5101 run 0 Clone 149 Gen 57 { 2 Million steps?}
dschief
- Hardware configuration: Gigabyte Z790 UD AC , i7-14700K (x2) Win11
ASUS Z97_K , i5-4460 (x2) Win10 & UBUNTU 24.04
GPU's ASUS RTX1660 x2, RTX3050 x2
EVGA1060 - Location: California Wine country
This is taking 31 min per % ; Is it ok? It's worth 2165 points! The dead -line is 5 days, so it looks like it will finish under the wire.
dschief
Re: 5101 run 0 Clone 149 Gen 57 { 2 Million steps?}
It seems to be way under pointed, by comparison,the 1920 point wu's I can finish in less than a day. this one "should"
be worth close to 4,000
On what kind of hardware?
dschief
C2D 6400 2.4 Ghz. 2 gig ram; normal wu's usually take 12 1/2 to 13 min per %; This 5101 is taking over 30 min per %
any rate the point boost is only 12.76 % while processing time is double. The minimum value should be 3840
It's an A1 WU ... not an A2. That's why it's so slow.
dschief
Just checked, Have 3 { 5102's } running in addition to the 5101, this is really going to kick the snot out of my PPD
