkpoint
[23:46:30] Completed 4000 out of 200000 steps  (2%)
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Project: 3858 (Run 5043, Clone 0, Gen 34) Fractional Credit
Did you try do fold without overclocking ?
You are the only one to have returned this WU for the time being :
Hi Robby (team 39299),
Your WU (P3858 R5043 C0 G34) was added to the stats database on 2009-02-01 15:44:24 for 9.69 points of credit.
Robby_Firefox
Hi toTOW,
When folding earlier, I was doing it without overclocking. Am overclocking around 10 percent and have not noticed any significant system instability or other unwanted behavior. Started the overclocking about three months ago, have been folding since December 2006.
Is there a way I can continue folding (or restart) (P3858 R5043 C0 G34), or is someone else bound to get it? And for the points awarded, why the 9.69 points. Would not it rounded up to 10 points; as would 9.35 remain 9 points?
Thanks,
Someone else will get the WU ... that will be interesting to see if he'll be able to complete it (issue on your machine) or not (issue with the WU).
In the old days of FAH, some WU were worth fractional points, and the stats system used to display them. But with the point inflation, and all WUs being worth exact values, the fractional numbers are no longer displayed. But don't worry, they are here, and will add up if you get more factional points.
The next person to get this WU completed it successfully. That supports toTOW's suggestion:
Robby_Firefox
Hello Folks,
I have turned off the overclocking, and the machine seems to be a bit more stable at least when it comes to folding operations. That may have been the problem all along. It did save some time, but the problems it caused are more than the time saved (if a job did not crash, end before it should, etc.). Sort of like getting a speeding ticket for driving too fast, eh? :wink:
Thanks for the advice,
Robby / Team Firefox
