Project: 3856 (Run 14, Clone 9, Gen 34)
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hello,
My machine was working on Project: 3856 (Run 14, Clone 9, Gen 34). It went through about 83 percent of its run successfully before terminating itself and sending what it had to you. I received 6 points (out of 401 points) if reading the data from EXTREME Overclocking correctly. Think this machine has worked successfully with this project or one similar to it before, but cannot verify as the FAH points update is presently going on.
Is this the right number of points for the work done? I shut down the client gracefully before restarting Windows XP Pro to apply the monthly security update.
As of now, it is still working on job 4441, about 75 percent of the way completed as of this writing. Below is a log file of what occurred from the time this machine ingested the a new core: FahCore_7c.exe (as the previous one was either corrupted or not valid for 3856).
Thanks,
Robby / Team Firefox
[01:17:31] Sending work to server
[01:17:31] Project: 5113 (Run 98, Clone 21, Gen 8)
[01:17:31] + Attempting to send results [January 14 01:17:31 UTC]
[01:18:24] + Results successfully sent
[01:18:24] Thank you for your contribution to Folding@Home.
[01:18:24] + Number of Units Completed: 384
[01:18:29] - Preparing to get new work unit...
[01:18:29] + Attempting to get work packet
[01:18:29] - Connecting to assignment server
[01:18:29] - Successful: assigned to (128.59.74.4).
[01:18:29] + News From Folding@Home: Welcome to Folding@Home
[01:18:29] Loaded queue successfully.
[01:18:31] + Closed connections
[01:18:31]
[01:18:31] + Processing work unit
[01:18:31] Core required: FahCore_7c.exe
[01:18:31] Core not found.
[01:18:31] - Core is not present or corrupted.
[01:18:31] - Attempting to download new core...
[01:18:31] + Downloading new core: FahCore_7c.exe
[01:18:32] + 10240 bytes downloaded
[01:18:32] + 20480 bytes downloaded
[01:18:32] + 30720 bytes downloaded
[01:18:32] + 40960 bytes downloaded
[01:18:32] + 51200 bytes downloaded
[01:18:32] + 61440 bytes downloaded
[01:18:32] + 71680 bytes downloaded
[01:18:32] + 81920 bytes downloaded
[01:18:32] + 92160 bytes downloaded
[01:18:32] + 102400 bytes downloaded
[01:18:32] + 112640 bytes downloaded
[01:18:32] + 122880 bytes downloaded
[01:18:32] + 133120 bytes downloaded
[01:18:32] + 143360 bytes downloaded
[01:18:32] + 153600 bytes downloaded
[01:18:32] + 163840 bytes downloaded
[01:18:33] + 174080 bytes downloaded
[01:18:33] + 184320 bytes downloaded
[01:18:33] + 194560 bytes downloaded
[01:18:33] + 204800 bytes downloaded
[01:18:33] + 215040 bytes downloaded
[01:18:33] + 225280 bytes downloaded
[01:18:33] + 235520 bytes downloaded
[01:18:33] + 245760 bytes downloaded
[01:18:33] + 256000 bytes downloaded
[01:18:33] + 266240 bytes downloaded
[01:18:33] + 276480 bytes downloaded
[01:18:33] + 286720 bytes downloaded
[01:18:33] + 296960 bytes downloaded
[01:18:33] + 307200 bytes downloaded
[01:18:33] + 317440 bytes downloaded
[01:18:33] + 327680 bytes downloaded
[01:18:33] + 337920 bytes downloaded
[01:18:33] + 348160 bytes downloaded
[01:18:33] + 358400 bytes downloaded
[01:18:33] + 368640 bytes downloaded
[01:18:33] + 378880 bytes downloaded
[01:18:33] + 389120 bytes downloaded
[01:18:33] + 399360 bytes downloaded
[01:18:33] + 409600 bytes downloaded
[01:18:33] + 419840 bytes downloaded
[01:18:33] + 430080 bytes downloaded
[01:18:33] + 440320 bytes downloaded
[01:18:33] + 450560 bytes downloaded
[01:18:33] + 460800 bytes downloaded
[01:18:33] + 471040 bytes downloaded
[01:18:33] + 481280 bytes downloaded
[01:18:33] + 491520 bytes downloaded
[01:18:33] + 501760 bytes downloaded
[01:18:33] + 512000 bytes downloaded
[01:18:33] + 522240 bytes downloaded
[01:18:33] + 532480 bytes downloaded
[01:18:33] + 542720 bytes downloaded
[01:18:34] + 552960 bytes downloaded
[01:18:34] + 563200 bytes downloaded
[01:18:34] + 573440 bytes downloaded
[01:18:34] + 583680 bytes downloaded
[01:18:34] + 593920 bytes downloaded
[01:18:34] + 604160 bytes downloaded
[01:18:34] + 614400 bytes downloaded
[01:18:34] + 624640 bytes downloaded
[01:18:34] + 634880 bytes downloaded
[01:18:34] + 645120 bytes downloaded
[01:18:34] + 655360 bytes downloaded
[01:18:34] + 665600 bytes downloaded
[01:18:34] + 675840 bytes downloaded
[01:18:34] + 686080 bytes downloaded
[01:18:34] + 696320 bytes downloaded
[01:18:34] + 706560 bytes downloaded
[01:18:34] + 716800 bytes downloaded
[01:18:34] + 727040 bytes downloaded
[01:18:34] + 737280 bytes downloaded
[01:18:34] + 745198 bytes downloaded
[01:18:34] Verifying core Core_7c.fah...
[01:18:34] Signature is VALID
[01:18:34]
[01:18:34] Trying to unzip core FahCore_7c.exe
[01:18:34] Decompressed FahCore_7c.exe (2138112 bytes) successfully
[01:18:39] + Core successfully engaged
[01:18:44]
[01:18:44] + Processing work unit
[01:18:44] Core required: FahCore_7c.exe
[01:18:44] Core found.
[01:18:44] Working on queue slot 03 [January 14 01:18:44 UTC]
[01:18:44] + Working ...
[01:18:45]
[01:18:45] *------------------------------*
[01:18:45] Folding@Home Double Gromacs Core C
[01:18:45] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[01:18:45]
[01:18:45] Preparing to commence simulation
[01:18:45] - Files status OK
[01:18:45] - Expanded 228149 -> 626717 (decompressed 274.6 percent)
[01:18:45]
[01:18:45] Project: 3856 (Run 14, Clone 9, Gen 34)
[01:18:45]
[01:18:45] Assembly optimizations on if available.
[01:18:45] Entering M.D.
[01:18:51] Working on p3856_fkbprelative_ligand
[01:18:51] Completed 0 out of 1000000 steps  (0%)
[01:18:51] Extra SSE2 boost OK
[01:27:51] Timer requesting checkpoint
[01:30:47] Completed 10000 out of 1000000 steps  (1%)
[01:39:47] Timer requesting checkpoint
[01:42:38] Completed 20000 out of 1000000 steps  (2%)
[01:51:38] Timer requesting checkpoint
[01:54:29] Completed 30000 out of 1000000 steps  (3%)
[02:03:29] Timer requesting checkpoint
[02:06:17] Completed 40000 out of 1000000 steps  (4%)
[02:15:17] Timer requesting checkpoint
[02:18:06] Completed 50000 out of 1000000 steps  (5%)
[02:27:06] Timer requesting checkpoint
[02:29:54] Completed 60000 out of 1000000 steps  (6%)
[02:38:54] Timer requesting checkpoint
[02:41:44] Completed 70000 out of 1000000 steps  (7%)
[02:50:44] Timer requesting checkpoint
[02:53:34] Completed 80000 out of 1000000 steps  (8%)
[03:02:34] Timer requesting checkpoint
[03:05:22] Completed 90000 out of 1000000 steps  (9%)
[03:14:22] Timer requesting checkpoint
[03:17:13] Completed 100000 out of 1000000 steps  (10%)
[03:26:13] Timer requesting checkpoint
[03:29:08] Completed 110000 out of 1000000 steps  (11%)
[03:31:40] + Working...
[03:38:08] Timer requesting checkpoint
[03:40:54] Completed 120000 out of 1000000 steps  (12%)
[03:49:54] Timer requesting checkpoint
[03:52:43] Completed 130000 out of 1000000 steps  (13%)
[04:01:43] Timer requesting checkpoint
[04:04:33] Completed 140000 out of 1000000 steps  (14%)
[04:13:33] Timer requesting checkpoint
[04:16:20] Completed 150000 out of 1000000 steps  (15%)
[04:25:20] Timer requesting checkpoint
[04:28:09] Completed 160000 out of 1000000 steps  (16%)
[04:37:09] Timer requesting checkpoint
[04:39:55] Completed 170000 out of 1000000 steps  (17%)
[04:48:55] Timer requesting checkpoint
[04:51:45] Completed 180000 out of 1000000 steps  (18%)
[05:00:45] Timer requesting checkpoint
[05:03:57] Completed 190000 out of 1000000 steps  (19%)
[05:12:57] Timer requesting checkpoint
[05:15:57] Completed 200000 out of 1000000 steps  (20%)
[05:24:58] Timer requesting checkpoint
[05:27:58] Completed 210000 out of 1000000 steps  (21%)
[05:36:59] Timer requesting checkpoint
[05:39:54] Completed 220000 out of 1000000 steps  (22%)
[05:48:55] Timer requesting checkpoint
[05:51:41] Completed 230000 out of 1000000 steps  (23%)
[06:00:41] Timer requesting checkpoint
[06:03:30] Completed 240000 out of 1000000 steps  (24%)
[06:12:30] Timer requesting checkpoint
[06:15:18] Completed 250000 out of 1000000 steps  (25%)
[06:24:18] Timer requesting checkpoint
[06:27:07] Completed 260000 out of 1000000 steps  (26%)
[06:36:07] Timer requesting checkpoint
[06:38:53] Completed 270000 out of 1000000 steps  (27%)
[06:47:54] Timer requesting checkpoint
[06:50:42] Completed 280000 out of 1000000 steps  (28%)
[06:59:42] Timer requesting checkpoint
[07:02:31] Completed 290000 out of 1000000 steps  (29%)
[07:11:32] Timer requesting checkpoint
[07:14:23] Completed 300000 out of 1000000 steps  (30%)
[07:23:23] Timer requesting checkpoint
[07:26:13] Completed 310000 out of 1000000 steps  (31%)
[07:35:14] Timer requesting checkpoint
[07:38:01] Completed 320000 out of 1000000 steps  (32%)
[07:47:02] Timer requesting checkpoint
[07:49:50] Completed 330000 out of 1000000 steps  (33%)
[07:58:51] Timer requesting checkpoint
[08:01:39] Completed 340000 out of 1000000 steps  (34%)
[08:10:40] Timer requesting checkpoint
[08:13:31] Completed 350000 out of 1000000 steps  (35%)
[08:22:31] Timer requesting checkpoint
[08:25:19] Completed 360000 out of 1000000 steps  (36%)
[08:34:19] Timer requesting checkpoint
[08:37:07] Completed 370000 out of 1000000 steps  (37%)
[08:46:07] Timer requesting checkpoint
[08:48:59] Completed 380000 out of 1000000 steps  (38%)
[08:57:59] Timer requesting checkpoint
[09:00:49] Completed 390000 out of 1000000 steps  (39%)
[09:09:49] Timer requesting checkpoint
[09:12:37] Completed 400000 out of 1000000 steps  (40%)
[09:21:37] Timer requesting checkpoint
[09:24:27] Completed 410000 out of 1000000 steps  (41%)
[09:31:40] + Working...
[09:33:27] Timer requesting checkpoint
[09:36:19] Completed 420000 out of 1000000 steps  (42%)
[09:45:19] Timer requesting checkpoint
[09:48:12] Completed 430000 out of 1000000 steps  (43%)
[09:57:12] Timer requesting checkpoint
[10:00:14] Completed 440000 out of 1000000 steps  (44%)
[10:09:14] Timer requesting checkpoint
[10:12:05] Completed 450000 out of 1000000 steps  (45%)
[10:21:05] Timer requesting checkpoint
[10:23:55] Completed 460000 out of 1000000 steps  (46%)
[10:32:55] Timer requesting checkpoint
[10:35:46] Completed 470000 out of 1000000 steps  (47%)
[10:44:46] Timer requesting checkpoint
[10:47:32] Completed 480000 out of 1000000 steps  (48%)
[10:56:32] Timer requesting checkpoint
[10:59:21] Completed 490000 out of 1000000 steps  (49%)
[11:08:21] Timer requesting checkpoint
[11:11:08] Completed 500000 out of 1000000 steps  (50%)
[11:20:08] Timer requesting checkpoint
[11:22:55] Completed 510000 out of 1000000 steps  (51%)
[11:31:55] Timer requesting checkpoint
[11:34:40] Completed 520000 out of 1000000 steps  (52%)
[11:43:40] Timer requesting checkpoint
[11:46:23] Completed 530000 out of 1000000 steps  (53%)
[11:55:23] Timer requesting checkpoint
[11:58:10] Completed 540000 out of 1000000 steps  (54%)
[12:07:10] Timer requesting checkpoint
[12:09:57] Completed 550000 out of 1000000 steps  (55%)
[12:18:57] Timer requesting checkpoint
[12:21:43] Completed 560000 out of 1000000 steps  (56%)
[12:30:43] Timer requesting checkpoint
[12:33:27] Completed 570000 out of 1000000 steps  (57%)
[12:42:27] Timer requesting checkpoint
[12:45:15] Completed 580000 out of 1000000 steps  (58%)
[12:54:15] Timer requesting checkpoint
[12:57:01] Completed 590000 out of 1000000 steps  (59%)
[13:06:01] Timer requesting checkpoint
[13:08:49] Completed 600000 out of 1000000 steps  (60%)
[13:17:49] Timer requesting checkpoint
[13:20:37] Completed 610000 out of 1000000 steps  (61%)
[13:29:37] Timer requesting checkpoint
[13:32:24] Completed 620000 out of 1000000 steps  (62%)
[13:41:24] Timer requesting checkpoint
[13:44:10] Completed 630000 out of 1000000 steps  (63%)
[13:53:11] Timer requesting checkpoint
[13:55:58] Completed 640000 out of 1000000 steps  (64%)
[14:04:58] Timer requesting checkpoint
[14:07:43] Completed 650000 out of 1000000 steps  (65%)
[14:16:43] Timer requesting checkpoint
[14:19:29] Completed 660000 out of 1000000 steps  (66%)
[14:28:29] Timer requesting checkpoint
[14:31:13] Completed 670000 out of 1000000 steps  (67%)
[14:40:13] Timer requesting checkpoint
[14:42:59] Completed 680000 out of 1000000 steps  (68%)
[14:51:59] Timer requesting checkpoint
[14:54:49] Completed 690000 out of 1000000 steps  (69%)
[15:03:49] Timer requesting checkpoint
[15:06:38] Completed 700000 out of 1000000 steps  (70%)
[15:15:38] Timer requesting checkpoint
[15:18:27] Completed 710000 out of 1000000 steps  (71%)
[15:27:27] Timer requesting checkpoint
[15:30:13] Completed 720000 out of 1000000 steps  (72%)
[15:31:40] + Working...
[15:39:13] Timer requesting checkpoint
[15:42:03] Completed 730000 out of 1000000 steps  (73%)
[15:51:03] Timer requesting checkpoint
[15:53:52] Completed 740000 out of 1000000 steps  (74%)
[16:02:52] Timer requesting checkpoint
[16:05:42] Completed 750000 out of 1000000 steps  (75%)
[16:14:42] Timer requesting checkpoint
[16:17:30] Completed 760000 out of 1000000 steps  (76%)
[16:26:30] Timer requesting checkpoint
[16:29:18] Completed 770000 out of 1000000 steps  (77%)
[16:38:18] Timer requesting checkpoint
Folding@Home Client Shutdown.
--- Opening Log file [January 14 16:48:09 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Robby\Application Data\Folding@home-x86
Arguments: -advmethods
[16:48:09] - Ask before connecting: No
[16:48:09] - User name: Robby (Team 39299)
[16:48:09] - User ID:
[16:48:09] - Machine ID: 1
[16:48:09]
[16:48:09] Loaded queue successfully.
[16:48:09] Initialization complete
[16:48:09]
[16:48:09] + Processing work unit
[16:48:09] Core required: FahCore_7c.exe
[16:48:09] Core found.
[16:48:09] Working on queue slot 03 [January 14 16:48:09 UTC]
[16:48:09] + Working ...
[16:48:09]
[16:48:09] *------------------------------*
[16:48:09] Folding@Home Double Gromacs Core C
[16:48:09] Version 1.00 (Thu Apr 24 19:12:09 PDT 2008)
[16:48:09]
[16:48:09] Preparing to commence simulation
[16:48:09] - Files status OK
[16:48:09] - Expanded 228149 -> 626717 (decompressed 274.6 percent)
[16:48:09]
[16:48:09] Project: 3856 (Run 14, Clone 9, Gen 34)
[16:48:09]
[16:48:09] Assembly optimizations on if available.
[16:48:09] Entering M.D.
[16:48:16] Will resume from checkpoint file
[16:48:16] Working on p3856_fkbprelative_ligand
[16:48:16] Completed 0 out of 1000000 steps  (0%)
[16:48:16] Extra SSE2 boost OK
[16:48:16] Resuming from checkpoint
[16:48:16] Verified work/wudata_03.log
[16:48:16] Verified work/wudata_03.edr
[16:48:17] Verified work/wudata_03.xvg
[16:48:17] Verified work/wudata_03.trr
[16:48:17] Verified work/wudata_03.xtc
[16:48:17] Completed 777541 out of 1000000 steps  (77%)
[16:51:18] Completed 780000 out of 1000000 steps  (78%)
[17:00:19] Timer requesting checkpoint
[17:03:07] Completed 790000 out of 1000000 steps  (79%)
[17:12:07] Timer requesting checkpoint
[17:14:53] Completed 800000 out of 1000000 steps  (80%)
[17:23:53] Timer requesting checkpoint
[17:26:40] Completed 810000 out of 1000000 steps  (81%)
[17:35:41] Timer requesting checkpoint
[17:38:29] Completed 820000 out of 1000000 steps  (82%)
[17:47:29] Timer requesting checkpoint
[17:50:22] Completed 830000 out of 1000000 steps  (83%)
[17:52:39] mdrun returned -1
[17:52:39] Going to send back what have done.
[17:52:39] logfile size: 59628
[17:52:39] - Writing 60166 bytes of core data to disk...
[17:52:39]   ... Done.
[17:52:39]
[17:52:39] Folding@home Core Shutdown: EARLY_UNIT_END
[17:52:42] CoreStatus = 72 (114)
[17:52:42] Sending work to server
[17:52:42] Project: 3856 (Run 14, Clone 9, Gen 34)
[17:52:42] + Attempting to send results [January 14 17:52:42 UTC]
[17:52:43] + Results successfully sent
[17:52:43] Thank you for your contribution to Folding@Home.
[17:52:48] - Preparing to get new work unit...
[17:52:48] + Attempting to get work packet
[17:52:48] - Connecting to assignment server
[17:52:48] - Successful: assigned to (171.67.108.13).
[17:52:48] + News From Folding@Home: Welcome to Folding@Home
[17:52:48] Loaded queue successfully.
[17:52:50] + Closed connections
[17:52:55]
[17:52:55] + Processing work unit
[17:52:55] Core required: FahCore_78.exe
[17:52:55] Core found.
[17:52:55] Working on queue slot 04 [January 14 17:52:55 UTC]
[17:52:55] + Working ...
[17:52:56]
[17:52:56] *------------------------------*
[17:52:56] Folding@Home Gromacs Core
[17:52:56] Version 1.90 (March 8, 2006)
[17:52:56]
[17:52:56] Preparing to commence simulation
[17:52:56] - Looking at optimizations...
[17:52:56] - Created dyn
[17:52:56] - Files status OK
[17:52:56] - Expanded 238039 -> 1167721 (decompressed 490.5 percent)
[17:52:56] - Starting from initial work packet
[17:52:56]
[17:52:56] Project: 4441 (Run 856, Clone 3, Gen 7)
[17:52:56]
[17:52:56] Assembly optimizations on if available.
[17:52:56] Entering M.D.
[17:53:02] Protein: p4441_Seq42_Amber03
[17:53:02]
[17:53:02] Writing local files
[17:54:30] Extra SSE boost OK.
[17:54:30] Writing local files
[17:54:30] Completed 0 out of 1500000 steps  (0%)
[18:14:01] Writing local files
[18:14:01] Completed 15000 out of 1500000 steps  (1%)
[18:33:06] Writing local files
[18:33:06] Completed 30000 out of 1500000 steps  (2%)
[18:52:12] Writing local files
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Project: 3856 (Run 14, Clone 9, Gen 34)
There are two reports in the DB : one for 0 points, and yours.
Hi Robby (team 39299),
Your WU (P3856 R14 C9 G34) was added to the stats database on 2009-01-14 12:02:22 for 6.92 points of credit.
Robby_Firefox
Hi toTOW,
Thanks for the answer. With 6.92 points, would that not round up to 7 points?
Or how do you folks work those numbers?
- Robby // Team Firefox
I don't know how the stats deal with the decimal point ... in the past, they used to be displayed ...
