best usage of 2 boxes
muttonhunter
Hardware configuration: .
Post by muttonhunter »
I've been running a box @3.4ghz.w/smp and gpu folding and a second box @ 2.5ghz smp only, both are running windoze xp pro.
I think i will get max pts. by putting my gpu (8800 GT) into the second box(2.5GHz) and run smp and gpu on that w/windows xp. Then i would set up the first box (3.4ghz) with a 64-bit linux os and run smp only on that.
Am I correct in thinking that would be the max output i could get from my 2 boxes?
Cajun_Don
Re: best usage of 2 boxes
Post by Cajun_Don »
The only way to fine out, is to do what you suggest. Then you will know, what works best for your two systems.
Have a great day.
