Project 4743 (Run 6, Clone 819, Gen 47)
joshH
Post by joshH »
Had no problems completing other WU's 100%. Woke up and saw this. Restarted the client, downloaded another WU, and everything is fine now (currently on Projectc 5747 (Run 0, Clone 38, Gen 128)).
[11:20:57] *------------------------------*
[11:20:57] Folding@Home GPU Core - Beta
[11:20:57] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[11:20:57]
[11:20:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:20:57] Build host: amoeba
[11:20:57] Board Type: AMD
[11:20:57] Core      :
[11:20:57] Preparing to commence simulation
[11:20:57] - Looking at optimizations...
[11:20:57] - Created dyn
[11:20:57] - Files status OK
[11:20:57] - Expanded 88362 -> 447304 (decompressed 506.2 percent)
[11:20:57] Called DecompressByteArray: compressed_data_size=88362 data_size=447304, decompressed_data_size=447304 diff=0
[11:20:57] - Digital signature verified
[11:20:57]
[11:20:57] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:20:57]
[11:20:57] Assembly optimizations on if available.
[11:20:57] Entering M.D.
[11:21:03] Working on p4743_lam5w_300K
[11:21:03] Client config found, loading data.
[11:21:03] Starting GUI Server
[11:21:07] mdrun_gpu returned
[11:21:07] SHAKE violations on GPU
[11:21:07]
[11:21:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:21:11] CoreStatus = 7A (122)
[11:21:11] Sending work to server
[11:21:11] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:21:11] - Read packet limit of 540015616... Set to 524286976.
[11:21:11] - Error: Could not get length of results file work/wuresults_01.dat
[11:21:11] - Error: Could not read unit 01 file. Removing from queue.
[11:21:11] - Preparing to get new work unit...
[11:21:11] + Attempting to get work packet
[11:21:11] - Connecting to assignment server
[11:21:11] - Successful: assigned to (171.64.65.103).
[11:21:11] + News From Folding@Home: GPU folding beta
[11:21:11] Loaded queue successfully.
[11:21:12] + Closed connections
[11:21:17]
[11:21:17] + Processing work unit
[11:21:17] Core required: FahCore_11.exe
[11:21:17] Core found.
[11:21:17] Working on queue slot 02 [January 30 11:21:17 UTC]
[11:21:17] + Working ...
[11:21:17]
[11:21:17] *------------------------------*
[11:21:17] Folding@Home GPU Core - Beta
[11:21:17] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[11:21:17]
[11:21:17] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:21:17] Build host: amoeba
[11:21:17] Board Type: AMD
[11:21:17] Core      :
[11:21:17] Preparing to commence simulation
[11:21:17] - Looking at optimizations...
[11:21:17] - Created dyn
[11:21:17] - Files status OK
[11:21:17] - Expanded 88362 -> 447304 (decompressed 506.2 percent)
[11:21:17] Called DecompressByteArray: compressed_data_size=88362 data_size=447304, decompressed_data_size=447304 diff=0
[11:21:17] - Digital signature verified
[11:21:17]
[11:21:17] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:21:17]
[11:21:17] Assembly optimizations on if available.
[11:21:17] Entering M.D.
[11:21:24] Working on p4743_lam5w_300K
[11:21:24] Client config found, loading data.
[11:21:24] Starting GUI Server
[11:21:28] mdrun_gpu returned
[11:21:28] SHAKE violations on GPU
[11:21:28]
[11:21:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:21:32] CoreStatus = 7A (122)
[11:21:32] Sending work to server
[11:21:32] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:21:32] - Read packet limit of 540015616... Set to 524286976.
[11:21:32] - Error: Could not get length of results file work/wuresults_02.dat
[11:21:32] - Error: Could not read unit 02 file. Removing from queue.
[11:21:32] - Preparing to get new work unit...
[11:21:32] + Attempting to get work packet
[11:21:32] - Connecting to assignment server
[11:21:32] - Successful: assigned to (171.64.65.103).
[11:21:32] + News From Folding@Home: GPU folding beta
[11:21:32] Loaded queue successfully.
[11:21:33] + Closed connections
[11:21:38]
[11:21:38] + Processing work unit
[11:21:38] Core required: FahCore_11.exe
[11:21:38] Core found.
[11:21:38] Working on queue slot 03 [January 30 11:21:38 UTC]
[11:21:38] + Working ...
[11:21:38]
[11:21:38] *------------------------------*
[11:21:38] Folding@Home GPU Core - Beta
[11:21:38] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[11:21:38]
[11:21:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:21:38] Build host: amoeba
[11:21:38] Board Type: AMD
[11:21:38] Core      :
[11:21:38] Preparing to commence simulation
[11:21:38] - Looking at optimizations...
[11:21:38] - Created dyn
[11:21:38] - Files status OK
[11:21:38] - Expanded 88362 -> 447304 (decompressed 506.2 percent)
[11:21:38] Called DecompressByteArray: compressed_data_size=88362 data_size=447304, decompressed_data_size=447304 diff=0
[11:21:38] - Digital signature verified
[11:21:38]
[11:21:38] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:21:38]
[11:21:38] Assembly optimizations on if available.
[11:21:38] Entering M.D.
[11:21:45] Working on p4743_lam5w_300K
[11:21:45] Client config found, loading data.
[11:21:45] Starting GUI Server
[11:21:49] mdrun_gpu returned
[11:21:49] SHAKE violations on GPU
[11:21:49]
[11:21:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:21:52] CoreStatus = 7A (122)
[11:21:52] Sending work to server
[11:21:52] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:21:52] - Read packet limit of 540015616... Set to 524286976.
[11:21:52] - Error: Could not get length of results file work/wuresults_03.dat
[11:21:52] - Error: Could not read unit 03 file. Removing from queue.
[11:21:52] - Preparing to get new work unit...
[11:21:52] + Attempting to get work packet
[11:21:52] - Connecting to assignment server
[11:21:53] - Successful: assigned to (171.64.65.103).
[11:21:53] + News From Folding@Home: GPU folding beta
[11:21:53] Loaded queue successfully.
[11:21:54] + Closed connections
[11:21:59]
[11:21:59] + Processing work unit
[11:21:59] Core required: FahCore_11.exe
[11:21:59] Core found.
[11:21:59] Working on queue slot 04 [January 30 11:21:59 UTC]
[11:21:59] + Working ...
[11:21:59]
[11:21:59] *------------------------------*
[11:21:59] Folding@Home GPU Core - Beta
[11:21:59] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[11:21:59]
[11:21:59] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:21:59] Build host: amoeba
[11:21:59] Board Type: AMD
[11:21:59] Core      :
[11:21:59] Preparing to commence simulation
[11:21:59] - Looking at optimizations...
[11:21:59] - Created dyn
[11:21:59] - Files status OK
[11:21:59] - Expanded 88362 -> 447304 (decompressed 506.2 percent)
[11:21:59] Called DecompressByteArray: compressed_data_size=88362 data_size=447304, decompressed_data_size=447304 diff=0
[11:21:59] - Digital signature verified
[11:21:59]
[11:21:59] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:21:59]
[11:21:59] Assembly optimizations on if available.
[11:21:59] Entering M.D.
[11:22:06] Working on p4743_lam5w_300K
[11:22:06] Client config found, loading data.
[11:22:06] Starting GUI Server
[11:22:10] mdrun_gpu returned
[11:22:10] SHAKE violations on GPU
[11:22:10]
[11:22:10] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:22:13] CoreStatus = 7A (122)
[11:22:13] Sending work to server
[11:22:13] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:22:13] - Read packet limit of 540015616... Set to 524286976.
[11:22:13] - Error: Could not get length of results file work/wuresults_04.dat
[11:22:13] - Error: Could not read unit 04 file. Removing from queue.
[11:22:13] - Preparing to get new work unit...
[11:22:13] + Attempting to get work packet
[11:22:13] - Connecting to assignment server
[11:22:14] - Successful: assigned to (171.64.65.103).
[11:22:14] + News From Folding@Home: GPU folding beta
[11:22:14] Loaded queue successfully.
[11:22:15] + Closed connections
[11:22:20]
[11:22:20] + Processing work unit
[11:22:20] Core required: FahCore_11.exe
[11:22:20] Core found.
[11:22:20] Working on queue slot 05 [January 30 11:22:20 UTC]
[11:22:20] + Working ...
[11:22:20]
[11:22:20] *------------------------------*
[11:22:20] Folding@Home GPU Core - Beta
[11:22:20] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[11:22:20]
[11:22:20] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:22:20] Build host: amoeba
[11:22:20] Board Type: AMD
[11:22:20] Core      :
[11:22:20] Preparing to commence simulation
[11:22:20] - Looking at optimizations...
[11:22:20] - Created dyn
[11:22:20] - Files status OK
[11:22:20] - Expanded 88362 -> 447304 (decompressed 506.2 percent)
[11:22:20] Called DecompressByteArray: compressed_data_size=88362 data_size=447304, decompressed_data_size=447304 diff=0
[11:22:20] - Digital signature verified
[11:22:20]
[11:22:20] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:22:20]
[11:22:20] Assembly optimizations on if available.
[11:22:20] Entering M.D.
[11:22:26] Working on p4743_lam5w_300K
[11:22:26] Client config found, loading data.
[11:22:26] Starting GUI Server
[11:22:30] mdrun_gpu returned
[11:22:30] SHAKE violations on GPU
[11:22:30]
[11:22:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:22:34] CoreStatus = 7A (122)
[11:22:34] Sending work to server
[11:22:34] Project: 4743 (Run 6, Clone 819, Gen 47)
[11:22:34] - Read packet limit of 540015616... Set to 524286976.
[11:22:34] - Error: Could not get length of results file work/wuresults_05.dat
[11:22:34] - Error: Could not read unit 05 file. Removing from queue.
[11:22:34] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
joshH
Re: Project 4743 (Run 6, Clone 819, Gen 47)
Post by joshH »
Finished that workunit and was assigned this workunit again. Bad WU? Luckily I was watching it when it finished and deleted the work / queue.dat and was assigned another WU.
Currently folding Project 4743 (Run 3, Clone 528, Gen 18) without a problem.
[17:27:57] *------------------------------*
[17:27:57] Folding@Home GPU Core - Beta
[17:27:57] Version 1.22 (Mon Dec 8 12:57:56 PST 2008)
[17:27:57]
[17:27:57] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:27:57] Build host: amoeba
[17:27:57] Board Type: AMD
[17:27:57] Core :
[17:27:57] Preparing to commence simulation
[17:27:57] - Looking at optimizations...
[17:27:57] - Created dyn
[17:27:57] - Files status OK
[17:27:57] - Expanded 88362 -> 447304 (decompressed 506.2 percent)
[17:27:57] Called DecompressByteArray: compressed_data_size=88362 data_size=447304, decompressed_data_size=447304 diff=0
[17:27:57] - Digital signature verified
[17:27:57]
[17:27:57] Project: 4743 (Run 6, Clone 819, Gen 47)
[17:27:57]
[17:27:57] Assembly optimizations on if available.
[17:27:57] Entering M.D.
[17:28:04] Working on p4743_lam5w_300K
[17:28:04] Client config found, loading data.
[17:28:04] Starting GUI Server
[17:28:08] mdrun_gpu returned
[17:28:08] SHAKE violations on GPU
[17:28:08]
[17:28:08] Folding@home Core Shutdown: UNSTABLE_MACHINE
Yes that's a bad WU, there are more than 10 reports of immediate failure in the DB.
I've marked it as bad.
