Project: 5757 (Run 1, Clone 95, Gen 272)
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
Post by SKeptical_Thinker »
[15:30:56]
[15:30:56] + Processing work unit
[15:30:56] Core required: FahCore_11.exe
[15:30:56] Core found.
[15:30:56] Working on queue slot 07 [February 1 15:30:56 UTC]
[15:30:56] + Working ...
[15:30:56]
[15:30:56] *------------------------------*
[15:30:56] Folding@Home GPU Core - Beta
[15:30:56] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:30:56]
[15:30:56] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:30:56] Build host: amoeba
[15:30:56] Board Type: Nvidia
[15:30:56] Core      :
[15:30:56] Preparing to commence simulation
[15:30:56] - Looking at optimizations...
[15:30:56] - Created dyn
[15:30:56] - Files status OK
[15:30:56] - Expanded 70219 -> 360060 (decompressed 512.7 percent)
[15:30:56] Called DecompressByteArray: compressed_data_size=70219 data_size=360060, decompressed_data_size=360060 diff=0
[15:30:56] - Digital signature verified
[15:30:56]
[15:30:56] Project: 5757 (Run 1, Clone 95, Gen 272)
[15:30:56]
[15:30:56] Assembly optimizations on if available.
[15:30:56] Entering M.D.
[15:31:03] Working on Protein
[15:31:04] Client config found, loading data.
[15:31:04] Starting GUI Server
[15:32:25] Completed 1%
[15:33:46] Completed 2%
[15:35:07] Completed 3%
[15:36:31] Completed 4%
[15:37:52] Completed 5%
[15:39:15] Completed 6%
[15:40:40] Completed 7%
[15:42:01] Completed 8%
[15:43:22] Completed 9%
[15:44:42] Completed 10%
[15:46:03] Completed 11%
[15:47:24] Completed 12%
[15:48:45] Completed 13%
[15:50:06] Completed 14%
[15:51:27] Completed 15%
[15:52:47] Completed 16%
[15:54:07] Completed 17%
[15:55:28] Completed 18%
[15:56:48] Completed 19%
[15:58:08] Completed 20%
[15:59:29] Completed 21%
[16:00:49] Completed 22%
[16:02:09] Completed 23%
[16:03:29] Completed 24%
[16:04:52] Completed 25%
[16:06:13] Completed 26%
[16:07:23] Run: exception thrown during GuardedRun
[16:07:23] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[16:07:23] Going to send back what have done -- stepsTotalG=10000000
[16:07:23] Work fraction=0.2684 steps=10000000.
[16:07:27] logfile size=14833 infoLength=14833 edr=0 trr=23
[16:07:27] - Writing 15369 bytes of core data to disk...
[16:07:27] Done: 14857 -> 4504 (compressed to 30.3 percent)
[16:07:27]   ... Done.
[16:07:27]
[16:07:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:07:30] CoreStatus = 7A (122)
[16:07:30] Sending work to server
[16:07:30] Project: 5757 (Run 1, Clone 95, Gen 272)
[16:07:30] - Read packet limit of 540015616... Set to 524286976.
Re: Project: 5757 (Run 1, Clone 95, Gen 272)
Hi SKeptical_Thinker (team 31574),
Your WU (P5757 R1 C95 G272) was added to the stats database on 2009-02-01 09:31:39 for 103.08 points of credit.
There's no other entry in the DB for this WU ...
toTOW wrote:There's no other entry in the DB for this WU ...
The next person was able to complete that WU successfully so you probably should look for a hardware or driver problem.
