As you can notice, they failled at different points.
[15:13:11] Loaded queue successfully.
[15:13:15] + Closed connections
[15:13:15]
[15:13:15] + Processing work unit
[15:13:15] Core required: FahCore_a0.exe
[15:13:15] Core found.
[15:13:15] Working on queue slot 03 [January 5 15:13:15 UTC]
[15:13:15] + Working ...
[15:13:15]
[15:13:15] *------------------------------*
[15:13:15] Folding@Home Gromacs 3.3 Core
[15:13:15] Version 1.93 (July 23, 2008)
[15:13:15]
[15:13:15] Preparing to commence simulation
[15:13:15] - Looking at optimizations...
[15:13:15] - Created dyn
[15:13:15] - Files status OK
[15:13:16] - Expanded 1161309 -> 6173133 (decompressed 531.5 percent)
[15:13:16] - Starting from initial work packet
[15:13:16]
[15:13:16] Project: 5114 (Run 125, Clone 73, Gen 4)
[15:13:16]
[15:13:16] Assembly optimizations on if available.
[15:13:16] Entering M.D.
[15:13:22] Rejecting checkpoint
[15:13:23] Protein: Calmodulin in water
[15:13:23] Writing local files
[15:13:25] Extra SSE boost OK.
[15:13:26] Writing local files
[15:13:26] Completed 0 out of 500000 steps (0 percent)
[15:53:36] Writing local files
[15:53:36] Completed 5000 out of 500000 steps (1 percent)
[16:33:54] Writing local files
[16:33:55] Completed 10000 out of 500000 steps (2 percent)
[17:12:44] Writing local files
[17:12:44] Completed 15000 out of 500000 steps (3 percent)
[17:51:56] Writing local files
[17:51:56] Completed 20000 out of 500000 steps (4 percent)
[18:33:00] Writing local files
[18:33:00] Completed 25000 out of 500000 steps (5 percent)
[19:11:34] Writing local files
[19:11:34] Completed 30000 out of 500000 steps (6 percent)
[19:49:58] Writing local files
[19:49:58] Completed 35000 out of 500000 steps (7 percent)
[20:30:20] Writing local files
[20:30:21] Completed 40000 out of 500000 steps (8 percent)
[21:08:37] Writing local files
[21:08:37] Completed 45000 out of 500000 steps (9 percent)
[21:49:49] Writing local files
[21:49:49] Completed 50000 out of 500000 steps (10 percent)
[14:25:28] 3 hours since checkpoint written...
[14:25:28]
[14:25:28] Folding@home Core Shutdown: EARLY_UNIT_END
[14:25:32] CoreStatus = 72 (114)
[14:25:32] Sending work to server
[14:25:32] Project: 5114 (Run 125, Clone 73, Gen 4)
[14:25:32] - Error: Could not get length of results file work/wuresults_03.dat
[14:25:32] - Error: Could not read unit 03 file. Removing from queue.
[14:25:32] - Preparing to get new work unit...Code: Select all
[23:52:12] Loaded queue successfully.
[23:52:16] + Closed connections
[23:52:16]
[23:52:16] + Processing work unit
[23:52:16] Core required: FahCore_a0.exe
[23:52:16] Core found.
[23:52:16] Working on queue slot 09 [January 6 23:52:16 UTC]
[23:52:16] + Working ...
[23:52:16]
[23:52:16] *------------------------------*
[23:52:16] Folding@Home Gromacs 3.3 Core
[23:52:16] Version 1.93 (July 23, 2008)
[23:52:16]
[23:52:16] Preparing to commence simulation
[23:52:16] - Looking at optimizations...
[23:52:16] - Created dyn
[23:52:16] - Files status OK
[23:52:17] - Expanded 1161309 -> 6173133 (decompressed 531.5 percent)
[23:52:17] - Starting from initial work packet
[23:52:17]
[23:52:17] Project: 5114 (Run 125, Clone 73, Gen 4)
[23:52:17]
[23:52:17] Assembly optimizations on if available.
[23:52:17] Entering M.D.
[23:52:23] Rejecting checkpoint
[23:52:24] Protein: Calmodulin in water
[23:52:24] Writing local files
[23:52:26] Extra SSE boost OK.
[23:52:27] Writing local files
[23:52:27] Completed 0 out of 500000 steps (0 percent)
[00:33:45] Writing local files
[00:33:45] Completed 5000 out of 500000 steps (1 percent)
[01:14:49] Writing local files
[01:14:49] Completed 10000 out of 500000 steps (2 percent)
[01:56:08] Writing local files
[01:56:08] Completed 15000 out of 500000 steps (3 percent)
[02:37:10] Writing local files
[02:37:10] Completed 20000 out of 500000 steps (4 percent)
[03:18:05] Writing local files
[03:18:05] Completed 25000 out of 500000 steps (5 percent)
[03:59:15] Writing local files
[03:59:16] Completed 30000 out of 500000 steps (6 percent)
[04:40:34] Writing local files
[04:40:34] Completed 35000 out of 500000 steps (7 percent)
[05:21:29] Writing local files
[05:21:29] Completed 40000 out of 500000 steps (8 percent)
[06:02:37] Writing local files
[06:02:37] Completed 45000 out of 500000 steps (9 percent)
[06:43:38] Writing local files
[06:43:38] Completed 50000 out of 500000 steps (10 percent)
[07:27:24] Writing local files
[07:27:24] Completed 55000 out of 500000 steps (11 percent)
[08:08:51] Writing local files
[08:08:51] Completed 60000 out of 500000 steps (12 percent)
[08:49:55] Writing local files
[08:49:56] Completed 65000 out of 500000 steps (13 percent)
[09:31:01] Writing local files
[09:31:01] Completed 70000 out of 500000 steps (14 percent)
[10:12:07] Writing local files
[10:12:07] Completed 75000 out of 500000 steps (15 percent)
[10:53:26] Writing local files
[10:53:26] Completed 80000 out of 500000 steps (16 percent)
[11:34:57] Writing local files
[11:34:57] Completed 85000 out of 500000 steps (17 percent)
[12:16:15] Writing local files
[12:16:15] Completed 90000 out of 500000 steps (18 percent)
[12:58:01] Writing local files
[12:58:01] Completed 95000 out of 500000 steps (19 percent)
[13:39:36] Writing local files
[13:39:36] Completed 100000 out of 500000 steps (20 percent)
[14:21:13] Writing local files
[14:21:13] Completed 105000 out of 500000 steps (21 percent)
[15:03:26] Writing local files
[15:03:26] Completed 110000 out of 500000 steps (22 percent)
[15:44:30] Writing local files
[15:44:30] Completed 115000 out of 500000 steps (23 percent)
[16:28:03] Writing local files
[16:28:03] Completed 120000 out of 500000 steps (24 percent)
[17:13:39] Writing local files
[17:13:39] Completed 125000 out of 500000 steps (25 percent)
[18:01:17] Writing local files
[18:01:17] Completed 130000 out of 500000 steps (26 percent)
[18:50:48] Writing local files
[18:50:48] Completed 135000 out of 500000 steps (27 percent)
[19:37:29] Writing local files
[19:37:29] Completed 140000 out of 500000 steps (28 percent)
[20:20:25] Writing local files
[20:20:25] Completed 145000 out of 500000 steps (29 percent)
[21:05:34] Writing local files
[21:05:34] Completed 150000 out of 500000 steps (30 percent)
[16:28:11] Writing local files
[16:28:11] Completed 155000 out of 500000 steps (31 percent)
[17:21:02] Writing local files
[17:21:02] Completed 160000 out of 500000 steps (32 percent)
[18:05:54] Writing local files
[18:05:54] Completed 165000 out of 500000 steps (33 percent)
[15:42:18] 3 hours since checkpoint written...
[15:42:18]
[15:42:18] Folding@home Core Shutdown: EARLY_UNIT_END
[15:42:23] CoreStatus = 72 (114)
[15:42:23] Sending work to server
[15:42:23] Project: 5114 (Run 125, Clone 73, Gen 4)
[15:42:23] - Error: Could not get length of results file work/wuresults_09.dat
[15:42:23] - Error: Could not read unit 09 file. Removing from queue.
[15:42:23] - Preparing to get new work unit...Has anyone made it to 100% and/or got points ?
