Project: 5749 (Run 4, Clone 352, Gen 11)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Can you tell I'm catching up on my logs? EUE
[01:07:28] + Closed connections
[01:07:28]
[01:07:28] + Processing work unit
[01:07:28] Core required: FahCore_11.exe
[01:07:28] Core found.
[01:07:28] Working on queue slot 04 [January 21 01:07:28 UTC]
[01:07:28] + Working ...
[01:07:28] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 1940 -version 620'
[01:07:28]
[01:07:28] *------------------------------*
[01:07:28] Folding@Home GPU Core - Beta
[01:07:28] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[01:07:28]
[01:07:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:07:28] Build host: amoeba
[01:07:28] Board Type: Nvidia
[01:07:28] Core      :
[01:07:28] Preparing to commence simulation
[01:07:28] - Looking at optimizations...
[01:07:28] - Created dyn
[01:07:28] - Files status OK
[01:07:28] - Expanded 98696 -> 492276 (decompressed 498.7 percent)
[01:07:28] Called DecompressByteArray: compressed_data_size=98696 data_size=492276, decompressed_data_size=492276 diff=0
[01:07:28] - Digital signature verified
[01:07:28]
[01:07:28] Project: 5749 (Run 4, Clone 352, Gen 11)
[01:07:28]
[01:07:28] Assembly optimizations on if available.
[01:07:28] Entering M.D.
[01:07:35] Working on Protein
[01:07:37] Client config found, loading data.
[01:07:37] Starting GUI Server
[01:09:32] Completed 1%
     {snip}
[02:08:34] Completed 32%
[02:09:27] Run: exception thrown during GuardedRun
[02:09:27] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[02:09:27] Going to send back what have done -- stepsTotalG=10000000
[02:09:27] Work fraction=0.3246 steps=10000000.
[02:09:31] logfile size=15873 infoLength=15873 edr=0 trr=23
[02:09:31] - Writing 16409 bytes of core data to disk...
[02:09:31] Done: 15897 -> 4633 (compressed to 29.1 percent)
[02:09:31]   ... Done.
[02:09:31]
[02:09:31] Folding@home Core Shutdown: EARLY_UNIT_END
[02:09:34] CoreStatus = 72 (114)
[02:09:34] Sending work to server
[02:09:34] Project: 5749 (Run 4, Clone 352, Gen 11)
[02:09:34] - Read packet limit of 540015616... Set to 524286976.
[02:09:34] + Attempting to send results [January 21 02:09:34 UTC]
[02:09:34] - Reading file work/wuresults_04.dat from core
[02:09:34]   (Read 5145 bytes from disk)
[02:09:34] Connecting to http://171.67.108.11:8080/
[02:09:35] Posted data.
[02:09:35] Initial: 0000; - Uploaded at ~6 kB/s
[02:09:35] - Averaged speed for that direction ~51 kB/s
[02:09:35] + Results successfully sent
Re: Project: 5749 (Run 4, Clone 352, Gen 11)
You got partial credit for it.
Hi anko1 (team 47815),
Your WU (P5749 R4 C352 G11) was added to the stats database on 2009-01-20 18:37:51 for 165.87 points of credit.
Someone else was able to complete it successfully.
