Server 171.67.108.20 is not reacchable
bdo
Post by bdo »
When I put the IP adress of this server in my Browser, I do'nt receive a answer. but in the server status page it is in mode accept. I have no problem with the other server
The problem is that I try to send à WU to this server.
Can you see where is the problem.
Thanks
[13:09:42] - Autosending finished units... [January 24 13:09:42 UTC]
[13:09:42] Trying to send all finished work units
[13:09:42] Project: 4436 (Run 30, Clone 4, Gen 7)
[13:09:42] - Read packet limit of 540015616... Set to 524286976.
[13:09:42] + Attempting to send results [January 24 13:09:42 UTC]
[13:09:42] - Reading file work/wuresults_06.dat from core
[13:09:42] Working on queue slot 07 [January 24 13:09:42 UTC]
[13:09:42] + Working ...
[13:09:42] - Calling '.\FahCore_7c.exe -dir work/ -suffix 07 -checkpoint 15 -service -verbose -lifeline 4448 -version 623'
[13:09:42]   (Read 2349770 bytes from disk)
[13:09:42] Connecting to http://171.67.108.20:8080/
[13:09:42]
[13:09:42] *------------------------------*
[13:09:42] Folding@Home Double Gromacs Core C
[13:09:42] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[13:09:42]
[13:09:42] Preparing to commence simulation
[13:09:42] - Files status OK
[13:09:43] - Expanded 220976 -> 620709 (decompressed 280.8 percent)
[13:09:43]
[13:09:43] Project: 3859 (Run 2272, Clone 0, Gen 9)
[13:09:43]
[13:09:43] Assembly optimizations on if available.
[13:09:43] Entering M.D.
[13:09:49] Will resume from checkpoint file
[13:09:49] Working on p3850_fkbprelative_ligand
[13:09:49] Completed 0 out of 1000000 steps  (0%)
[13:09:49] Extra SSE2 boost OK
[13:09:49] Resuming from checkpoint
[13:09:50] Verified work/wudata_07.log
[13:09:50] Verified work/wudata_07.edr
[13:09:50] Verified work/wudata_07.xvg
[13:09:50] Verified work/wudata_07.trr
[13:09:50] Verified work/wudata_07.xtc
[13:09:50] Completed 66191 out of 1000000 steps  (6%)
[13:15:39] - Couldn't send HTTP request to server
[13:15:39] + Could not connect to Work Server (results)
[13:15:39]     (171.67.108.20:8080)
[13:15:39] + Retrying using alternative port
[13:15:39] Connecting to http://171.67.108.20:80/
[13:19:00] Completed 70000 out of 1000000 steps  (7%)
[13:19:12] - Couldn't send HTTP request to server
[13:19:12] + Could not connect to Work Server (results)
[13:19:12]     (171.67.108.20:80)
[13:19:12] - Error: Could not transmit unit 06 (completed January 24) to work server.
[13:19:12] - 4 failed uploads of this unit.
[13:19:12]   Keeping unit 06 in queue.
[13:19:12] + Sent 0 of 1 completed units to the server
[13:19:12] - Autosend completed
new08
Hardware configuration: Hewlett-Packard 1494 Win10 Build 1836
GeForce [MSI] GTX 950
Runs F@H Ver7.6.21
[As of Jan 2021]
Re: Server 171.67.108.20 is not reacchable
Post by new08 »
You are not alone..One week later things are still the same.
Before it was 17 that was down and I lost quite a few units. I used 20 to test browser and it was ok then.
Now I'm on the same tack with this one.
With no name against the server, maybe it's just pot luck if it gets checked or booted??
VJ said to my earlier query some new code was going in during Jan '09 on 108.17 - maybe it's affecting this one now also?
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
Sunday 1 Feb Though this server is showing as Accepting- it does appear to be more in reject mode with no uploads occurring and still not responding -with only one connection live at present.
One has to ask..how difficult is it to get/keep servers on line??
old_fool
Post by old_fool »
I am having problems with 171.67.108.20, too!
Is anyone reading these fora, at all?
And yes, does it take such great effort to keep a server running? I mean, thousands of people are doing a lot of voluntary work for Stanford - it would be really nice if the project team at Stanford could put some care in keeping the servers up.
Bear with me guys, I'm trying to be polite. But I'm fuming.
old_fool
Post by old_fool »
Can we contact an admin?
alpha
Post by alpha »
The stats page it is ACTIVE, yet my WU is still trying to upload to Stanford.
Are we being ignored or do they not have time to look into this problem thats been going on since Jan. 24, 2009?
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
I see that 108.20 is the only server in that range that does not have a collection server (CS Column) allocated.
Is this pertinent?
I have only one days grace to upload this unit on the 22nd Feb when the unit finishes.
If that fails [after three unit reruns] - then I will not use that client again ,as I've wasted a lot of time on this part of the project.
old_fool
Post by old_fool »
Hey new08,
what do you mean "not use this client"? I didn't think it was the client to determine the server you get your work units from, is it? If it is, should one re-install the client, and that will assign a different server?
I have stopped this computer 2 days ago. I only used it for checking my e-mails in the morning, and was keeping it up mostly for FAH. If these guys are unwilling to do the most basic maintenance work, then I won't bother either. I'll save the electricity, thanks.
What infuriates me most, however, is that I have this ideal that with these WUs I am helping, albeit very little, in research that may one day save the life of people with leukemia, Alzheimer's or CJD... or such. I'm not doing it for Stanford per se. There IS a bigger picture there!
alpha
Post by alpha »
I have 4 WU's that will die in a couple of days that need this server. I may just stop F@H too, it get a little saddening for all that work to just die.
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
Quote : If it is, should one re-install the client.
I have upgraded the client to 6.23 but this is the last shot.
Certain OS's and clients do seem to need certain servers- so my move away way on this basis.
I do have other PCs that run and all get this problem sometimes...but not quite so consistently as this .108.? ident!
old_fool
Post by old_fool »
new08 wrote:I have upgraded the client to 6.23 but this is the last shot.
Actually, that will probably not do the trick with your existing processed WUs. Just check this thread:
viewtopic.php?f=18&t=6302
The problem is that FAH has a broken-ass architecture, and the collection server is hard-coded in each WU. This wouldn't be a problem if each admin did his/her work conscientiously, but they aren't. How long has this comedy going on? A week? Almost two weeks? And a server that is UNABLE to collect WUs is still distributing them, basically wasting our resources for nothing. Just because a responsible person couldn't care to just go and unplug the damn server. Until that server is up, it's going to spread WUs that will not be collected.
I've sent a mail to Vijay to get more detail about this server.
VijayPande
Pande Group Member
Post by VijayPande »
There was a strange issue with this one, that was keeping this issue off of the serverstat radar. I've fixed that and we should be ok from here on out.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
alpha
Post by alpha »
Thank you, all my WU's have uploaded. I appreciate that someone looked at this thread and contacted the correct person to fix it.
Have a great day all.
old_fool
Post by old_fool »
alpha wrote:Thank you, all my WU's have uploaded. I appreciate that someone looked at this thread and contacted the correct person to fix it.
I concur - thanks for fixing the issue.
