Project: 2665 (Run 2, Clone 89, Gen 86)
Xilikon
Post by Xilikon »
A team member got a issue with that WU which always fail at 17%. Since there is no report, I'll make a new one to see if it's a known bad unit :
Launch directory: C:\Program Files\Folding@Home Windows SMP Client V1.01
Executable: C:\Program Files\Folding@Home Windows SMP Client V1.01\Folding@home-Win32-x86.exe
Arguments: -smp
[13:54:51] - Ask before connecting: No
[13:54:51] - User name:
[13:54:51] - User ID:
[13:54:51] - Machine ID: 1
[13:54:51]
[13:54:51] Could not open work queue, generating new queue...
[13:54:51] - Preparing to get new work unit...
[13:54:51] + Attempting to get work packet
[13:54:51] - Connecting to assignment server
[13:54:52] - Successful: assigned to (171.64.65.64).
[13:54:52] + News From Folding@Home: Welcome to Folding@Home
[13:54:52] Loaded queue successfully.
[13:55:15] + Closed connections
[13:55:15]
[13:55:15] + Processing work unit
[13:55:15] Work type a1 not eligible for variable processors
[13:55:15] Core required: FahCore_a1.exe
[13:55:15] Core found.
[13:55:15] Using generic mpiexec calls
[13:55:15] Working on queue slot 01 [January 22 13:55:15 UTC]
[13:55:15] + Working ...
[13:55:15]
[13:55:15] *------------------------------*
[13:55:15] Folding@Home Gromacs SMP Core
[13:55:15] Version 1.74 (March 10, 2007)
[13:55:15]
[13:55:15] Preparing to commence simulation
[13:55:15] - Files status OK
[13:55:24] - Expanded 4803458 -> 24810145 (decompressed 516.5 percent)
[13:55:24] - Starting from initial work packet
[13:55:24]
[13:55:24] Project: 2665 (Run 2, Clone 89, Gen 86)
[13:55:24]
[13:55:25] Assembly optimizations on if available.
[13:55:25] Entering M.D.
[13:55:47] ial work packet
[13:55:47]
[13:55:47] Project: 2665 (Run 2, Clone 89, Gen 86)
[13:55:47]
[13:55:53] check for stray files
[13:55:53] - Starting from initial work packet
[13:55:53]
[13:55:53] Project: 2665 (Run 2, Clone 89, Gen 86)
[13:55:53]
[13:55:55] Entering M.D.
[13:56:04] Rejecting checkpoint
[13:56:07] Protein: HGG with glycosylations
[13:56:07] Writing local files
[13:56:22] Extra SSE boost OK.
[13:56:23] Writing local files
[13:56:24] Completed 0 out of 250000 steps (0 percent)
[14:43:18] Writing local files
[02:31:26] Completed 40000 out of 250000 steps (16 percent)
[03:18:28] Writing local files
[03:18:28] Completed 42500 out of 250000 steps (17 percent)
[03:40:06] Warning: long 1-4 interactions
[03:40:06] Gromacs cannot continue further.
[03:40:06] Going to send back what have done.
[03:40:06] logfile size: 41984
[03:40:06] - Writing 42520 bytes of core data to disk...
[03:40:06] ... Done.
[03:40:07] - Failed to delete work/wudata_01.sas
[03:40:07] - Failed to delete work/wudata_01.goe
[03:40:07] Warning: check for stray files
[03:42:07]
[03:42:07] Folding@home Core Shutdown: EARLY_UNIT_END
[03:42:07]
[03:42:11] CoreStatus = 7B (123)
[03:42:11] Client-core communications error: ERROR 0x7b
[03:42:11] This is a sign of more serious problems, shutting down.
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
Re: Project: 2665 (Run 2, Clone 89, Gen 86)
Only one person has uploaded a result and it's incomplete (i.e.- an EUE) so I cannot conclude whether it's a bad WU or not. They only earned about 6% of the points, so it's probably not the same problem as your 17% error.
