Project: 5749 (Run 3, Clone 264, Gen 33)
klasseng
Hardware configuration: System 1: Mac Studio, M1 Max,
System 2: Mac Mini, M2
Post by klasseng »
Is anyone else having trouble with this WU?
I'm getting:
- SHAKE violations on GPU
- Folding@home Core Shutdown: UNSTABLE_MACHINE
This GPU has finished 209 WU's with only one other problem . . . another known bad WU.
[09:55:06] Initial: 0000; - Receiving payload (expected size: 99260)
[09:55:07] - Downloaded at ~96 kB/s
[09:55:07] - Averaged speed for that direction ~72 kB/s
[09:55:07] + Received work.
[09:55:07] Trying to send all finished work units
[09:55:07] + No unsent completed units remaining.
[09:55:07] + Closed connections
[09:55:12]
[09:55:12] + Processing work unit
[09:55:12] Core required: FahCore_11.exe
[09:55:12] Core found.
[09:55:12] Working on queue slot 03 [January 21 09:55:12 UTC]
[09:55:12] + Working ...
[09:55:12] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 15 -forceasm -verbose -lifeline 4472 -version 623'
[09:55:12]
[09:55:12] *------------------------------*
[09:55:12] Folding@Home GPU Core - Beta
[09:55:12] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:55:12]
[09:55:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:55:12] Build host: amoeba
[09:55:12] Board Type: Nvidia
[09:55:12] Core      :
[09:55:12] Preparing to commence simulation
[09:55:12] - Assembly optimizations manually forced on.
[09:55:12] - Not checking prior termination.
[09:55:12] - Expanded 98748 -> 492276 (decompressed 498.5 percent)
[09:55:12] Called DecompressByteArray: compressed_data_size=98748 data_size=492276, decompressed_data_size=492276 diff=0
[09:55:12] - Digital signature verified
[09:55:12]
[09:55:12] Project: 5749 (Run 3, Clone 264, Gen 33)
[09:55:12]
[09:55:12] Assembly optimizations on if available.
[09:55:12] Entering M.D.
[09:55:18] Will resume from checkpoint file
[09:55:19] Working on Protein
[09:55:23] Client config found, loading data.
[09:55:24] Starting GUI Server
[09:55:24] Resuming from checkpoint
[09:55:24] Verified work/wudata_03.log
[09:55:24] Verified work/wudata_03.edr
[09:55:24] Verified work/wudata_03.xtc
[09:55:24] mdrun_gpu returned
[09:55:24] SHAKE violations on GPU
[09:55:24]
[09:55:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:55:27] CoreStatus = 7A (122)
[09:55:27] Sending work to server
[09:55:27] Project: 5749 (Run 3, Clone 264, Gen 33)
[09:55:27] - Error: Could not get length of results file work/wuresults_03.dat
[09:55:27] - Error: Could not read unit 03 file. Removing from queue.
[09:55:27] EUE limit exceeded. Pausing 24 hours.
peace,
Grant
Re: Project: 5749 (Run 3, Clone 264, Gen 33)
No one was able to return this WU yet ...
I suggest you delete your /work folder and queue.dat file to make sure that there is no file remaining from an old crash ... (I say so because the WU seems to be resuming from checkpoint, but it has just been downloaded).
