Got a completed protein to return to this server, but the server is down?
Doesn't seem to have an owner.
Any chance of an update when it is going to be up again?
Teddy
171.64.122.136 down? (VSP70)
silas_the_monk
- Hardware configuration: 1. EEE PC (Linux)
2. HP Windows Vista - Contact:
Re: 171.64.122.136 down? (VSP70)
I'm having a similar problem with this IP address
[02:09:49] Finished Work Unit:
[02:09:49] - Reading up to 194040 from "work/wudata_09.arc": Read 194040
[02:09:49] - Reading up to 51580 from "work/wudata_09.xtc": Read 51580
[02:09:49] goefile size: 0
[02:09:49] logfile size: 89825
[02:09:49] Leaving Run
[02:09:51] - Writing 385189 bytes of core data to disk...
[02:09:51] ... Done.
[02:09:51] - Shutting down core
[02:09:51]
[02:09:51] Folding@home Core Shutdown: FINISHED_UNIT
[02:09:54] CoreStatus = 64 (100)
[02:09:54] Sending work to server
[02:09:54] Project: 2526 (Run 45, Clone 40, Gen 10)
[02:09:54] + Attempting to send results [January 25 02:09:54 UTC]
[02:10:16] - Couldn't send HTTP request to server
[02:10:16] + Could not connect to Work Server (results)
[02:10:16] (171.64.122.136:8080)
[02:10:16] + Retrying using alternative port
[02:10:37] - Couldn't send HTTP request to server
[02:10:37] + Could not connect to Work Server (results)
[02:10:37] (171.64.122.136:80)
[02:10:37] - Error: Could not transmit unit 09 (completed January 25) to work server.
[02:10:37] Keeping unit 09 in queue.
[02:10:37] Project: 2526 (Run 45, Clone 40, Gen 10)
[02:10:37] + Attempting to send results [January 25 02:10:37 UTC]
[02:10:58] - Couldn't send HTTP request to server
[02:10:58] + Could not connect to Work Server (results)
[02:10:58] (171.64.122.136:8080)
[02:10:58] + Retrying using alternative port
[02:11:19] - Couldn't send HTTP request to server
[02:11:19] + Could not connect to Work Server (results)
[02:11:19] (171.64.122.136:80)
[02:11:19] - Error: Could not transmit unit 09 (completed January 25) to work server.
[02:11:19] + Attempting to send results [January 25 02:11:19 UTC]
[02:11:24] - Server does not have record of this unit. Will try again later.
[02:11:24] Could not transmit unit 09 to Collection server; keeping in queue.
[02:11:24] - Preparing to get new work unit...
[02:11:24] + Attempting to get work packet
[02:11:24] - Connecting to assignment server
[02:11:25] - Successful: assigned to (171.64.122.136).
[02:11:25] + News From Folding@Home: Welcome to Folding@Home
[02:11:26] Loaded queue successfully.
[02:11:47] - Couldn't send HTTP request to server
[02:11:47] + Could not connect to Work Server
[02:11:47] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[02:11:56] + Attempting to get work packet
[02:11:56] - Connecting to assignment server
[02:11:57] - Successful: assigned to (171.64.122.136).
[02:11:57] + News From Folding@Home: Welcome to Folding@Home
[02:11:57] Loaded queue successfully.
[02:12:18] - Couldn't send HTTP request to server
[02:12:18] + Could not connect to Work Server
[02:12:18] - Attempt #2 to get work failed, and no other work to do.
[02:12:36] + Attempting to get work packet
[02:12:36] - Connecting to assignment server
[02:12:37] - Successful: assigned to (171.64.122.136).
[02:12:37] + News From Folding@Home: Welcome to Folding@Home
[02:12:37] Loaded queue successfully.
[02:12:58] - Couldn't send HTTP request to server
[02:12:58] + Could not connect to Work Server
[02:12:58] - Attempt #3 to get work failed, and no other work to do.
[02:13:19] + Attempting to get work packet
[02:13:19] - Connecting to assignment server
[02:13:19] - Successful: assigned to (171.64.122.136).
[02:13:19] + News From Folding@Home: Welcome to Folding@Home
[02:13:20] Loaded queue successfully.
[02:13:41] - Couldn't send HTTP request to server
[02:13:41] + Could not connect to Work Server
[02:13:41] - Attempt #4 to get work failed, and no other work to do.
[02:14:30] + Attempting to get work packet
[02:14:30] - Connecting to assignment server
[02:14:30] - Successful: assigned to (171.64.122.136).
[02:14:30] + News From Folding@Home: Welcome to Folding@Home
[02:14:31] Loaded queue successfully.
[02:14:52] - Couldn't send HTTP request to server
[02:14:52] + Could not connect to Work Server
[02:14:52] - Attempt #5 to get work failed, and no other work to do.
[02:16:12] + Attempting to get work packet
[02:16:12] - Connecting to assignment server
[02:16:12] - Successful: assigned to (171.64.122.136).
[02:16:12] + News From Folding@Home: Welcome to Folding@Home
[02:16:13] Loaded queue successfully.
[02:16:34] - Couldn't send HTTP request to server
[02:16:34] + Could not connect to Work Server
[02:16:34] - Attempt #6 to get work failed, and no other work to do.
[02:19:22] + Attempting to get work packet
[02:19:22] - Connecting to assignment server
[02:19:22] - Successful: assigned to (171.67.108.12).
[02:19:22] + News From Folding@Home: Welcome to Folding@Home
[02:19:23] Loaded queue successfully.
[02:19:33] Project: 2526 (Run 45, Clone 40, Gen 10)
[02:19:33] + Attempting to send results [January 25 02:19:33 UTC]
[02:19:54] - Couldn't send HTTP request to server
[02:19:54] + Could not connect to Work Server (results)
[02:19:54] (171.64.122.136:8080)
[02:19:54] + Retrying using alternative port
[02:20:15] - Couldn't send HTTP request to server
[02:20:15] + Could not connect to Work Server (results)
[02:20:15] (171.64.122.136:80)
[02:20:15] - Error: Could not transmit unit 09 (completed January 25) to work server.
[02:20:15] + Attempting to send results [January 25 02:20:15 UTC]
[02:20:15] (Got status 503)
[02:20:15] (171.67.108.17:8080)
[02:20:15] + Retrying using alternative port
[02:20:15] (171.67.108.17:80)
[02:20:15] Could not transmit unit 09 to Collection server; keeping in queue.
[02:20:15] + Closed connections
[02:20:15]
[02:20:15] + Processing work unit
[02:20:15] Core required: FahCore_a0.exe
[02:20:15] Core not found.
[02:20:15] - Core is not present or corrupted.
[02:20:15] - Attempting to download new core...
[02:20:15] + Downloading new core: FahCore_a0.exe
[02:20:17] + 10240 bytes downloaded
[02:20:17] + 20480 bytes downloaded
[02:20:17] + 30720 bytes downloaded
[02:20:18] + 40960 bytes downloaded
[02:20:18] + 51200 bytes downloaded
[02:20:18] + 61440 bytes downloaded
[02:20:18] + 71680 bytes downloaded
[02:20:18] + 81920 bytes downloaded
[02:20:18] + 92160 bytes downloaded
[02:20:18] + 102400 bytes downloaded
[02:20:18] + 112640 bytes downloaded
[02:20:18] + 122880 bytes downloaded
[02:20:18] + 133120 bytes downloaded
[02:20:19] + 143360 bytes downloaded
[02:20:19] + 153600 bytes downloaded
[02:20:19] + 163840 bytes downloaded
[02:20:19] + 174080 bytes downloaded
[02:20:19] + 184320 bytes downloaded
[02:20:19] + 194560 bytes downloaded
[02:20:19] + 204800 bytes downloaded
[02:20:19] + 215040 bytes downloaded
[02:20:19] + 225280 bytes downloaded
[02:20:19] + 235520 bytes downloaded
[02:20:19] + 245760 bytes downloaded
[02:20:19] + 256000 bytes downloaded
[02:20:19] + 266240 bytes downloaded
[02:20:19] + 276480 bytes downloaded
[02:20:19] + 286720 bytes downloaded
[02:20:19] + 296960 bytes downloaded
[02:20:19] + 307200 bytes downloaded
[02:20:19] + 317440 bytes downloaded
[02:20:20] + 327680 bytes downloaded
[02:20:20] + 337920 bytes downloaded
[02:20:20] + 348160 bytes downloaded
[02:20:20] + 358400 bytes downloaded
[02:20:20] + 368640 bytes downloaded
[02:20:20] + 378880 bytes downloaded
[02:20:20] + 389120 bytes downloaded
[02:20:20] + 399360 bytes downloaded
[02:20:20] + 409600 bytes downloaded
[02:20:20] + 419840 bytes downloaded
[02:20:20] + 430080 bytes downloaded
[02:20:20] + 440320 bytes downloaded
[02:20:20] + 450560 bytes downloaded
[02:20:20] + 460800 bytes downloaded
[02:20:20] + 471040 bytes downloaded
[02:20:20] + 481280 bytes downloaded
[02:20:20] + 491520 bytes downloaded
[02:20:20] + 501760 bytes downloaded
[02:20:20] + 512000 bytes downloaded
[02:20:20] + 522240 bytes downloaded
[02:20:20] + 532480 bytes downloaded
[02:20:20] + 542720 bytes downloaded
[02:20:20] + 552960 bytes downloaded
[02:20:20] + 563200 bytes downloaded
[02:20:20] + 573440 bytes downloaded
[02:20:20] + 583680 bytes downloaded
[02:20:20] + 593920 bytes downloaded
[02:20:20] + 604160 bytes downloaded
[02:20:21] + 614400 bytes downloaded
[02:20:21] + 624640 bytes downloaded
[02:20:21] + 634880 bytes downloaded
[02:20:21] + 645120 bytes downloaded
[02:20:21] + 655360 bytes downloaded
[02:20:21] + 665600 bytes downloaded
[02:20:21] + 675840 bytes downloaded
[02:20:21] + 686080 bytes downloaded
[02:20:21] + 696320 bytes downloaded
[02:20:21] + 706560 bytes downloaded
[02:20:21] + 716800 bytes downloaded
[02:20:21] + 727040 bytes downloaded
[02:20:21] + 737280 bytes downloaded
[02:20:21] + 747520 bytes downloaded
[02:20:21] + 757760 bytes downloaded
[02:20:21] + 768000 bytes downloaded
[02:20:21] + 778240 bytes downloaded
[02:20:21] + 788480 bytes downloaded
[02:20:21] + 798720 bytes downloaded
[02:20:21] + 808960 bytes downloaded
[02:20:21] + 819200 bytes downloaded
[02:20:21] + 829440 bytes downloaded
[02:20:21] + 839680 bytes downloaded
[02:20:21] + 849920 bytes downloaded
[02:20:21] + 860160 bytes downloaded
[02:20:21] + 870400 bytes downloaded
[02:20:21] + 880640 bytes downloaded
[02:20:21] + 890880 bytes downloaded
[02:20:21] + 901120 bytes downloaded
[02:20:21] + 911360 bytes downloaded
[02:20:21] + 921600 bytes downloaded
[02:20:21] + 931840 bytes downloaded
[02:20:21] + 942080 bytes downloaded
[02:20:21] + 952320 bytes downloaded
[02:20:21] + 962560 bytes downloaded
[02:20:21] + 972800 bytes downloaded
[02:20:21] + 983040 bytes downloaded
[02:20:22] + 993280 bytes downloaded
[02:20:22] + 1003520 bytes downloaded
[02:20:22] + 1013760 bytes downloaded
[02:20:22] + 1024000 bytes downloaded
[02:20:22] + 1034240 bytes downloaded
[02:20:22] + 1044480 bytes downloaded
[02:20:22] + 1054720 bytes downloaded
[02:20:22] + 1064960 bytes downloaded
[02:20:22] + 1073182 bytes downloaded
[02:20:22] Verifying core Core_a0.fah...
[02:20:22] Signature is VALID
[02:20:22]
[02:20:22] Trying to unzip core FahCore_a0.exe
[02:20:23] Decompressed FahCore_a0.exe (1656832 bytes) successfully
[02:20:23] Decompressed libfftw3f-3.dll (1382280 bytes) successfully
[02:20:28] + Core successfully engaged
[02:20:33]
[02:20:33] + Processing work unit
[02:20:33] Core required: FahCore_a0.exe
[02:20:33] Core found.
[02:20:33] Working on queue slot 00 [January 25 02:20:33 UTC]
[02:20:33] + Working ...
[02:20:33]
[02:20:33] *------------------------------*
[02:20:33] Folding@Home Gromacs 3.3 Core
[02:20:33] Version 1.93 (July 23, 2008)
[02:20:33]
[02:20:33] Preparing to commence simulation
[02:20:33] - Looking at optimizations...
[02:20:34] - Created dyn
[02:20:34] - Files status OK
[02:20:35] - Expanded 1147254 -> 6173133 (decompressed 538.0 percent)
[02:20:35] - Starting from initial work packet
[02:20:35]
[02:20:35] Project: 5113 (Run 97, Clone 54, Gen 15)
[02:20:35]
[02:20:35] Assembly optimizations on if available.
[02:20:35] Entering M.D.
[02:20:41] Rejecting checkpoint
[02:20:42] Protein: Calmodulin in water
[02:20:42] Writing local files
[02:20:46] Extra SSE boost OK.
[02:20:47] Writing local files
[02:20:47] Completed 0 out of 500000 steps (0 percent)
[03:24:25] Writing local files
[03:24:26] Completed 5000 out of 500000 steps (1 percent)
[04:26:43] Writing local files
[04:26:44] Completed 10000 out of 500000 steps (2 percent)
[05:28:44] Writing local files
[05:28:44] Completed 15000 out of 500000 steps (3 percent)
[06:30:44] Writing local files
[06:30:44] Completed 20000 out of 500000 steps (4 percent)
[06:52:46] Project: 2526 (Run 45, Clone 40, Gen 10)
[06:52:46] + Attempting to send results [January 25 06:52:46 UTC]
[06:53:07] - Couldn't send HTTP request to server
[06:53:07] + Could not connect to Work Server (results)
[06:53:07] (171.64.122.136:8080)
[06:53:07] + Retrying using alternative port
[06:53:28] - Couldn't send HTTP request to server
[06:53:28] + Could not connect to Work Server (results)
[06:53:28] (171.64.122.136:80)
[06:53:28] - Error: Could not transmit unit 09 (completed January 25) to work server.
[06:53:28] + Attempting to send results [January 25 06:53:28 UTC]
[06:53:33] - Server does not have record of this unit. Will try again later.
[06:53:33] Could not transmit unit 09 to Collection server; keeping in queue.
[06:53:33] + Working...
[07:32:40] Writing local files
[07:32:40] Completed 25000 out of 500000 steps (5 percent)
[08:34:36] Writing local files
[08:34:36] Completed 30000 out of 500000 steps (6 percent)
[09:37:06] Writing local files
[09:37:06] Completed 35000 out of 500000 steps (7 percent)
[10:39:47] Writing local files
[10:39:47] Completed 40000 out of 500000 steps (8 percent)
[11:42:09] Opening http://foldingforum.org/...
[11:42:49] Writing local files
[11:42:49] Completed 45000 out of 500000 steps (9 percent)
[12:45:55] Writing local files
[12:45:56] Completed 50000 out of 500000 steps (10 percent)
[12:53:33] Project: 2526 (Run 45, Clone 40, Gen 10)
[12:53:33] + Attempting to send results [January 25 12:53:33 UTC]
[12:53:54] - Couldn't send HTTP request to server
[12:53:54] + Could not connect to Work Server (results)
[12:53:54] (171.64.122.136:8080)
[12:53:54] + Retrying using alternative port
[12:54:15] - Couldn't send HTTP request to server
[12:54:15] + Could not connect to Work Server (results)
[12:54:15] (171.64.122.136:80)
[12:54:15] - Error: Could not transmit unit 09 (completed January 25) to work server.
[12:54:15] + Attempting to send results [January 25 12:54:15 UTC]
[12:54:21] - Server does not have record of this unit. Will try again later.
[12:54:21] Could not transmit unit 09 to Collection server; keeping in queue.
[12:54:21] + Working...
[13:29:27] Opening http://foldingforum.org/...
Any official comment from Stanford on this?
Its been down nearly 24hrs now & the CS obviously is not interested in collecting the finished proteins either?
Teddy
Teddy
Pande Group doesn't comment on every little bump in the road (though they do try). History also shows they'll jump on it first thing Monday morning.
Maybe one of the European Mods will see this tonight (today), and make sure it's the first thing PG sees Monday morning.
Yes the server is down ... but there's nothing more I can tell ... the machine might be broken, out of power or under maintenance.
VijayPande
- Pande Group Member
It's been under maintenance. I'll see where they are.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Chair, Biophysics
Stanford University
All up & running again
Teddy
Teddy
