Project 5760 (Run 8, Clone 110, Gen 129) unstable machine
CASSTOR !!!
Post by CASSTOR !!! »
Anyone comlpeted this one ?
09:39:13] Folding@Home GPU Core - Beta
[09:39:13] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[09:39:13]
[09:39:13] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:39:13] Build host: amoeba
[09:39:13] Board Type: Nvidia
[09:39:13] Core      :
[09:39:13] Preparing to commence simulation
[09:39:13] - Assembly optimizations manually forced on.
[09:39:13] - Not checking prior termination.
[09:39:13] - Expanded 68679 -> 357580 (decompressed 520.6 percent)
[09:39:13] Called DecompressByteArray: compressed_data_size=68679 data_size=357580, decompressed_data_size=357580 diff=0
[09:39:13] - Digital signature verified
[09:39:13]
[09:39:13] Project: 5760 (Run 8, Clone 110, Gen 129)
[09:39:13]
[09:39:13] Assembly optimizations on if available.
[09:39:13] Entering M.D.
[09:39:20] Working on Protein
[09:39:21] Client config found, loading data.
[09:39:22] Starting GUI Server
[09:43:26] Completed 1%
[09:47:31] Completed 2%
[09:51:36] Completed 3%
[09:55:42] Completed 4%
[09:59:46] Completed 5%
[10:03:50] Completed 6%
[10:07:54] Completed 7%
[10:11:59] Completed 8%
[10:16:02] Completed 9%
[10:20:06] Completed 10%
[10:24:10] Completed 11%
[10:28:15] Completed 12%
[10:30:52] Completed 13%
[10:30:53] mdrun_gpu returned
[10:30:53] NANs detected on GPU
[10:30:53]
[10:30:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:30:57] CoreStatus = 7A (122)
[10:30:57] Sending work to server
[10:30:57] Project: 5760 (Run 8, Clone 110, Gen 129)
[10:30:57] - Error: Could not get length of results file work/wuresults_03.dat
[10:30:57] - Error: Could not read unit 03 file. Removing from queue.
[10:30:57] Trying to send all finished work units
[10:30:57] + No unsent completed units remaining.
[10:30:57] - Preparing to get new work unit...
[10:30:57] + Attempting to get work packet
[10:30:57] - Will indicate memory of 3325 MB
[10:30:57] - Connecting to assignment server
[10:30:57] Connecting to http://assign-GPU.stanford.edu:8080/
[10:30:58] Posted data.
[10:30:58] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[10:30:58] + News From Folding@Home: GPU folding beta
[10:30:58] Loaded queue successfully.
[10:30:58] Connecting to http://171.67.108.11:8080/
[10:30:59] Posted data.
[10:30:59] Initial: 0000; - Receiving payload (expected size: 97116)
[10:31:00] - Downloaded at ~94 kB/s
[10:31:00] - Averaged speed for that direction ~68 kB/s
[10:31:00] + Received work.
[10:31:00] Trying to send all finished work units
[10:31:00] + No unsent completed units remaining.
[10:31:00] + Closed connections
[10:31:05]
[10:31:05] + Processing work unit
[10:31:05] Core required: FahCore_11.exe
[10:31:05] Core found.
[10:31:05] Working on queue slot 04 [January 18 10:31:05 UTC]
[10:31:05] + Working ...
[10:31:05] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -forceasm -verbose -lifeline 3308 -version 623'
[10:31:06]
[10:31:06] *------------------------------*
Thanks you
Re: Project 5760 (Run 8, Clone 110, Gen 129) unstable machine
There's no data for this WU in the DB yet :(
