F@H serious error
zimmerc
F@H serious error
Post by zimmerc »
I have been running F@H for months on my computer and all of sudden I keep getting a message and can not fold any more. the message is "Folding@home has run into a serious error running the core and will shut down". I erased the program and downloaded it again and I still get the same thing. Any help appreciated.
Re: F@H serious error
What were the Project/Run/Clone/Gen numbers of the WU being worked on? After you replaced the program, did you get a different P/R/C/G? If not, you probably need to erase the work directory and let it build it again. Then recheck to see if you get the same WU again or a new one.
Log file please ? ©
spazzychalk
Post by spazzychalk »
i had this same thing happen with an error, even after i deleted the folder before reinstalling. let them get the log here before you do get rid of it all so they can correct the problem, but i had to go through proper uninstall, then delete the left over program folder, and the other remnants in the appdata roaming folder, restart, then reinstall
zimmerc
Post by zimmerc »
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Users\Charles\AppData\Roaming\Folding@home-x86
[04:04:02] - Ask before connecting: No
[04:04:02] - User name: Charles_Zimmerman (Team 147178)
[04:04:02] - User ID: 6BD73DC84324A3CA
[04:04:02] - Machine ID: 1
[04:04:02]
[04:04:02] Loaded queue successfully.
[04:04:02] Initialization complete
[04:04:02]
[04:04:02] + Processing work unit
[04:04:02] Core required: FahCore_78.exe
[04:04:02] Core found.
[04:04:02] Working on queue slot 03 [January 29 04:04:02 UTC]
[04:04:02] + Working ...
[04:04:02]
[04:04:02] *------------------------------*
[04:04:02] Folding@Home Gromacs Core
[04:04:02] Version 1.90 (March 8, 2006)
[04:04:02]
[04:04:02] Preparing to commence simulation
[04:04:02] - Ensuring status. Please wait.
[04:04:19] - Looking at optimizations...
[04:04:19] - Working with standard loops on this execution.
[04:04:19] - Created dyn
[04:04:19] - Files status OK
[04:04:19] - Expanded 356949 -> 3006825 (decompressed 842.3 percent)
[04:04:19] - Starting from initial work packet
[04:04:19]
[04:04:19] Project: 2620 (Run 32, Clone 19, Gen 17)
[04:04:19]
[04:04:19] Entering M.D.
[04:04:29] Protein: p2620_p1475_tet1_03_1 t= 20000.00000
[04:04:29]
[04:04:29] Writing local files
[04:04:29] Gromacs error.
[04:04:29]
[04:04:29] Folding@home Core Shutdown: UNKNOWN_ERROR
[04:04:32] CoreStatus = 79 (121)
[04:04:32] Client-core communications error: ERROR 0x79
[04:04:32] This is a sign of more serious problems, shutting down.
Delete the WU until you get something else. I've reported the one giving you issues as bad.
zimmerc
Post by zimmerc »
how do you delete it?
anandhanju
Post by anandhanju »
Stop the client; delete the work directory, queue.dat, and unitinfo.txt. As toTOW has reported this WU as bad, you should get a new WU.
The directory can be found at C:\Users\Charles\AppData\Roaming\Folding@home-x86
PS. Welcome to the forum ;)
zimmerc
Post by zimmerc »
thank you all.
John_Weatherman
Post by John_Weatherman »
From your log :[04:04:19] - Working with standard loops on this execution.
I would add the -foreasm flag, otherwise if you work with standard loops (that is without SSE) it will work really slowly. See the Wiki if you need to know how to.
