Project: 2527 (Run 52, Clone 53, Gen 5)
anko1
(3.2GHz) HT;Windows XP
Post by anko1 »
EUE. On my son's older machine, so....
[14:03:30] + Closed connections
[14:03:30]
[14:03:30] + Processing work unit
[14:03:30] Core required: FahCore_78.exe
[14:03:30] Core found.
[14:03:30] Working on Unit 00 [January 15 14:03:30]
[14:03:30] + Working ...
[14:03:30] - Calling 'FahCore_78.exe -dir work/ -suffix 00 -checkpoint 15 -verbose -lifeline 4036 -version 503'
[14:03:30]
[14:03:30] *------------------------------*
[14:03:30] Folding@Home Gromacs Core
[14:03:30] Version 1.90 (March 8, 2006)
[14:03:30]
[14:03:30] Preparing to commence simulation
[14:03:30] - Looking at optimizations...
[14:03:30] - Created dyn
[14:03:30] - Files status OK
[14:03:30] + New frame time estimate; Working...
[14:03:30] - Expanded 239682 -> 1192097 (decompressed 497.3 percent)
[14:03:30] - Starting from initial work packet
[14:03:30]
[14:03:30] Project: 2527 (Run 52, Clone 53, Gen 5)
[14:03:30]
[14:03:30] Assembly optimizations on if available.
[14:03:30] Entering M.D.
[14:03:35] + New frame time estimate; Working...
[14:03:36] Protein: p2527_Am22-43
[14:03:36]
[14:03:36] Writing local files
[14:03:36] Extra SSE boost OK.
[14:03:37] Writing local files
[14:03:37] Completed 0 out of 2000000 steps  (0)
[14:03:40] + New frame time estimate; Working...
[14:18:36] Timered checkpoint triggered.
[14:27:13] Writing local files
[14:27:13] Completed 20000 out of 2000000 steps  (1)
[14:27:15] + Writing 'sec_per_frame = 74.599998' to config
[14:27:15] + Working ...Timered checkpoint triggered.
             {snip}
[04:34:00] Writing local files
[04:34:00] Completed 740000 out of 2000000 steps  (37)
[04:34:04] + Writing 'sec_per_frame = 70.500000' to config
[04:34:04] + Working ...Gromacs cannot continue further.
[04:43:50] Going to send back what have done.
[04:43:50] logfile size: 36230
[04:43:50] - Writing 36766 bytes of core data to disk...
[04:43:50]   ... Done.
[04:43:50]
[04:43:50] Folding@home Core Shutdown: EARLY_UNIT_END
[04:43:54] CoreStatus = 72 (114)
[04:43:54] Sending work to server
[04:43:54] + Attempting to send results
[04:43:54] - Reading file work/wuresults_00.dat from core
[04:43:54]   (Read 36766 bytes from disk)
[04:43:54] Connecting to http://171.64.122.136:8080/
[04:43:54] Posted data.
[04:43:54] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[04:43:54] - Uploaded at ~73 kB/s
[04:43:54] - Averaged speed for that direction ~188 kB/s
[04:43:54] + Results successfully sent
[04:43:54] Thank you for your contribution to Folding@Home.
Re: Project: 2527 (Run 52, Clone 53, Gen 5)
There are 4 similar reports of failure at the same progress ... I guess this trajectory has reached its end.
anko1
Post by anko1 »
Thanks for checking, toTOW.
