I have searched the forum and the FAQ's and could not find the answer, sorry if I missed it.
If you join a team, do the WU numbers from then on also get added to your indivdual WU total? I have finished seven WU's since joining a team. My overall score has increased for both, but my individual WU total has not increased while my team WU number has.
Am I doing something wrong, bad configuration or is this normal?
PC is an AMD 4000 64 dual core with ATI 1650 Pro PCIE graphics.
I am using the XP Console on Machine 1 and the GPU console on Machine 2 and it's working well.
Thanks!
Individual/Team WU accumulation?
Re: Individual/Team WU accumulation?
Hello Tromatic, welcome to the forum.
The work unit totals will continue to accumlate. However, they do not change once they have been submitted, i.e. if you change teams, the previous points stay with the previous team.
You can configure the client to add points as follows.
no name, no team #
name, no team #
name, team #
no name, team #
If you have set "name, team #" and new points are added to one, but not the other, then you may have a configuration problem. You may not have entered your user name exactly the same way as before.
no name, no team #
name, no team #
name, team #
no name, team #
Thanks much. The only change I made was to join a team. I will double check my config and make sure my user name is OK on both clients, although if my points are going up I must be OK.
FahMon is showing the correct user name on both. All numbers are increasing except the individual WU number. No biggie, the work is getting done but it is nice to see the number go up.
Thanks,
Matthew
Latest info:
Date of last work unit 2008-01-17 03:02:43
Total score 44884
Overall rank (if points are combined) 52880 of 896676
Active processors (within 50 days) 4
Active processors (within 7 days) 2
Donator Richard_M._Nixon
Team Default (includes all those WU returned without valid team number) (0)
Score 42561 (certificate)
Donator Rank 55305 of 896676
WU 266 (certificate)
Team ar15.com (40965)
Score 2323 (certificate)
Donator Rank 315881 of 896676
WU 7 (certificate)
Date of last
Active processors
(within 50 days) 2
Active processors
(within 7 days) 2
Thanks,
Matthew
Latest info:
Total score 44884
WU 7 (certificate)
Date of last
Active processors
(within 50 days) 2
Active processors
(within 7 days) 2
7im wrote:Hello Tromatic, welcome to the forum.
no name, no team #
name, no team #
name, team #
no name, team #
Now that you're folding for a named team, all your WUs should show up in that account. Your old folding totals on Team 0 will just sit there and collect dust.
Thank you!
Matthew
Matthew
uncle fuzzy wrote:Now that you're folding for a named team, all your WUs should show up in that account. Your old folding totals on Team 0 will just sit there and collect dust.
