Project: 5751 (Run 6, Clone 154, Gen 8)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
Since most of my 57xxs complete successfully, I thought this one might be a bad WU.
[16:06:12] + Closed connections
[16:06:12]
[16:06:12] + Processing work unit
[16:06:12] Core required: FahCore_11.exe
[16:06:12] Core found.
[16:06:12] Working on queue slot 09 [January 18 16:06:12 UTC]
[16:06:12] + Working ...
[16:06:12] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -checkpoint 15 -verbose -lifeline 1940 -version 620'
[16:06:12]
[16:06:12] *------------------------------*
[16:06:12] Folding@Home GPU Core - Beta
[16:06:12] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[16:06:12]
[16:06:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:06:12] Build host: amoeba
[16:06:12] Board Type: Nvidia
[16:06:12] Core      :
[16:06:12] Preparing to commence simulation
[16:06:12] - Looking at optimizations...
[16:06:12] - Created dyn
[16:06:12] - Files status OK
[16:06:12] - Expanded 98610 -> 492276 (decompressed 499.2 percent)
[16:06:12] Called DecompressByteArray: compressed_data_size=98610 data_size=492276, decompressed_data_size=492276 diff=0
[16:06:12] - Digital signature verified
[16:06:12]
[16:06:12] Project: 5751 (Run 6, Clone 154, Gen 8)
[16:06:12]
[16:06:12] Assembly optimizations on if available.
[16:06:12] Entering M.D.
[16:06:19] Working on Protein
[16:06:21] Client config found, loading data.
[16:06:21] Starting GUI Server
[16:06:21] mdrun_gpu returned
[16:06:21] NANs detected on GPU
[16:06:21]
[16:06:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:06:24] CoreStatus = 7A (122)
[16:06:24] Sending work to server
[16:06:24] Project: 5751 (Run 6, Clone 154, Gen 8)
[16:06:24] - Read packet limit of 540015616... Set to 524286976.
[16:06:24] - Error: Could not get length of results file work/wuresults_09.dat
[16:06:24] - Error: Could not read unit 09 file. Removing from queue.
[16:06:24] Trying to send all finished work units
[16:06:24] + No unsent completed units remaining.
Re: Project: 5751 (Run 6, Clone 154, Gen 8)
Yes that's a bad WU. I've marked it ... again.
Here is the original thread : viewtopic.php?f=19&t=7657
anko1
Post by anko1 »
Hmm, that's interesting that there's another thread on this unit. I put the unit in the search box to see if it had already been reported. Btw, thanks for checking on all my units, toTOW.
The forum search engine is not working very well ... did you try the google search module ?
anko1
Post by anko1 »
Nope. Thanks for the tip. I'll use that in the future.
