Project: 2665 (Run 2, Clone 918, Gen 80)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
This was an EUE, and another corestatus 7B.
[05:32:04] + Closed connections
[05:32:09]
[05:32:09] + Processing work unit
[05:32:09] Work type a1 not eligible for variable processors
[05:32:09] Core required: FahCore_a1.exe
[05:32:09] Core found.
[05:32:09] Using generic mpiexec calls
[05:32:09] Working on queue slot 03 [January 17 05:32:09 UTC]
[05:32:09] + Working ...
[05:32:09] - Calling 'mpiexec -np 4 -channel auto -host 127.0.0.1 FahCore_a1.exe -dir work/ -suffix 03 -checkpoint 15 -verbose -lifeline 3492 -version 623'
[05:32:09]
[05:32:09] *------------------------------*
[05:32:09] Folding@Home Gromacs SMP Core
[05:32:09] Version 1.74 (March 10, 2007)
[05:32:09]
[05:32:09] Preparing to commence simulation
[05:32:09] - Looking at optimizations...
[05:32:09] - Created dyn
[05:32:09] - Files status OK
[05:32:14] - Expanded 4800297 -> 24810145 (decompressed 516.8 percent)
[05:32:14] - Starting from initial work packet
[05:32:14]
[05:32:14] Project: 2665 (Run 2, Clone 918, Gen 80)
[05:32:14]
[05:32:15] Assembly optimizations on if available.
[05:32:15] Entering M.D.
[05:32:37] al work packet
[05:32:37]
[05:32:37] Project: 2665 (Run 2, Clone 918, Gen 80)
[05:32:37]
[05:32:37] 65 (Run 2, Clone 918, Gen 80)
[05:32:37]
[05:32:38] Entering M.D.
[05:32:44] Rejecting checkpoint
[05:32:46] Protein: HGG with glycosylations
[05:32:46] Writing local files
[05:32:54] Extra SSE boost OK.
[05:32:55] Writing local files
[05:32:55] Completed 0 out of 250000 steps  (0 percent)
[05:39:07] - Autosending finished units... [January 17 05:39:07 UTC]
[05:39:07] Trying to send all finished work units
[05:39:07] + No unsent completed units remaining.
[05:39:07] - Autosend completed
[05:47:55] Timered checkpoint triggered.
[05:48:59] Writing local files
[05:48:59] Completed 2500 out of 250000 steps  (1 percent)
[06:04:00] Timered checkpoint triggered.
[06:05:06] Writing local files
[06:05:06] Completed 5000 out of 250000 steps  (2 percent)
[06:09:44] Warning:  long 1-4 interactions
[06:09:45] _UNIT_END
[06:09:45] Finalizing output
[06:09:45] her.
[06:09:45] Going to send back what have done.
[06:09:45] logfile size: 12963
[06:09:45] - Writing 13499 bytes of core data to disk...
[06:09:45]   ... Done.
[06:11:45]
[06:11:45] Folding@home Core Shutdown: EARLY_UNIT_END
[06:11:45]
[06:11:49] CoreStatus = 7B (123)
[06:11:49] Sending work to server
[06:11:49] Project: 2665 (Run 2, Clone 918, Gen 80)
[06:11:49] + Attempting to send results [January 17 06:11:49 UTC]
[06:11:49] - Reading file work/wuresults_03.dat from core
[06:11:49]   (Read 13499 bytes from disk)
[06:11:49] Connecting to http://171.64.65.64:8080/
[06:11:49] Posted data.
[06:11:49] Initial: 0000; - Uploaded at ~14 kB/s
[06:11:50] - Averaged speed for that direction ~238 kB/s
[06:11:50] + Results successfully sent
[06:11:50] Thank you for your contribution to Folding@Home.
Re: Project: 2665 (Run 2, Clone 918, Gen 80)
You got partial credit for it :
Hi anko1 (team 47815),
Your WU (P2665 R2 C918 G80) was added to the stats database on 2009-01-17 00:28:41 for 8.86 points of credit.
There's another report for partial credit, but someone was finally able to complete it.
FWIW, both partial credits seem to have come from Windows XP and the successful completion was from Linux.
This isn't something I normally check, but in those cases that I've checked before I didn't see this pattern, so I really don't want to imply that it's more than a statistical anomaly.
anko1
Post by anko1 »
bruce wrote:FWIW, both partial credits seem to have come from Windows XP and the successful completion was from Linux.
That's interesting. And yes, I've got Windows XP.
